View Full Version : LQ4/T56 Swap
ItDoRun
07-21-2008, 06:31 AM
Can a T56 be bolted up to an LQ4 6.0L? I assume it can since the aluminum blocks and these cast iron blocks are pretty much the same. I'm looking at getting a complete LQ4 with ECM, wiring, accessories, etc. Can the stock ECM be reprogrammed to accept a T56, and can the wiring harness be modified as well? Any help would be greatly appreciated.
If anyone is doing/has done this particular swap, I would like to discuss it you if possible.
thanks,
Chris
WS6
07-21-2008, 05:05 PM
Yes, to both your questions. I can not remember off the top of my head if you can simply unbolt the flex plate and bolt a flywheel on. I remember there being talk of a spacer for the 6.0s that were in front of the 4L80E. Sorry, I just don't remember. The ECM is the same for manual or autos, you just have to have it programmed accordingly.
