View Full Version : Anybody used Wait4me performance?
orang-kr8
06-03-2008, 08:24 PM
Sounds like they do a good job on pcm reprogramming, but anybody had a wire harness modified by them? (any pics?) or anybody recommend a good company for under $450.00?
Midnight68
06-03-2008, 08:37 PM
I cant remember what it cost me but I highly recommend Speartech.
http://speartech.com/
Mr.VENGEANCE
06-04-2008, 04:49 AM
whats with companies with funny names...
how serious can you take "wait for me"
scogin918
06-04-2008, 05:18 AM
I purchased a personal license from them a while back and have had good success e-mailing and downloading tunes through them for my car as well as my truck. As far as harnesses go, I 2nd using Speartech. They also provide good service after the sale.
WS6
06-04-2008, 06:24 AM
good point but he really does a good job. I have no idea why he chose that for a name.
John Spears used to work for GM. He is the owner of Speartech.
SatisTraction
06-04-2008, 04:49 PM
i used him for a tune. the turn around was VERY fast.
romar 02 SS
06-04-2008, 06:28 PM
My harness is from them.They did a good job, in the time frame they said it would be done. Called me when they had a question. I'm happy with there work. Larry
LS1NOVA
06-04-2008, 06:55 PM
I used him, good and fast
nitrovette
06-05-2008, 03:11 AM
Yes jesse took care of me fast and for a good price,fired right up tune was very close.Ive since got efilive and tune my own.
Camaross82
02-23-2009, 08:25 PM
how much for a harness and ecm?
Malibu Jax
02-24-2009, 11:21 AM
I thought I would add my experience with wait 4 me. Jesse and his wife run the operation and Jesse is the main tuner with his wife doing alot of the reworks on the harnesses.
I had an 02 ls1 harness reworked and my cpu reprogrammed. Jesse really knows his stuff on wiring and I am a novice at best so if you are like me make sure to write down your question and his answer should you have any. My harness was missing the fuse block so I was expecting relays with the rework but had to put them in myself. The harness came back with the plug ins labeled with avery labels so you did know what was what. In my case since I was missing some of the harness they labeled the important wires that were cut and got rid of the non-essential ones. The tune was to delete out security, rear-end ratio change, tire size, the basics. I am still working bugs out but I don't at this time attribute any of them to wait 4 me. I cannot remember for sure but I believe it was $350-400 which is very reasonable.
I went hunting because I knew I say this question before. https://www.pro-touring.com/forum/showthread.php?t=50353
I tried to find a photo of the harness when it came back but appariently did not take one. It just comes back with averys saying what sensor or purpose it is for.
https://static1.pt-content.com/images/pt/2009/01/DSC00284-1.jpg
dogger
02-26-2009, 04:03 PM
wait for me does good work. jesse has good service as well.
btw his name came from when he was doing tunes on the side before he started it as his full time business.
I will tell you though john at speartech has and will go out of his way to help you even if you don't buy his product which in my opinon speaks volumes and put's him at the top of my list when it's time to buy diffeernt items.
having said that both have been around for a number of year's and with good reason they take care of there customer's. if you've been in the lsx market any amount of time you will see second rate business don't last very long at all.
kurider
03-02-2009, 10:12 AM
I used speartech with my 98 camaro V6 to V8 swap and he did great work.
rockytopper
03-02-2009, 02:03 PM
I used Jesse on my first LS1 swap pcm tune. I highly recommend.
nitrovette
07-21-2009, 02:28 AM
Im actually trying to get ahold of jesse right now for a tune for a 01 saleen s/c speedster my dads building.
capbuster
07-21-2009, 07:35 PM
I did use Jesse for a reworked harness and tune. Everything looked good, and as several have stated, wires were labeled and retaped.
Engine did start right up but I had a problem with a battery drain. Checked several things and posted my problem on here. Called Jesse and did not get much help, was put off rather abruptly, he had no idea. Eventually, I tore down the wiring and isolated it to the 2 power connections going into the ECM. I had them switched, they were mislabeled. The battery power which is orange in the harness had a pink wire soldered as an extension, and the switched power lead which is pink had a white wire soldered on as an extension, why? I don't know. Switched them and everything is great! This is my experience, and it seems like an isolated incident, but it happens. Great price, but it did cost me a lot of time.
