View Full Version : Power steering lines for type 2 pump.
CamaroJesse
06-10-2008, 02:14 PM
I have the lee 670 steering box, type 2 pump, DSE rmote resevoir, and the braded lines from DSE. The dse kit only comes with 2 lines and i need more to hook it all up. Can anyone help me out or maybe show me a diagram or some pictures on how to route this?
thanks
Jesse
MarkM66
06-11-2008, 06:43 AM
Are there two different size fittings on the pump?
If so, I believe it is small fitting on pump to pressure on box, return on box to small fitting on resv., large fitting on resv. to large fitting on pump.
CamaroJesse
06-11-2008, 07:29 AM
Im pretty sure the kit i got from dse was made for the type 2 pump with the resevoir bolted on to the pump. But have a remote resevoir. thats where im getting confused,
tomspo04
06-11-2008, 03:32 PM
Which side is the pressue side on the box?
ZZ430
06-11-2008, 05:28 PM
I just did one on a Chevelle using the DSE type II pump and remote reservoir, making my own hoses.
Hope these pics help.
CarlC
06-11-2008, 07:05 PM
I believe that the pump will need to be tapped to have an AN o-ring fitting added to the return. I've forgotten if the pressure side is a simple screw-in part.
CamaroJesse
06-12-2008, 05:56 AM
That picture helps a bunch! Thanks alot!
