View Full Version : Need help with GM part numbers
Bowtie racing
06-02-2008, 11:36 PM
Can someone give me correct GM part numbers for these :
-Z06/LS7 corvette fuel filter
-LSx Fbody clutch actuating combo ( master and slave cylinder)
Thank you!!!
JEFFTATE
06-03-2008, 05:02 AM
There is no serviceable fuel filter on the C6 Corvette.
( Z06 or otherwise ). Its in the tank. Part of the fuel pump module.
That doesn't sound like a good design to me , but that's the way the GM engineers did it.
2002 Camaro LS motor 6-speed :
Clutch Master Cylinder pn-12570277 ( $144.00 plus freight )
Clutch Slave Cylinder pn-15046288 ( $123.00 plus freight )
These do not come as a combo.
Available separately.
The line doesn't come with them either.
What are you putting them in ?
You'll probably have to make the line anyway.
I work at a GM Dealer , PM me and let me know if you want to buy them from me . I'll get them on the way.
Bowtie racing
06-03-2008, 08:52 AM
Hello Jeff,
Why i didnt ask here this at the first place..
I have thought the GM Z06 corvette fuel filter is serviceable ?! It supposed to work as an regulator same time ? I found this but as you said it seems to be C5 corvette only..
http://content.mamotorworks.com/img300/fr3065.jpg
My " great" plan was to use it and run only one line from fuel tank to engine ( LS7 )
As for the clutch actuating combo i have had a Gm hydraulic master / slave combo in previus project, Is it discontinued ? Here is picture of the master cylinder. Slave had similar hose allready installed and i just snaped em together and that was it.
http://i1.ebayimg.com/03/i/000/de/fc/fcff_1.JPG
I am looking it for my 69 camaro with T56.
JEFFTATE
06-03-2008, 09:57 AM
Hello Jeff,
That company is probably packaging their own kit.
OTHER companies sell it that way.
GM doesn't.
GM is wierd like that.
Bowtie racing
06-03-2008, 12:18 PM
Jeff you got PM:cheers:
Bowtie racing
06-05-2008, 04:49 AM
Jeff solved the mystery !!!!!!!! Thanks!!
James OLC
06-05-2008, 05:26 AM
Are you sure about that Jeff? Every master that I have seen/bought comes with the line and quick connect fitting attached? I know that the Raybestos replacement does not but the GM one's usually do. In the past I have had to buy the entire master assemebly just for the line (really just for the fitting) since it is not available on it's own. Maybe a recent change?
derekf
06-05-2008, 05:34 AM
If they've stopped including the line with the GM master, maybe they'll have started selling it on its own (which I'd like, I've got a master and no line).
JEFFTATE
06-05-2008, 06:10 AM
Ok , I was wrong about that.
They didn't stop including the line.
The line comes with the clutch master.
Also , the reservoir , fill line , fluid , and pressure line to the slave cylinder are on the master.
I just didn't have one here at the time to look at so I wasn't sure , yet.
Now I'm sure.
I got one in stock.
Bowtie racing
06-11-2008, 10:36 AM
I want to thanks Jeff for helping me with this. As you guys are reading this, Jeff has allready send me the parts:twothumbs
He ordered the parts in house and confirmed me it was what i was looking for. Next time when shopping for GM stuff , i ll bring my business to Jeff. :cheers:
JEFFTATE
06-12-2008, 01:21 PM
Thanks Man !
It's on the way !
