View Full Version : How do you get cruise control with cable throttle?
merriman44
05-21-2008, 09:47 AM
Finally getting the funds to finish up the ls2 and begin reassembling the 69 camaro. I would like to use the cable throttle route but only if I can eventually add cruise control. Any thoughts?
WS6
05-21-2008, 05:45 PM
The engine management is designed to work with a throttle by wire TB. Also, all Gen 4 motors are throttle by wire. Why go through the trouble of changing it back? The cost of the correct pedal is most likely similar to an after market cruise control unit. Dakota Digital makes one and it's designed to be cable operated.
greygoose006
05-21-2008, 05:56 PM
if you mean like the way they did it in the carb days, the cruise was run off engine vacuum which pulled the throttle cable
merriman44
05-22-2008, 07:02 AM
I just mean for the gen III engines. my car was a 6 cyinder so i have the pedal and linkage
Shawn MacAnanny
05-25-2008, 05:19 PM
ok I'm on the same boat, i think. I have 6 cylinder gas pedal, carb throttle cable, carb LS1 engine, and want cruise as well, what's available?
BonzoHansen
05-25-2008, 05:47 PM
I'm with you - I have the whole cruise assem. out of a 99 Z, but I'd rather run DBW, it would all be so much cleaner. I haven't looked yet if I can convert the LS1 I have to DBW, I haven't gotten that far in the research yet.
72NovaSS
05-26-2008, 10:16 AM
Why do cruise control...I mean WOT and your foot mashed to the floor isnt that bad right?
merriman44
05-27-2008, 06:17 AM
No but this will be a semi daily driver. May take it as far as tennessee from Ohio. This thing is meant to be driven.
Bonzo all you need is the right harness and ecu and a DBW throttle body.
