View Full Version : Project: SCHEVY 2001 Silverado
GMracer
05-13-2008, 10:25 AM
Well I've been lurking this site for a while now, and figured I would share my project, as long as it's cool with you guys. I know it's not a pro-touring car, but the plans for this thing is a mean street machine, that can handle well and put it's fair share of power down on the pavement.
April 2007 was the last time I took a bunch of pictures of it, this being two of them.
https://static1.pt-content.com/images/pt/2008/02/April22_2007042-1.jpg
https://static1.pt-content.com/images/pt/2008/02/bg3-1.jpg
July came and after having the trans built the August before I had it blow on me 3 times, all the builder told me were they were bad parts, never got a chance to push the truck much, and was told the trans would hold more than I was asking for, well after the third time I convinced myself I would be careful till I could afford to order a level 5 80e or something similar. Well with my luck it blew again, no reason what so ever I was just on my way to work and it locked up. When the fluid was cold it would move, heated up and it would go anyway. So it went back in my garage, and I convinced myself, not so much my friends, that I was going to tear it completly down and build it frame up.
The plans as of right now, a basic over veiw:
2001 Silverado 2wd regular cab shortbed
Rolling Chassis
- To be designed and fabricated by myself
- Factory suspension moved upwards to accommodate lower ride height
- Motor moved back and up to transfer weight and clear steering
- McGaughys Spindles, RideTech Control arms, and double adjustable shockwaves, Muscle Bar up front
- F9100s, double adjustable billet shocks, Satchell adjustable 4-link out back
- GM 14bolt 9.5” SF narrowed rearend
- Converted to 5x5 Lug Pattern
- Powder coated Hammered Black Satin finish, all components gloss black
- Custom Fuel Cell Behind rear end
- All fuel, air, and brake lines to be hard stainless, with braided to moving parts
- Intro Wheels GT Sports 20x8.5 Front w/ Toyo Proxy STII 275/40/R20
- Intro Wheels GT Sports 20x15 Rear w/ MT Sportsman SR 29x18x20
- Wilwood 16” Front Rotors 6 piston calipers
- Wilwood 14” Rear Rotors 4 piston calipers
- GM HD Hydroboost Brake System
Exterior
- Water based True Black w/ blue toner
- Ceramic Clear Coat (same as new Mercedes)
- Body dropped bed 5.5” to hide all suspension components and appear “stock”
- Stock Wheel tubs widened to accommodate 20x15s, again to appear “stock”
- Rear tailgate will close and open to appear "stock"
- Shaved tailgate, license plate, candied and smoked tail lights
- Exhaust tips through the roll pan to mimic the front bumper
- Escalade Handles
- Cal-Vu Mirrors
- Front bumper is a modified SS bumper
- Hood will be raised across the whole back
- Xenarc Headlights with 4300k HIDs
- Clear Marker Lenses
Interior
- All plastic panels will be dyed black, factory satin finish.
- Escalade top dash pad, wood grain on passenger side to be painted black, and “Cadillac” replaced by “SCHEVY”
- Escalade Dash Bezel
- 03 Console w/ T56 shifter while retaining cup holders.
- Black headliner, and visors to match
- Black Carpeting
- Modified Stock Bucket seats, reworked into more of a “race bucket”
- Denali Gauges, all interior dash lights to be orange (only color on whole truck, while the rest is black and billet)
- Sounds system is TBA, but amp will be hidden along with two 10”shallow mount subwoofers behind each seat.
Drivetrain
- 402 CI LQ4 Specs TBA Est. HP 750rwhp
- Custom Turbo Kit by TurboDan Single S85mm all stainless tubular headers, complete one off kit.
