View Full Version : 335s on a 67'-68'
Jetset700
06-16-2008, 10:17 AM
Ok I have the DSE Quadralink and deep tubs on the way. I need to
order wheels & tires. I know some have put 335s on 67'-68' Camaros but how tight are they? How low are you and any rubbing
issues? DSE recommends 18x11 with 315s on 67'. Anyone with
315s and unrolled lip? Rear is a 9in DSE spec width 50" +2.50" of
offset each side. BS numbers in you comments appreciated.
Peter
06-16-2008, 11:00 AM
very tight, you will just have to do more frame cutting. Should work fine with your link rear.
I'd get your rims and tires, cut the tubs out and set up from there. Modify your frame. Order your rear end to fit the wheels. mock it all up then put your tubs in last.
