View Full Version : Exhaust too close to fuel pump?
bobbaganoosh
05-27-2008, 04:22 PM
My project is an '86 Mustang that I recently finished the fuel system on. I mounted the a1000 pump on the front side of the tank because I don't like the look of a sumped tank or the pump & lines hanging down. I must of had a brain fart when I did this, because I'm running an IRS from an '03 Cobra and the exhaust runs under the diff & turns outward approx. 2" from the pump. Is this too close? I've thought about fabbing up a heat shield if I could get away with it. I really like the look of a rear exit exhaust but I won't use it if it's going to give me problems. Thanks for any help.
BTW since the exhaust isn't done yet (I have a Cobra exhaust I'm using for mockup) I'd rather change that instead of moving the fuel pump.
Drewhelm
06-18-2008, 08:53 AM
If the exhaust is not blowing directly on the pump, no it should be fine.
