View Full Version : DSE or art morrison?
rubbersdown
05-21-2008, 06:45 PM
What should I get... I hear that DSE makes great parts and I know morrison does also. So here is my dillema. I am either going to go with a stock subframe and a DSE speed kit 3.
OR get a full Art Morrison subframe and front end suspension.
I am not a big fan on DSE's subframe, I do not like hydroformed look or the stamped style crossmembers. This is why I say a DSE speed kit stage 3 or a FULL Art Morrison front end. Is the extra $1500 or so worth the art morrison subframe and c5 suspension? or should I just stick with the stock subframe? I dont race, it is going to be a SEMI-daily driver (couple times a week) and maybe once a month a 200 miletrip up north.
Also, I will more then likely be going with a g bar for the rear but would like to hear your opinions on the g-bar vs. the quadralink.
thanks in advance
Mr.VENGEANCE
05-21-2008, 08:06 PM
well.. im running AM.
but you cant go wrong with either one.. they are the leaders of the game.
andrewb70
05-21-2008, 08:45 PM
.....I dont race, it is going to be a SEMI-daily driver (couple times a week) and maybe once a month a 200 miletrip up north.
Get yourself some stiffer springs, poly bushings, a little bigger sway bar, and do the G-mod. Save yourself a bundle of cash.
BrianP
05-21-2008, 09:25 PM
When I look at the DSE subframe I see strength, durability, torsional stiffess. It's a thing of beauty to me.
dhutton
05-22-2008, 04:25 AM
I chose the AME subframe over the DSE coilover conversion because I didn't want to have to drop the control arm everytime I wanted to adjust the coilovers. I'm sure the system works well but that feature is a PITA.
Don
Fesler built
05-22-2008, 04:31 AM
Don
Agree I dont understand why anyone would want to pull the suspension apart to adjust things, work smarter not harder:pat:
67bird
05-22-2008, 06:32 AM
have you looked at ATS Chicane?
ProdigyCustoms
05-22-2008, 06:56 AM
I do not think the DSE speedkit can fairly be compared to the Corvette suspended, rack and pinion, chassis from AME. Now if you were compareing the DSE frame to the AME frame, that would be a equal comparison and I would be saying you should pick the one that looks the way you want your frame to look, because I believe they are equal in quality and the numbers are there also.
To me, if I were going to spend $4000 to mod a stock subframe, this would be a area where I would bite the bullet and spend up for the complete subframe.
Now if I were just doing some control arms, spindles, steering box, sway bar, steering rebuild kit, Coil springs and shocks, and spending $2500 I would have a different opinion.
It is really mostly about your budget and the theme of the car in general. If you doing a full on mini tub, 4 link, 3 piece wheel, 14" brake, 600HP+, bla, bla, bla, car, you should probably do a subframe or you may be under building this area of the project. If your not mini tubbing, your running 12" brakes and 17" TT2s and a crate 350, your still building a very nice car, but your probably over building this area by doing a high end subframe.
I would say 75% of the calls to our tech line deal with project planning. Trying to find the right combination of parts so as not to over or under build in any area. And more often then not we find people over building some areas and under building other areas.
Again, these are just our opinions, and you know what they say about opinions!
ProdigyCustoms
05-22-2008, 06:58 AM
Duplicate
dhutton
05-22-2008, 12:11 PM
The other reason I chose the AME subframe is because it can save you money if you are also doing an LSx conversion if you can live with the factory accessories and stock F body oil pan. Once you add those savings (aftermarket accessories plus conversion oil pan) to the cost of upgrading a stock subframe you can very quickly get to the price of an AME subframe.
Don
BRIAN
05-22-2008, 12:51 PM
Why would you chose a subframe based on how it looks? Hydroforming is an OEM type proceedure that I am sure costs DSE a fortune. Not that 2x3 rails dont get the job done. Not sure I am understannding you correctly??
Think about all the race cars that ran stock subs with modded parts. At some point the prices do come close and new parts are usually easier to work with.
This is a site about drivers but you are not alone on picking parts on their looks vs performance.
dhutton
05-22-2008, 01:28 PM
I think the point is that AME and DSE subframes are equal in performance so you might as well choose the look you like - hydroformed or fabricated. Some prefer one over the other.
Don
rubbersdown
05-22-2008, 01:47 PM
I understand that, sorry I didnt choose my words very wisely. I mean that I dont like the looks of the hydroformed subframe as in to ME personally the AME looks stronger, im sure the DSE is plenty strong and its all in my head though.
Does the dse use c5 or c6 parts or does DSE use their own geometry and parts with their subframe? I am leaning pretty heavy twords the ame at this point.
I am torn in my engine choice right now between an lsx or a dart block 572. I want around 600RWHP on pump gas so i am leaning twords a 572.
