    Results 1 to 6 of 6
      Felton, DE
      How do i get dash pad off? 68 Firebird
      A while back my friends were helping me strip the entire interior while i was working on the engine and they got my dashpad halfway off. I'm not quite sure what they did but it seems to still be attached by the windsheild but everything else is unattached. Any ideas?
      1994 Z28 - 13.52@110mph 2.1 60ft T56, bolt-ons, suspension
      1978 Datsun 2+2 - 6.0L LS1 swap in progress
      1968 Firebird, 2820 dry- 2000 LS1, D&D Viper T56, RAM clutch/flywheel, 236/236 .651/.651 110+4LSA cam, victor JR EFI, 4150 TB, 42lbers, painless harness, Moroso 7qt pan, sfc, trac bars, 3" x pipe side exits, Telstars-30"MT streets/skinnies, mini-tub, 8.5" posi, richmond 4.56s, Hooker lLTs, Denny N20 DS, Fast dual wideband, Shotgun street scoop.
      http://www.myspace.com/shawnmacananny
      Jun 2008
      i am assuming that the dash pad in your firebird is the same if not very similar to my 67 camro.. my dash pad just pushs up and pulls out.. mine might not have something holding it in like it should but it is tight as heck..
      your might just be wedged in there... i could be wrong ..
      Check under the dash. There might be some nuts on the studs that go through the top of the dash.
      Central CA USA
      A 68 Camaro dash pad has studs with nuts under the dash. The 68 runs down the outer ends of the dash unlike a 67, these extensions don't have nuts, there are studs that snap into rectangular clips that snap into the dash. I don't recall if there are one or two studs per side, but you should be able to just pry the dash pad out after removing the nuts. I'm pretty sure the firebird is the same as Camaro.
      David
      Thanks for the clarification Dave. I have a 68 and thought they were the same.
      Greenville, IL
      Firebird comes off the same way as Camaro.
