Results 1 to 9 of 9
Thread: Brakes stay locked up
05-29-2008 #1
I just installed a new power booster to my brake setup this weekend. The booster is new from Classic Industries. My brakes are all new from CCP including the master, which I was told I could run manual until I was ready to add the booster.
I measured the adjusting rod coming from the booster to the master and made sure the length was right. After getting it installed and driving the car the brakes will maintain pressure causing the brakes to lock. It appears to be caused by the booster as if it builds pressure and applies it to the master. After the car sits overnight there is no line pressure but if you drive a few blocks applying the brakes it will build and cause the brakes to stay applied. I did not have any issues when using the master as a manual brake systems (except stiff peddle and more brake effort).
Not sure if the booster could be bad or if there is something I am not considering or overlooked somehow. Suggestions are welcomed.
