View Full Version : moving from flux to gas...
absintheisfun
05-26-2008, 07:48 PM
I have been using .030 flux for about 6 months now. I'm no pro, but I feel like I am getting more comfortable with welding, and I'm ready to start using gas. I have the guages and hook-ups with my current welder. What now???
I do need to reverse the polarity of the ground and the wire feed correct?
Now, what recomendations do you guys have for sheet metal?
What pressure do I set the gas to?
Size of wire, gas mix, any other extra safety precautions or things I need to take into account when using gas?
mcw
hotrdblder
05-26-2008, 07:50 PM
.023 wire when welding sheet metal
gas shoul dbe 15 cfm or so
mix should be c-25
gkring
05-26-2008, 08:01 PM
good timing. What size gas cylinders should the weekend fabricator use? I don't want something huge and cumbersome to move around the shop, but you also don't want to have to be exchanging tanks every weekend either.
MarkM66
06-03-2008, 06:40 AM
Just see what your welding shop has to offer on tanks.
Read you welders user manual too.
06-08-2008, 02:27 PM
Yes, reverse the polarity for use with shielding gas.
rockdogz
06-08-2008, 03:48 PM
Very good call - when I switched from flux to gas it was a huge difference! You will love the much cleaner welds.
