View Full Version : Looking for wire crimp reference
67RSSS502
02-11-2005, 05:52 PM
Can anyone recommend a good wire crimper for heavy gauge wire? I am looking to crimp ends on 1/0 gauge cables and want to do a good job without spending a bunch of $. My intent is to crimp the ends on the cable at one end with them actually in the car after I cut them to the perfect length.
Thanks!
Dion
67RSSS502
ramz69ss
02-11-2005, 08:57 PM
the only people that crimp wire like that and that would have supplies availible to the public would be large welding suppliers,most everyone here,i am guessing,,,use compression fitting(car audio). i had them make a 50 ft. ground(2/0) for my welder.
personally,i have done it one time,i had a s10 with 12-15s,,,it had 10 batteries,the connectors were going to cost a small fortune,,,so i order some crimps(1/0) from stinger(car audio supplier) at the shop i worked at,,,,i used a set of channel locks to press one of the sides over on the wire(my crimps were split),then i did the same on the other until it was tight,,then i soldered the wire and shrink wrapped the fitting...cheaper and better than just a crimp
yody
02-11-2005, 10:47 PM
i use this anvil type thing, you stick the connector or end under an anvil that has a point on it. It holds it all together, while you put it on the floor and bang it with a hammer, crimps it like no other. They are like $25, try any electrical supply place like terminal supply.
1976SR71
02-12-2005, 10:11 AM
I would also solder / heat shrink when done.
Use a propane torch...And some Silver content solder for the best connection.
67RSSS502
02-15-2005, 02:49 PM
yody... i think i know what you are talking about, but just wanted to make sure it is something like this
http://www.usahardware.com/inet/shop/item/25160/icn/20-650283/hobart_welding/770122.htm
thanks!
Dion
67RSSS502
yody
02-15-2005, 03:02 PM
thats it
Pro-touring towncar
02-17-2005, 12:23 PM
I have used my trim hammer and anvil that I got from Eastwood. Works real well.
Tim
