View Full Version : Hedman 65019 Header Pic's
Mean 69
02-09-2005, 03:20 AM
Hi guys,
Does anyone have a picture of the mentioned headers? These are equal length, 1 3/4" primary tube deals, and I am most interested in the driver's side. I think most folks run the Elite's, this is NOT them, and I am having a really hard time finding any specific information on them.
A pic of a small block first gen Hooker Super Comp in 1 3/4" would be cool too, if available.
Muchos Gracias,
Mark
vanzuuk1
11-18-2006, 02:07 PM
Ttt
ITLBTU
01-17-2007, 02:36 PM
I have Hooker Supercomp 1 7/8" on my sm 400 in my '69 Camaro. I have never liked them. They hang to low. I think they are a little big as well. I'm looking for some 1 3/4" now. I will be looking for some custom header now, because I have a set of Brodix spread port heads for it now.
HILROD
01-17-2007, 09:55 PM
My buddies car I built has these on it. What part, or where, do you want to see? They fit great, no clearance issues. 1968 Camaro, 383, Edelbrock heads. They tuck up pretty tight too. FRANK
vanzuuk1
01-22-2007, 03:59 PM
Pics of driver and passenger side engine compartment and a few shots to show ground clearance please.
HILROD
01-27-2007, 01:28 PM
This is the left side header. I can't upload any more pics. The driver side dose not hit anything at all, and is tucked up tighter that this one. You can just see where the control arm almost hits one tube. I tried to push on the tube with a large flat bar, causing a slight crease. This was enough to create aroung 3/8 clearance. Also if I took shims out of the arm or had non-stock ones it would clear no problem. FRANK
HILROD
01-27-2007, 01:33 PM
Maybe it'll work now.
Rick Dorion
01-27-2007, 02:37 PM
Does the #1 pipe go in front of the 3 and 5 or over? I have the 65003's but could use more clearance on the steering box.
HILROD
01-27-2007, 08:55 PM
The two center pipes on the driver side, go under 1. It is close to the steering box at one point but does not touch. This car has the '69 ss350-302 frame-stands.
Rick Dorion
01-28-2007, 05:40 AM
Thanks. I do too. What motor mounts? It's tight with the energy suspension items!
HILROD
01-28-2007, 07:07 AM
The mounts are Energy poly mounts also. I will say these are the best fitting large tube headers, I've ever installed. No more supercomps for me.
