    Results 1 to 2 of 2
      North Bend, WA
      Wilwood slotted only rotors in brake kits ?
      Does Wilwood offer brake kits in slotted only rotor form ?
      In particular, I'm considering a 140-7149 kit (rear, Dynalite Pro Series Rear Parking Brake Kit) - preferably in slotted only form.
      I've got a slotted only front system, and cross-drilled in the rear would look weird in conjunction.
      If that isn't available, I've found another good solution that will cost a few hundred more, but quality rotors in slotted only form is available. Downside to this alternative is it is not a drum in hat parking brake.
      Auburn, WA
      I believe you can only get the slotted rotors with the SL4 caliper - but call Wilwood to make sure. I could be wrong on that.
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
