    Results 1 to 9 of 9
      Arlington Heights, IL
      C6 Zo6 wheels on 68 Camaro?
      Im wondering if i could fit 18x8.5 zo6 wheels up front on my 68 camaro with ats tall spindles and stock upper and lower control arms. I know i will need adapters for this. I had 17x9.5 zr1's that just werent working for me but these are an inch narrower and a little taller so they might clear my control arm. Has anyone done this? I really would rather put on some fikses or forgelines but i cant afford it so knock off vette wheels will have to do for now.
      thanks
      Jesse
      1969 Camaro under construction.
      1967 firebird. 6.0/t56. Ridetech stage 2. Moser 9 inch. Forgeline wheels.(SOLD)
      NW Burbs, IL
      Hi Jesse,
      I recently bought C6 wheels, which I beleive are 1" narrower than Z06 wheels? Anyway, I now have stock OEM tires mounted on these rims, which are 18x8.5 and 19x10. Backspacing is roughly 7" and 8.6" F/R. I will be buying adapters soon.
      https://www.pro-touring.com/forum/sh...ad.php?t=42366
      Anyway, I see you live in Arlington Heights. I'm in Mt. Prospect. You are more than welcome to come over and check them out and/or mock them up.
      The ones i am looking at are 18x8.5 as well. Im thinking they will work but would like to be sure. last year i ordered zr1's and eagle f1 tires to find that they dont fit. They were too wide. I wonder what the differance would be between my camaro susp. and the chevelle susp. My prolem was the wheel hitting the upper control arm.
      NW Burbs, IL
      Jesse,
      I can’t imagine that these wheels would not work. Again, you are more than welcome to make a template off one of my wheels.
      Just wondering, where are you planning on buying adapters from?
      The only adapter place i know of is skulte. How would i go about making a template off your wheel?
      thanks
      Jesse
      NW Burbs, IL
      Quote Originally Posted by CamaroJesse
      thanks
      Jesse
      Cardboard or posterboard?
      First a "negative" would have to be made to fit inside the wheel. Then use this to make the actual wheel template.
      Or make a template based on your suspension and bring it over?
      Did that make any sense?
      I think ive decided to go with a different wheel. Im always changing my mind. But thanks for the help, i do appreciate it!
      NW Burbs, IL
      No problem. What wheel did you end up choosing?
      I just bought a pair of 3" adapters on ebay for $78 shipped...will have the rears mounted next week.
      Well i have wheels on the car right now, they are just stock rallys but ill be buying wheels in a few months. Ive just been trying to figure out what it is i want. Im either going to get torque thrust II's or spend a little more and get CCW's. I really want a big dish in the back.
