View Full Version : Watts Link
G_T
06-06-2008, 06:52 PM
Has anyone installed a Watts Link on a Mopar? Specifically a 2nd gen Dodge Charger with a Dana 60. I'm planning to install a Moser Dana 60 and composite leaf springs and need to run a Watts link. I've seen several kits - most are targeting mustangs. I have no issues with welding/ets. just looking for a well thought out kit that is relatively straightforward in using or adapting to a mopar.
Thanks!
Steve1968LS2
06-06-2008, 07:17 PM
The Lateral Dynamics unit has been installed on a Mopar.. not sure if it was a Dana 60 though.
wicked67
06-07-2008, 03:06 PM
If you can I would make your own.
wicked67
06-07-2008, 03:08 PM
https://static1.pt-content.com/images/pt/2008/06/100_0288-1.jpg
G_T
06-08-2008, 01:03 AM
I will make my own after looking around.
That setup looks pretty slick.
Do you have any pics of the center swivel piece? What did you use for bearings?
06-08-2008, 10:01 AM
https://static1.pt-content.com/images/pt/2008/05/100_0285-1.jpg You can use a standard flat press fit roller bearing and have the cage hole drilled to fit.
