View Full Version : Repro GNX wheel & big brakes
rmccubbin
05-28-2008, 02:28 PM
Does anyone know if a repro GNX wheel (Kirban, G-bodyparts.com) will allow 12" or 13" front brakes on a G-body? Thanks!
-Ryan Mc.
slowcamaro
05-28-2008, 04:24 PM
There a guy around that makes a 12" wilwood kit that fit under stock 16's
Randy67
05-29-2008, 04:14 AM
I have checked the GTA wheel (I believe it is the same as the GNX wheel ) and it doesn't fit the C5 brake setup. The rotor barely clears the wheel dropwell, caliper isn't even close to clearing. 12" setup should be okay, depending on the calipers used.
jackfrost
05-29-2008, 05:37 AM
i fit a 15" AL wheel over my 12" b-spindle brakes. wilwood GMIII caliper.
HILROD
05-29-2008, 07:04 AM
I can fit a 16 Enkei that looks like a GNX wheel over my 13 Baer fronts. It clears, but not by much.
FASTPACE
05-30-2008, 09:57 AM
They should fit 12" brakes just fine, the TTAs have 12" brakes on the front from the factory using the 16" GTA wheels. 13" will probably be pushing it for clearance, there isn't much with the 12" to start with.
Takid455
05-30-2008, 01:06 PM
these do not fit C5 brakes though. I tried.