- T56 6 Speed Transmission
- 4.88 gears w/ Detroit Locker in the 14-bolt
- Exact Specs TBA on complete drivetrain
https://static1.pt-content.com/images/pt/2008/05/CIMG1826-1.jpg
https://static1.pt-content.com/images/pt/2008/05/CIMG1833-1.jpg
https://static1.pt-content.com/images/pt/2008/05/CIMG1835-1.jpg
https://static1.pt-content.com/images/pt/2008/05/CIMG1838-1.jpg
Originally I modified the stock frame, and finished it besides my shock mounts
https://static1.pt-content.com/images/pt/2008/05/IMG_2896-1.jpg
https://static1.pt-content.com/images/pt/2008/02/IMG_2897-1.jpg
https://static1.pt-content.com/images/pt/2008/02/IMG_2892-1.jpg
https://static1.pt-content.com/images/pt/2008/02/IMG_2894-1.jpg
https://static1.pt-content.com/images/pt/2008/05/IMG_2893-1.jpg
GMracer
05-13-2008, 10:28 AM
But then I decided I'd rather build my own frame, so I built a table
https://static1.pt-content.com/images/pt/2008/05/HPIM0192-1.jpg
Threw this frame on it
https://static1.pt-content.com/images/pt/2008/05/HPIM0195-1.jpg
Jigged everything I needed
https://static1.pt-content.com/images/pt/2008/05/HPIM0198-1.jpg
https://static1.pt-content.com/images/pt/2008/05/HPIM0207-1.jpg
https://static1.pt-content.com/images/pt/2008/05/HPIM02641-1.jpg
Ordered some custom spec rails from AutoWeld
https://static1.pt-content.com/images/pt/2008/05/HPIM02511-1.jpg
Starting to lay them out
https://static1.pt-content.com/images/pt/2008/05/HPIM0260-1.jpg
Here you can see how the stock hyrdoformed frame compound bends in, so I needed to mimic that
https://static1.pt-content.com/images/pt/2008/05/HPIM0256-1.jpg
Marked the angles
https://static1.pt-content.com/images/pt/2008/05/HPIM0266-1.jpg
https://static1.pt-content.com/images/pt/2008/05/HPIM0268-1.jpg
Cut
https://static1.pt-content.com/images/pt/2008/05/HPIM02711-1.jpg
Clamped into place and double checked everything
https://static1.pt-content.com/images/pt/2008/05/HPIM0272-1.jpg
GMracer
05-13-2008, 10:37 AM
https://static1.pt-content.com/images/pt/2008/05/HPIM0275-1.jpg
https://static1.pt-content.com/images/pt/2008/05/HPIM0278-1.jpg
https://static1.pt-content.com/images/pt/2008/05/HPIM0284-1.jpg
Welded the seams up
https://static1.pt-content.com/images/pt/2008/05/HPIM02871-1.jpg
Then I used the same method to tie in the rail rails since they were 10" closer together than the mid section
https://static1.pt-content.com/images/pt/2008/05/HPIM0361-1.jpg
Cut and Bevel
https://static1.pt-content.com/images/pt/2008/05/HPIM0374-1.jpg
Weld and then mark them for final fitment
https://static1.pt-content.com/images/pt/2008/05/HPIM0378-1.jpg
Clamping up and getting ready for final fitment
https://static1.pt-content.com/images/pt/2008/05/HPIM0379-1.jpg
Both sides complete and welded up as one piece
https://static1.pt-content.com/images/pt/2008/05/HPIM0365-1.jpg
Had to smooth the welds on the inside before I put them together otherwise I would never have got them smooth
https://static1.pt-content.com/images/pt/2008/05/HPIM0367-1.jpg
These welds were tight enough to do, never mind a grinder
https://static1.pt-content.com/images/pt/2008/05/HPIM0368-1.jpg
GMracer
05-13-2008, 10:41 AM
Starting on the next side, also explains how I strengthened those seams, and kept it hidden
Since I did the other side completely and got it right I knew where everything had to be cut and drilled
https://static1.pt-content.com/images/pt/2008/05/HPIM03671-1.jpg
Drilled the plug weld holes
https://static1.pt-content.com/images/pt/2008/05/HPIM0371-1.jpg
https://static1.pt-content.com/images/pt/2008/05/HPIM0375-1.jpg
https://static1.pt-content.com/images/pt/2008/05/HPIM0376-1.jpg
Made some plates, 3/16"
https://static1.pt-content.com/images/pt/2008/05/HPIM03791-1.jpg
https://static1.pt-content.com/images/pt/2008/05/HPIM03801-1.jpg
Welded them in on one side
https://static1.pt-content.com/images/pt/2008/05/HPIM03811-1.jpg
Slide them together clamped everything up nice and tight
https://static1.pt-content.com/images/pt/2008/05/HPIM03831-1.jpg
https://static1.pt-content.com/images/pt/2008/05/HPIM03891-1.jpg
https://static1.pt-content.com/images/pt/2008/05/HPIM0397-1.jpg
Once everything was good, I layed the rail flat, clamped and welded the seam
https://static1.pt-content.com/images/pt/2008/05/HPIM0399-1.jpg
https://static1.pt-content.com/images/pt/2008/05/HPIM0400-1.jpg
GMracer
05-13-2008, 10:44 AM
Once the cooled I needed to grind this one smooth also
https://static1.pt-content.com/images/pt/2008/05/HPIM0403-1.jpg
Everything was set just need to get the final welds in this weekend, due to being in school till tomorrow then I got the summer off.
https://static1.pt-content.com/images/pt/2008/05/HPIM0409-1.jpg
https://static1.pt-content.com/images/pt/2008/05/HPIM0407-1.jpg
I also cut the rear frame rails down 4" I was going to run them higher but decided against it, so I plated them the same way.
https://static1.pt-content.com/images/pt/2008/05/HPIM0363-1.jpg
https://static1.pt-content.com/images/pt/2008/05/HPIM0364-1.jpg
Also once I get my 2" Spindles in I will be able to layout the front suspension and order my laser cut brackets for that. Also got to send out my 14b to have it narrowed in a week or so. Sucked that I had to cut off all those brackets I welded up already. Oh well, plans change.
robbie_92835
05-13-2008, 02:09 PM
I cant wait to see more progress pics.
Code Red
05-13-2008, 03:34 PM
wow very nice work and those wheels look famaliar ;) (i have them on my colorado)
GMracer
05-13-2008, 04:00 PM
Yea, you're on a couple other boards I'm on, I actually just sold them though. Thanks for compliments!
Code Red
05-13-2008, 04:29 PM
welcome
what other boards?
GMracer
05-13-2008, 04:30 PM
I know you're on the Fiberglass Forums, I don't know what else I've seen you on, ShowTruckScene? I don't know I'm on too many of them haha
Code Red
05-13-2008, 04:47 PM
I havent been on fgf in awhile course havent done much fiberglassing in a while
trackrat79
05-13-2008, 11:05 PM
Very cool, wish I had the money and time to do my chassi now. That and I need to get something else to drive before I tear my truck apart.
Was it expensive having custome rails made. I thought that there were companies out there that did it but scared of the cost never really looked into it.
GMracer
05-14-2008, 04:10 AM
I think it was about 1100 shipped for custom spec rails
6'9"Witha69
05-14-2008, 09:00 AM
Too cool bro. Have you plotted out the susp pickups and analyzed the info?
GMracer
05-14-2008, 10:59 AM
plotted out the susp pickups? did you mean the trucks suspension?
with my spindles and the control arms setup where I plan to, the rollcenter will be about 1" above the ground, going to run 4-5* of caster, all the pivots (arms and steering are stock location) which helps with clearances and such. Out back, I haven't plotted out how I'm going to setup the bars, whatever fits basically, and I will set my IC right above the front bumper.
I don't have a program or anything to do the plotting, and since it is a street car, and I don't have the ability to weigh and get perfect calculations I will leave enough adjust ability to go from there. Like I said though it's not going to be a strict track truck, so with what I plan I think it will work ideal for my plans.
Any tips or suggestions are welcome, I'm open to trying new methods.
Nessumsar
05-14-2008, 07:29 PM
That it awesome man! Wish I had a shop at my disposal, oh the possibilities! Love the power slide picture as well, very sweet.
01somta
05-14-2008, 07:43 PM
I am in LOVE!!!
GBodyGMachine
05-15-2008, 07:17 AM
This is sweet. Do you post on FSC? If not you should!
GMracer
05-15-2008, 09:04 AM
Not on FSC, I'm on GMFS though.
796spdbu
05-16-2008, 09:41 PM
what sites are these you speak of..fsc and the others..what the address' of you dot mind. what kinda rear suspension you going to us? Thanks.
GMracer
05-17-2008, 10:36 AM
www.gmfullsize.com/forum
Just a GM Truck site, not a tech as this site
Triangulated four link, I mention that info up top.
GMracer
07-14-2008, 01:09 PM
Well haven't updated due to me forgetting the camera, but I've been working on mainly figuring out my front suspension I wanted to make it perfect at ride height, and finally after moving everything upwards, motor 1.5" up i got my arms at 2* LCA and the uppers at 6* this is set at 5.5" ride height. Tire will sit right at the lip of the front tires.
So with that figured out, I started the front crossmember
crazy cuts to make it fit
https://static1.pt-content.com/images/pt/2008/07/HPIM0587-1.jpg
https://static1.pt-content.com/images/pt/2008/07/HPIM0588-1.jpg
https://static1.pt-content.com/images/pt/2008/07/HPIM0589-1.jpg
https://static1.pt-content.com/images/pt/2008/07/HPIM0597-1.jpg
Made sure the tierods would be clear, at full turn they hit so I will make a small round notch
https://static1.pt-content.com/images/pt/2008/07/HPIM0600-1.jpg
Tac'd
https://static1.pt-content.com/images/pt/2008/07/HPIM0601-1.jpg
https://static1.pt-content.com/images/pt/2008/07/HPIM0603-1.jpg
https://static1.pt-content.com/images/pt/2008/07/HPIM0605-1.jpg
At final position
https://static1.pt-content.com/images/pt/2008/07/HPIM0606-1.jpg
https://static1.pt-content.com/images/pt/2008/07/HPIM0607-1.jpg
https://static1.pt-content.com/images/pt/2008/07/HPIM0608-1.jpg
https://static1.pt-content.com/images/pt/2008/07/HPIM0609-1.jpg
GMracer
07-14-2008, 01:10 PM
Centered the rack up, took some measurements
https://static1.pt-content.com/images/pt/2008/07/HPIM0610-1.jpg
https://static1.pt-content.com/images/pt/2008/07/HPIM0611-1.jpg
Check out those arm angles, perfect!
https://static1.pt-content.com/images/pt/2008/07/HPIM0616-1.jpg
https://static1.pt-content.com/images/pt/2008/07/HPIM0619-1.jpg
https://static1.pt-content.com/images/pt/2008/07/HPIM0621-1.jpg
https://static1.pt-content.com/images/pt/2008/07/HPIM0622-1.jpg
Got the steering mocked up
https://static1.pt-content.com/images/pt/2008/07/HPIM0624-1.jpg
https://static1.pt-content.com/images/pt/2008/07/HPIM0626-1.jpg
https://static1.pt-content.com/images/pt/2008/07/HPIM0633-1.jpg
https://static1.pt-content.com/images/pt/2008/07/HPIM0636-1.jpg
GMracer
and some more pictures...
Check out this, the body bout doesn't have much room to weld to so I could do a plate angle up on one side and the other going down, but I hate that look
https://static1.pt-content.com/images/pt/2008/07/HPIM0537-1.jpg
https://static1.pt-content.com/images/pt/2008/07/HPIM0538-1.jpg
so why not make it look factory
https://static1.pt-content.com/images/pt/2008/07/HPIM0540-1.jpg
all done.... :crazy:
https://static1.pt-content.com/images/pt/2008/07/HPIM0541-1.jpg
Cut some steel
https://static1.pt-content.com/images/pt/2008/07/HPIM0543-1.jpg
https://static1.pt-content.com/images/pt/2008/07/HPIM0544-1.jpg
https://static1.pt-content.com/images/pt/2008/07/HPIM0546-1.jpg
https://static1.pt-content.com/images/pt/2008/07/HPIM0547-1.jpg
Welded up and smoothed out, the 2" hole will be drilled later
https://static1.pt-content.com/images/pt/2008/07/HPIM0550-1.jpg
https://static1.pt-content.com/images/pt/2008/07/HPIM0553-1.jpg
https://static1.pt-content.com/images/pt/2008/07/HPIM0555-1.jpg
https://static1.pt-content.com/images/pt/2008/07/HPIM0556-1.jpg
GMracer
07-14-2008, 01:11 PM
had a few extra hands...
https://static1.pt-content.com/images/pt/2008/07/methree-1.jpg
haha not, I wish though.
