View Full Version : SC&C: AFX vs Stage 2+
JLM
06-03-2008, 06:02 PM
I'm at the point where I need to get suspension pieces on order, however I'm going back and forth on SC&C's AFX upgrade using the tall spindles, or going with the Stage 2+ utilizing the factory spindles and the tall ball-joints.
Now, under normal circumstances, given the minimal cost increase, I would obviously go for the AFX spindles.
However, my issue is that I already have discs on the front of the car utilizing the factory style spindle.
If I go with the AFX spindle I will have to purchase a new front brake kit.
Granted, the front end disc kit I have installed is just a simple Master Power Brakes kit, so upgrading would be decent.
Given the cost involved however, in your mind is the AFX spindle that much better than the Stage 2+ which would end up being quite a bit cheaper not having to purchase new brakes for the front.
Car will primarily be used on the street, but will see a couple HPDE, and auto-x events per year.
Rick Dorion
06-03-2008, 06:12 PM
I'm in a similiar position except I have the taller UBJ's and SC&C UCA's. Since my car is a street car 9x% I'm very happy with the results so far. Now if/when there's ABS to go along with the AFX setup...hmmm.
6'9"Witha69
06-04-2008, 09:10 AM
I believe that Marcus has stated that the AFX setup beats the taller balljoint setup. I would call him since he is a straight shooter and will lead you down the right path.
If it were me, AFX. Also, have you bought rims? AFX spindles narrow the track width slightly (~1/4" per side) so that is something else to cosider.
JLM
06-04-2008, 09:20 AM
No, I have not purchased wheels yet. New rear-end and discs out back will change things slightly as well. So I need to get all this stuff in the car before I can take measurements for wheels.
I'll give SC&C a call today. Thanks.
chicane67
06-06-2008, 08:30 PM
...Which offsets the hat thickness of the late model brake systems. Gross numbers show you a TW change by 1/4"... but the hat thickness on a few aftermarket systems is nearing 1/2". So you actually gain 1/4" per side in TW...
6'9"Witha69
06-09-2008, 09:30 AM
...Which offsets the hat thickness of the late model brake systems. Gross numbers show you a TW change by 1/4"... but the hat thickness on a few aftermarket systems is nearing 1/2". So you actually gain 1/4" per side in TW...Correct, forgot about that especially for Wilwood and similar that use aluminum hats for 2 pc rotor setups. Those are .375" or greater in a lot of cases.
