View Full Version : T-400 modulator
madcarson
05-28-2008, 05:47 PM
Been so long since I drove it;has manual valve body so do I still need to hook up vaccume to modulator ?:smoke:
critter
05-28-2008, 06:47 PM
Yep, or it will never shift out of first gear at part throttle. Get a red stripe modulator so you can adjust the screw inside it to have some control over shift points.
MarkB
05-28-2008, 08:06 PM
If you have a manual control valve body, which it sounds as though you do, you shouldn't need a vacuum modulator. Most of the manual valve bodies, just plug off the port. Do you know what brand you are running?
madcarson
05-29-2008, 05:01 AM
no it was built about 15-20 yrs ago;low first gear etc.cost $2500 bucks then,I didn't think it neededV supply thanks again!:jump:
critter
05-29-2008, 09:11 AM
Whoops! My bad. I read right past that "manual valve body" part.
H8tulooze
06-06-2008, 05:47 PM
LOL:rotfl:
