View Full Version : Power brake booster?
FMG CAMARO
05-18-2008, 02:25 PM
I am looking to add a power brake booster to my 1968 camaro. How involved is it? Can I add a booster to my existing master cylinder or do I need a new setup? If I can add one do l need to disconnect brake lines and bleed the system? Also do I have to touch the proportioning valve? Just trying to save a few bucks and do i myself. thanks for the help in advance!
FRANK
jackfrost
05-19-2008, 06:30 AM
the master will be different for power vs. manual, so you will need to swap it out. bench bleed the new master, then you will need to bleed the entire system w/ the new master installed. start at the RR, then LR, then RF, then LF.