PARKERRS
05-22-2008, 02:11 PM
I wouldn't think that the DSE is weaker in any way compared to the AME, just a different method and appearance. As stated both are pretty much eqaul as far as performance. If you think the DSE isn't tested and durable check out the posts about the Year One Event. Kyle and Stacy drove the car down which is 300 miles, then beat on it at the auto cross and on the Road Atlanta track non stop all weekend to the tune of over 300 miles of 9/10s driving, then drove it back home without a problem. This is real world testing and they have been doing it to the hydro formed frame in this car for more than a year now at all events, seems strong enough for me.
Tommy
vp23271
05-22-2008, 02:35 PM
+1
If you decide to stick with the stock subframe, look into the ATS Chicane mod. A forum member on this site Reboot04 has done the mod and taken a lot of pics. I believe this will give you access to the coil overs to adjust them without having to remove them from the car.
http://www.onelapcamaro.com/
If you go with the Chicane, you might spend close to what the DSE or AME cost once you factor in control arms, spindles and coil overs. So 2x check the numbers and your budget.
The DSE and AME frame are both top notch and you can't go wrong with either one.
2 factors that you might want to consider is weight and how wide of a tire each frame will allow.
XLexusTech
05-22-2008, 03:11 PM
Reading you post without any selfish motive one way of the other the words that stand out to me are "Daily driver" "No racing" and "Looks"
So here are my thoughts if you are going for looks then GO AM and also look @ the Speed-Tech subframe. The look of both of these is great. If you want a daily driver with good performance and ride then dont buy either cause you have no need for them.
rubbersdown
05-22-2008, 03:35 PM
What if I want a good looking daily driver? lol. I personally am more into performance than looks. But the AEM offers both and the c5 suspension is a tried and true setup. remember again I am going to shoot for a little over 600RWHP so it needs to be something that is going to handle good and I know the c5 suspension is up to the task (I happen to get airborn and went through a small brick wall and into a tree at 92mph in a c5 corvette and I think the suspension is all that survived lol, I have pics of the car ill try to find them and post them). I honestly am not worried about the cost as I dont really have any kind of budget per-say but im not looking to throw money away. I am just trying to figure out what is the best setup I can get for what im trying to acomplish... A 600hp daily driver with the suspension to throw it around some corners at speed with no problems. Is that to much to ask? lol probably
hotrdblder
05-22-2008, 04:07 PM
take a look at my chassis, it uses c6 control arms, has custom cnc drop steering arms, custom steering rack, custom tuned bilstein coil overs, and designed by our resident susp master, katz tsubai aka(saltracer) we will have our test car at nashville and columbus goodguys thrashing it as hard as we can, feel free to come out for a ride or drive.kenny davis hot rods is getting one for there chevelle, perfection autosport has one coming for a project and tyler at ats has one coming for a customer project.
goodluck, your project sounds great, any of your choices will fit you well.
jake
ps. for the susp guys
.85 - camber gain per inch of bump
.776 motion ratio
107 instant center
.815 roll center
.010 bumpsteer, bump out
61.5 track width
https://static1.pt-content.com/images/pt/2008/05/IMG_1114-1.jpg
rubbersdown
05-22-2008, 05:13 PM
jake
.776 motion ratio
107 instant center
.815 roll center
61.5 track width
your chassis looks pretty nice, I saw your website as well. Does your website price include the shocks and spindles? also, does the chassis have all tabs to mount bumpers, fenders, and all that type of stock stuff?
silver69camaro
05-23-2008, 07:04 AM
Here we go...
2x4 actually. Assuming you were referring to our subframe.
I agree 100%. Our subframes are so similar in performance, nobody here would be able to tell the difference.
Neither of us use stock geometry. We (AME) chose to use the stock forged aluminum LCA and UCAs, DSE decided to make their own. Both AME and DSE have modified geometry.
Correct. See, the stock subframe is pretty good. People throw words out like "torsional stiffness" and "flimsy" when referring to the stock subframe. Actually, it's quite stiff for what it is. There are two problem areas:
1. Excess weight - the stock subframe could be made lighter while maintaining the stock stiffness. That was my goal and I acheived it by shaving close to 40lbs off. I'm sure DSE's is lighter as well.
2. Geometry - Every subframe, aftermarket or not, will suffer from the fact that the two rear legs of the subframe are hangin' out in space...flimsy as can be. You can't get around that. So are we really gaining anything by buying a "stiffer" subframe? No, because the ONLY benefits you can gain are by using subframe connectors or some front end bracing (and don't just stick some tube from the radiator support to the firewall, you need a full cage).
Actually, both DSE and AME subframes allow a 275mm tire on a 10" rim. I'm not sure about the weight difference, but I bet it's close.
Anyway, these threads are always a good and bad thing. Good because they bring up the discussion and techinical thinking about theory and overall performance benifits; bad because very few people who actually have seat time in a car equipped with any aftermarket subframe at all. Also, the few actual high-performance subframes out there today are so close in performance it's rediculous, and spending hours and hours on end comparing RCs and camber gains makes no sense. Choosing a different tire compound will result in a larger difference in handling.
