View Full Version : '89 F150 Big brakes? Any kits available?
cantvalve16
06-09-2008, 12:51 PM
Anybody know who deals in brake kits for off center stuff like an 89 F150 2wd? I am not opposed to changing lug patterns either. Just looking for a way to get some good brakes under this thing.
Skip Fix
06-09-2008, 02:28 PM
Man I'd look for a wrecked Lightning , the ones I've seen have some massive brakes.
TheRoadVirus
06-09-2008, 04:00 PM
Finally some interest, woohoo. We're a rare breed, my friend. Good luck.. let me know what you find out.
Randy67
06-10-2008, 04:35 AM
Supa cheapo method - F350 brakes, except for the whole 8-lug part. SRW would be better than DRW brakes. :firefire:
Apogee
06-10-2008, 05:45 AM
I've seen several 8 to 5-lug conversions done for Early Bronco applications running one-ton running gear, but it involves welding in holes and remachining rotors.
For a more bolt-on solution, I would think you could run adapters to make the pattern change and then select a higher-offset wheel to keep the track width the same by negating the thickness of the adapter.
Tobin
KORE3
Happyfunballs
06-10-2008, 06:39 AM
Found some rotors.
http://www.buybrakes.com/prostop/drilled-apps-Ford%20Truck%20&%20SUV.html
