View Full Version : DIHPB vs. Caliper e-brake systems
Turbo67camaro
07-13-2008, 10:47 PM
Is there much difference in labor cost with installing a drum-in-hat parking brake system vs. a caliper with built-in e-brake system ?
What are the major pros and cons of each of these systems ?
zman1969
07-24-2008, 12:15 PM
IMO id go with the in hat park brake- very simple the old actuating calipers circa 1980 leaves alot to be desired im using the 98-02 LS1 fbody setup on my car the 93-97 LT1 isnt too bad either you may have to watch caliper mounting in relation to the shock absorbers
my .02c hope this helps
Turbo67camaro
07-24-2008, 06:28 PM
Thanks Zman.
I found some info after my post that indicated that the DIHPB systems do hold better. It seems like a cleaner install too. All things considered, I came to the same conclusion.
