    Results 1 to 3 of 3
      Chicago suburbs
      TH350 cooler lines
      Which fitting at the trans is the output side for the cooler? I forgot to check while the car was running. In other words, does the fluid at the trans go out the top and in the bottom or vise versa?
      The bottom line on the transmission your output and the top line on the transmission is your return line from the cooler.
      Mark
      Bowler Performance Transmissions
      www.bowlertransmissions.com
      Chicago suburbs
      Thanks, MarkB