So what's the answer? IMO, go with your gut feeling. You can't go wrong.
rubbersdown
05-23-2008, 07:25 AM
Thanks for the info silver69. Honestly my gut feeling tells me to go with AME and thats more then likely what im going to do.
I am going to go with a completely shaved firewall, so do u think I should add some bars from the firewall to the front of the subframe, like the pic of hotrdblder's car up above? and sub-frame connectors?
silver69camaro
05-23-2008, 08:01 AM
No, I would not add the firewall downtubes unless if you are using a 10 or 12-point cage. The additional stiffness you gain is not worth the hassle as these bars will be in the way of brake MC, header installation, etc. A good setup for road and track would be a 6-point and subframe connectors, with the roofline bars attached to the subframe.
Subframe connectors? Always!
rubbersdown
05-23-2008, 08:10 AM
sounds good, I was planing on doing subframe connectors no matter what but I am still trying to decide if i am going to do a cage or not. Does anyone make a pre-built cage that has a removable crossbar and VERRY low-slung door bars? I am not racing this car so i dont need anything nhra approved or anything, just looking to stiffen the chassis. If not I guess I could just buy a 6pt kit with a removable cross bar and build my own door bars to fit my needs. I just need something that wont make it difficult for me to get in and out of my car as my back and knees are bad enough already.
hotrdblder
05-23-2008, 08:11 AM
yes price includes non adjustable tuned bilstein coil overs, mounting holes for rad support, bumper brackets, as well as your choice of engine mounts placed correctly so you do not need to buy 150-200 dollar adapter mounts,like the others sell. included splined sway bar also, with all susp parts, ready to bolt in, all you need is brakes and steering shaft.
hotrdblder
05-23-2008, 08:15 AM
I offer a pre bent 10 point cage, my down bars tie into the forward down bars, which go down thru the dash from the halo bar, i will post pics of clearances. Also i just run a rocker bar if your not going to run an approved door bar you will get little help from it.
I disagree, bolt on forward down bars, placed at cowl seem WILL help alot.
good luck with your choice, if your serious about performance look my way.
silver69camaro
05-23-2008, 08:36 AM
Keep in mind those adapters let you change your engine from an LS engine to BBC or SBC on a whim. If you have them set for an LS, you're stuck with that forever (unless if you cut the mounts off and relocate). Adapters aren't a bad thing, the flexability is nice to have.
I didn't say they wouldn't help, because they will...I said, in my opinion, they aren't worth the hassle when trying to replace MCs or set up steering shafts. They can be a pain! But hey, everything has an upside and a downside. But really, bolt-on downtubes wouldn't be a bad idea provided the bolt holes don't elongate over time like bolt on SFCs do. Might be something to try in the future.
hotrdblder
05-23-2008, 08:59 AM
agreed, i use different style mount and i can install mounts at sbc/bbc placement for ls-1s also.
i also can change my m/c with ease.
rubbersdown, goodluck with your build any of the mentioned frames would do you good.
XLexusTech
05-23-2008, 12:35 PM
Would love to see pics of a nice cage. I have been looing for one that hous the a piller and goes trhough the dash further forward then they run of the mill Pre fab one available
Corinthian
05-27-2008, 11:31 AM
On the topic of engines in AME's sub is there any relocation from stock? I believe I read that your Max-G chassis moved the engine rearward and down, I'm wondering if that is also the case with the sub.
silver69camaro
05-28-2008, 04:58 AM
Actually, our Max-G unibody platform has no engine mounts, so that's up to the builder. Obviously I recommend the engine placed as far back as possible.
With our F-body clip, the engine is moved slightly foward to make more room for HEI distributors. Otherwise it's stock and the slight foward movement makes no difference in weight distribution.
billybobdupree
06-04-2008, 03:30 AM
I am using a LS1 in my 1st gen. With the use of your mounts, can you tell me what the distance is from the rear of the head, (on the passenger side), to the firewall. I am currently using a factory sub and have the engine mounted at 1'' from the firewall (passenger side head). Also, are the AM exhaust header's a must with use of your frame? (Asking because I recently purchased new Stainless Works.)
dhutton
06-04-2008, 04:40 AM
I recently tried a set of SW headers on my AME clip for someone, not sure what the part number was. They fit more or less OK but they did not line up with the exhaust cutout in the trans crossmember. There was also clearance issues with the O2 sensor if I recall correctly.
Don
silver69camaro
06-04-2008, 05:16 AM
Our frame also puts the LS engine about 1" from the firewall as well. It's just enough clearance to snake wires behind the motor for a clean look.
Looks like Don answered your question on the headers. We always recommend our own headers, they make life very simple!
