View Full Version : Drivetrain shudder?
Nessumsar
05-21-2008, 08:42 PM
Getting relatively bad drive train shudder at 70mph and 3500rpm. The shudder "pulses" about twice a second. It seems to do it worse on deceleration too. I do have solid engine mounts and a poly tranny mount.
astroracer
05-22-2008, 02:38 AM
The solid mounts will definetly transmit more vibration. The 1st thing I would check for yours would be the u-joints. It sounds like one or both may be dry. If they are not greasable they should be replaced.
Mark
Nessumsar
05-22-2008, 08:39 AM
I replaced both u-joints when I got the car running; the first time I put the car in gear, the rear joint exploded, sitting in my driveway!
But the shudder is enough to make the change in my center console rattle.
Chad-1stGen
05-22-2008, 11:16 AM
Does it shudder at cruise or only under acceleration/deceleration?
Nessumsar
05-22-2008, 02:33 PM
It shudders more so on decel, and less on cruise and accel.
mikes69z
06-05-2008, 08:45 AM
Is your driveshaft balanced?
Josh
06-05-2008, 09:20 AM
I had a similar problem and I went through everything from new mounts to pinion angle changes. The driveshaft was balanced a few years before when I changed rear ends so I never did that. I finnaly had it done when I was on power tour in Indiana because it was unbearable, and that did the job!
Nessumsar
06-05-2008, 09:23 AM
Awesome, I will look into getting it balanced.
CarlC
06-06-2008, 06:21 AM
Balance and pinion angle.
Josh
06-11-2008, 05:37 AM
Be sure to get back to us on the solution..
Vegas69
06-11-2008, 06:16 AM
Have been doing a lot of research on pinion and driveline angles. Decel vibration is a sign of a pinion angle problem. I think it's to little. Driveline and pinion angle should be equal but opposite. Meaning the driveline points down 3 degrees...the rearend points up 3 degrees. The driveshaft must also be at the right angle. Classic chevy 5 speed has a good article on it along with googl.e If you just replaced U Joints and they are bad already, there is a good chance you have to little angle as well.
Nessumsar
06-11-2008, 07:17 PM
I also just had the Hotchkis leafs put on, the car only has 2800 miles, and the shudder hasn't always been there. Only like the past 2 months.
Vegas69
06-11-2008, 08:16 PM
Let me guess....you lowered the car?
Nessumsar
06-12-2008, 09:24 PM
Yeah, the 1.5" the leafs gave me, but the car doesn't appear to sit much lower. I will check the pinion angle this weekend, and the drive shaft.
