View Full Version : II Much cold start: an update
parsonsj
06-28-2008, 06:45 AM
Recently I put one of Norris' catch cans on the car and went back to the factory PCV. (my car was sucking big quantities of oil out of the crankcase with the racing PCV setup). One lesson (http://www.maxchevy.com/columns/parsons/iii_5-parsons-1.html) there.
I also replaced all my Russell hose with hardline and Earl's hose. Another lesson (http://www.maxchevy.com/columns/parsons/iii_6-parsons-1.html) there.
I also removed the stereo as I'm working on packaging A/C. A third lesson there. :)
Anyway, with those changes, and with no change at all to the EFI tune, the car starts way better. 2 seconds max. It fires with a burst, then quickly drops to a fast idle, then a normal idle as the engine warms up. It's perfect.
Theories:
1. The stereo was causing a big voltage drop, causing the XFI to reset.
2. My plugs were coated in oil, and kept the engine from firing easily.
3. My car likes playing jokes on me.
4. I'm going insane.
jp
Steve1968LS2
06-28-2008, 07:31 AM
Glad to hear you're getting it sorted out.
My only ongoing "problem" is that sometimes the RPMs drop too low. For example, if I'm creeping in traffic. I give it gas and the RPM go up and when let off the gas they pendulum low (like 640) and the car stalls. It's not all the time but enough to be annoying when it does happen.
And yes, our cars love to play jokes on us. lol
I was thinking of AC, but I just can't get myself to clutter up my engine bay.
Oh yea John... where are the damn pictures!
Fuelie Nova
06-28-2008, 07:37 AM
Ha! I think it is 3 + 4!
My engine recently starting missing on light acceleration, I was ready to blame it on something associated with the XFI. Long story short... one bad plug wire.
I now developed a crackle in my left rear speaker last evening... I'm still trying to blame it on the XFI :hammer:
Tg
GBodyGMachine
John, I thought you were selling II Much?
neki67
06-28-2008, 07:40 AM
My thoughts exactly!!
But otherwise thanks for another fine write up John.
JEFFTATE
06-28-2008, 08:54 AM
Good article John.
We ( Days Chevrolet ) have been selling a fixed orifice type PCV
"Valve " ( Its really more like a fitting )to help cut down on the oil consumption of the factory LS Engines .
GM Part # 12572717
Like I said , it's more of a fixed orifice fitting instead of a valve.
It has a very small ( approximately 1/16th inch ) metered hole in it.
parsonsj
06-28-2008, 10:58 AM
Some photos...
https://www.pro-touring.com/forum/attachment.php?attachmentid=24164&d=1213363549
https://www.pro-touring.com/forum/attachment.php?attachmentid=24165&d=1213363549
https://www.pro-touring.com/forum/attachment.php?attachmentid=24166&d=1213363549
https://www.pro-touring.com/forum/attachment.php?attachmentid=24167&d=1213363813
Rick Dorion
06-28-2008, 12:15 PM
I tried the fixed orifice on my genI, made no difference(?)
John, are you catching much oil in the catch can? I have one coming :)
LS1NOVA
06-28-2008, 08:21 PM
Anyone know the correct way to use a pcv and catch can on a boosted engine?
JEFFTATE
06-30-2008, 04:46 AM
Yeah , It doesn't always work.
parsonsj
06-30-2008, 05:00 AM
Rick,
I get a splash of oil in the catch can. A drop or so per trip. At this rate, I may never have to drain it!
jp
Rick Dorion
06-30-2008, 08:30 AM
Hmm. I thought you'd catch more based on your earlier problem. Guess the OEM pcv helped alot!
parsonsj
06-30-2008, 08:42 AM
Yeah there's a real difference in how much air/oil can flow through them based on my "suck the pcv test" (I can't recommend anyone try that at home).
The cool part about all of this is it is that I have filtered air flowing through the crankcase now. Just like factory. :)
jp
MastMotorsports
06-30-2008, 11:44 AM
John,
I really like the bulkhead going from the hardline to the softline going to the fuel rail. Is that your piece or is that a purchased part? That is an elegant solution for that interface.
victionone
06-30-2008, 12:38 PM
Shaun,
John made it out of 2x2x1/8 aluminum angle.
parsonsj
06-30-2008, 01:10 PM
I really like the bulkhead going from the hardline to the softline going to the fuel rail. Is that your piece or is that a purchased part? That is an elegant solution for that interface.Thanks! Vic is right. (He had asked me about it earlier). I made it with a bandsaw and belt sander. I usually send my aluminum parts out for anodizing, but I was too impatient to wait for it this time. It's bolted to the firewall with 3 1/4" bolts and nut-serts.
jp
WS6
06-30-2008, 05:51 PM
It was the oil on the spark plugs. My bike runs slightly rich and by the time the plugs need changing it requires some throttle on initial start up. With new clean plugs, the bike fires of instantly and idles perfect from the start.
Glad to hear the car is running even better, John. As always, the work looks great. I like the hard lining much better,
