Results 1 to 7 of 7
Thread: 17" wheels on malibu wagon
08-04-2008 #1
- Join Date
- Aug 2008
- Location
- wisconsin
- Posts
- 11
Looking for advice on what backspace needed for 17"wheels on a 78 malibu wagon.The car has 2"dropped spindles and s-10 moog springs.The rear has 1 1/2 dropped springs,no frame notch or rolled wheelwell.Idont want to have any rub issues.Also what is agood tire size to run?Thanks for any and all advice.
08-05-2008 #2
- Join Date
- Dec 2004
- Location
- North Jersey
- Posts
- 983
17x8s with 4" backspacing should be fine at all four corners. I run that on my Monte SS with no issues, and my buddy with a '78 Malibu coupe has the same dimension on his car with no troubles. If you want to go bigger in the rear, definitely measure first!
Steve Ragusa - North Jersey
2006 Infiniti G35x
08-05-2008 #3I would run a 17x8 on the front (4.5 inch backspacing) and 17x9 or 9.5 on the rear with 4.75 inch backspacing.
87 Turbo T: Precision 5857 Billet Wheel turbo, PTE Turbosaver, Razor's Progressive Alky, Red's XP fuel pump hotwired, Accufab AFPR, TurboTweak 93/94 chip, Scanmaster 2.1, 9 inch K&N filter, aluminum driveshaft, 160 thermostat, 3 inch Terry Houston downpipe with dump, DMH electric exhaust cut-out, TH 2.5 inch exhaust with Magnaflows, RJC powerplate, torque strap, Dutt neck stock intercooler, LT1 MAF, Translator Plus, Digi-Tails LED sequential tail lights, Eaton posi, TA Performance rear end girdle
Simmons wheels: 17x8.5 front (4.32" backspacing) with 235/45/17s Vredestein Sessentas, 17x9 rear (4.75 backspacing) with 275/40/17s, SC&C Street Comp Stage 2 kit (adjustable upper control arms, Howe tall upper and lower ball joints, S10 Xtreme lower control arm bump stops), 13 inch Baer front brakes, S10 rear wheel cylinders
08-06-2008 #4
- Join Date
- Aug 2008
- Location
- wisconsin
- Posts
- 11
back to the top
thanks
08-07-2008 #5i run 17x8's on all four corners with 4.5 B.S. on my 80 wagon with a 2" drop front and rear
08-07-2008 #6
- Join Date
- Aug 2008
- Location
- wisconsin
- Posts
- 11
Hey Nowukno
What size tires are you running? Your wagon's wheels and tires look right.
thanks
Todd
08-07-2008 #7255/40 rear 215/45 front
Originally Posted by two to many
