b-rod
06-11-2008, 11:22 PM
Hey, my name's Brody from Coquitlam, which is just outside Vancouver, British Columbia and I've got a 1980 Cutlass Supreme.
ENGINE
357 SBC/TH-350, 9.25:1 compression, AFR 195's, Comp XE268, MSD ignition, dual 2 1/2" exhaust w/ x pipe into Magnaflow mufflers and the other usual stuff.
REAR END STUFF
Ford 9" rear end, 3.70 gears on a Detroit Locker, Iceman tubular double adjustable upper/lower contol arms, 11" rotors and Cadillac calipers.
FRONT END STUFF
I've got Speedway tubular uppers, Spohn tubular lowers with QA1 Pro-Coil coilover kit, and my hybrid brake setup with '98+ Blazer sealed hub/spindle with LS1 calipers and C5 Corvette rotors.
PLANS
Next year I plan to pull the body off the frame, box it, weld up all the un-neccessary holes, then start on the body work.
As far as performance goes, I'll be converting to fuel injection and swapping the TH-350 for a TKO-600.
Here a couple pictures of how it looks for now....
https://static1.pt-content.com/images/pt/2008/06/a1964c2f-1.jpg
https://static1.pt-content.com/images/pt/2008/06/de17a70c-1.jpg
Anyways, let me know what you think! Thanks
-Brody
https://www.pro-touring.com/forum/vbpicgallery.php?do=big&p=3763
ENGINE
REAR END STUFF
FRONT END STUFF
PLANS
-Brody
