View Full Version : Lower ball joint ? Afco vs. Moog
framedoctor
06-27-2008, 02:27 PM
I am looking to lower my '86 442 in front after an engine swap. I would like about an inch or so. I considered drop spindles but thought if I could install the tall LBJs and eliminate some bump-steer, better yet. My problem is I am unsure which ball joint is correct. I've researched Afco, Howe and Moog and the base diameter for the tall ones from Afco and Moog have a smaller base dia. than the original for my car. Am I missing something? Part numbers would help alot.
The Howe seems to be the best but are pricey for me. It's not likely that I ever track this car, I just need the front a little lower. It already has Eibach springs all around.
Thanks in advance.
TPI Monte SS
06-27-2008, 03:47 PM
FWIW, I have the Howe ones in my car, and am very impressed with the construction. I don't track my car either, but I do drive it "spiritedly!"
framedoctor
06-30-2008, 04:51 PM
I got some LBJs, I got a pair of the Moogs locally from one of our suppliers to the bodyshop where I work. They are the K6117, I think they are for a 2WD truck? The threads on this look to be a larger dia. Am I supposed to drill the top of the taper to fit?
framedoctor
07-01-2008, 08:50 PM
The silent replies to my question inspired me to try the search button again. I think I found all the answers to my questions on SC&C's FAQs page. It felt like it was written directly to me.
I'll have that humble pie now please.
07-02-2008, 09:59 AM
How about a link to it?
I've seen the Howe units, but not the AFCO.
David
framedoctor
07-03-2008, 02:38 AM
The Afcos are circle track parts available at Summit, Jegs, or any other circle track catalog. They've been discussed on here but no one had ever listed part #s. I had even searched Afco and Moog by part # and came up empty handed. I've enlisted the help of a racer local to me, he's going to help me out.
Can anyone tell me if the Howe units are a direct replacement for my car, or would I still need to enlarge the taper on the bottom of the spindle?
TPI Monte SS
07-03-2008, 06:29 AM
The Howe pieces I got from SC&C were a direct bolt-on for my car, no mods to the taper of the spindle required.