So I continued with that crossmember, made stock styled rack mounts.
https://static1.pt-content.com/images/pt/2008/07/HPIM0641-1.jpg
https://static1.pt-content.com/images/pt/2008/07/HPIM0651-1.jpg
Going to cut down some of the excess on the opposite side
https://static1.pt-content.com/images/pt/2008/07/HPIM0655-1.jpg
Beveled edges and a nice solid bead
https://static1.pt-content.com/images/pt/2008/07/HPIM0658-1.jpg
Back on the frame
https://static1.pt-content.com/images/pt/2008/07/HPIM0660-1.jpg
Temporary bolts holding it in place
https://static1.pt-content.com/images/pt/2008/07/HPIM0662-1.jpg
Lower control arm mounts, I was going to have them laser cut, but seemed like a waste of money and time for what I will need
https://static1.pt-content.com/images/pt/2008/07/HPIM0671-1.jpg
https://static1.pt-content.com/images/pt/2008/07/HPIM0672-1.jpg
https://static1.pt-content.com/images/pt/2008/07/HPIM0677-1.jpg
https://static1.pt-content.com/images/pt/2008/07/HPIM0676-1.jpg
Code Red
07-14-2008, 01:51 PM
awesome man
nice pic with the 3 of you lol
I did a similar shot for a friend and his truck
linkstar69
07-14-2008, 04:38 PM
Love it, great to see you jump in with both feet. Should be an awsome truck when you're finished
Bishop73
07-14-2008, 04:45 PM
Great build thread. Did you post some of this over on GMFS? I'm over there and I thought your table you made looked familiar.
GMracer
07-14-2008, 05:08 PM
yep Im on GMFS, thanks guys!
jackfrost
07-15-2008, 08:56 AM
wow, that is impressive. keep it up.
GMracer
07-15-2008, 06:22 PM
started the second crossmember (under the oilpan)
https://static1.pt-content.com/images/pt/2008/07/HPIM0692-1.jpg
this is going to mount the back of the LCA and then the motor mounts ontop, the middle of the crossmember will be bolted in similar to factory setup.
https://static1.pt-content.com/images/pt/2008/07/HPIM0694-1.jpg
https://static1.pt-content.com/images/pt/2008/07/HPIM0695-1.jpg
https://static1.pt-content.com/images/pt/2008/07/HPIM0696-1.jpg
Cut some brackets for the LCAs
https://static1.pt-content.com/images/pt/2008/07/HPIM0699-1.jpg
https://static1.pt-content.com/images/pt/2008/07/HPIM0700-1.jpg
https://static1.pt-content.com/images/pt/2008/07/HPIM0701-1.jpg
https://static1.pt-content.com/images/pt/2008/07/HPIM0702-1.jpg
https://static1.pt-content.com/images/pt/2008/07/HPIM0703-1.jpg
Got a lot done tonight even though it doesn't look it, I still work from 730-430 then do this till 930
796spdbu
07-16-2008, 10:32 AM
I must have over looked the rear suspension design, I went back and reread your specs and seen it. Great fab work! cant wait to see it finished!:cool:
GMracer
07-16-2008, 05:49 PM
yea, I plan to run a triangulated 4link out back. Satchell possibly, we will see what space allows for.
jerome
07-16-2008, 07:14 PM
great progress, this is gonna turn out awesome. I know what you mean when you say its a lot of work, but pics don't show much progress. You spend all afternoon cutting and fitting a piece, spend forever positioning it, put on your welding helmet to tack it, and the clamp falls off. Keep on truckin'
LMDGUY
07-16-2008, 07:46 PM
way cool project..I will follow along
GMracer
07-17-2008, 03:43 PM
thanks guys!
Kingsize
07-24-2008, 10:40 PM
Awesome thread, I can't wait to see it when you are done!
Idle Clip>>> http://www.youtube.com/watch?v=s2rKmw2DDZY
500rwhp Dyno Pull>>> http://www.youtube.com/watch?v=z21MepuHe2g
www.fquick.com/Kingsize
http://www.myspace.com/kingsize007
Memphis
07-25-2008, 12:15 AM
Damn that is awesome. I really need to get a book on metal fab everytime I see something like this I want to do it myself.
orbit
07-25-2008, 07:41 AM
I've been reading this thread all along and have to say... I am jelous!!!:hammer:
I have a 90 454SS that would be such a great canidate for this type of build. But!!!!! I do not know how to weld, let alone make the measurements accurately, :nopity: and I do not want a Frankenstein truck.
Keep the pix and explanations coming!
Black-Jacket
07-26-2008, 12:40 PM
looks good nick, easier for me to view the pics in this thread than sift throught the other
Chirp08
07-26-2008, 01:18 PM
I would love to be able to tackle a project like this, very nice work man. It feels good when you fab up the littlest things on these cars, I can't imagine how awesome it must feel to do the whole frame. I can't wait to see the final truck.
Banks08
07-27-2008, 06:59 PM
Very nice so far. I wish i had the cash and the skils to fab an entire frame. I want to build my 88 chevy like that. I have to learn to work with metal so i can save some dough and fab stuff.
slmd95s10
08-20-2008, 08:47 AM
any updates on this project? this is awesome!!
GMracer
08-26-2008, 06:28 PM
Bout time I update, ordered some brackets through SD so I was waiting on those... got a call and they told me they shipped my custom cut duck heads, I was confused, but then soon realized that they do resemble a ducks head :crazy: Here they are
https://static1.pt-content.com/images/pt/2008/08/HPIM0846-1.jpg
https://static1.pt-content.com/images/pt/2008/08/HPIM0847-1.jpg
Upper control arm frame mounts to be exact, with stock alignment adjustment.
First took care of the rear crossmember, doubles as a bed mount, however I'm considering a tilt bed, not to be a show off, more so for ease of maintenance and such
https://static1.pt-content.com/images/pt/2008/08/HPIM0835-1.jpg
https://static1.pt-content.com/images/pt/2008/08/HPIM0840-1.jpg
Then got the rear cab mount done... wish I would have planned the frame a little more I don't love the fact it's so long, but that's what happens when you do the first one, you learn as you go
https://static1.pt-content.com/images/pt/2008/08/HPIM0843-1.jpg
https://static1.pt-content.com/images/pt/2008/08/HPIM0844-1.jpg
https://static1.pt-content.com/images/pt/2008/08/HPIM0845-1.jpg
Then I wanted to finish the front suspension so I waited to do the last cab mount till later
Mocked them up
https://static1.pt-content.com/images/pt/2008/08/HPIM0848-1.jpg
https://static1.pt-content.com/images/pt/2008/08/HPIM0852-1.jpg
Needed to add the alignment pin
https://static1.pt-content.com/images/pt/2008/08/HPIM0855-1.jpg
GMracer
08-26-2008, 06:29 PM
All pin installed welded and smoothed
https://static1.pt-content.com/images/pt/2008/08/HPIM0856-1.jpg
https://static1.pt-content.com/images/pt/2008/08/HPIM0857-1.jpg
https://static1.pt-content.com/images/pt/2008/08/HPIM0858-1.jpg
All welded up
https://static1.pt-content.com/images/pt/2008/08/HPIM0864-1.jpg
https://static1.pt-content.com/images/pt/2008/08/HPIM0865-1.jpg
https://static1.pt-content.com/images/pt/2008/08/HPIM0866-1.jpg
https://static1.pt-content.com/images/pt/2008/08/HPIM0867-1.jpg
https://static1.pt-content.com/images/pt/2008/08/HPIM0868-1.jpg
https://static1.pt-content.com/images/pt/2008/08/HPIM0871-1.jpg
Finally the core support mounts, wanted to retain a factory design
https://static1.pt-content.com/images/pt/2008/08/HPIM0874-1.jpg
That's it for now, I'm looking for a T56 atleast the case so I can finish the last of the crossmembers, having trouble finding one for cheap.
GBodyGMachine
08-27-2008, 07:23 AM
So Awesome
linkstar69
08-27-2008, 07:12 PM
[/quote]
Judging by the amount of work you've put into your build you've got the right to show off a little bit.
Top stuff man.
GMracer
08-27-2008, 07:21 PM
thanks man, I'm just saying I wouldn't park it at a show with it up all the time, if I want to show them how it's setup unlatch and lift. Makes sense too, I'm just worried about the high pivot and it hitting the cab, I will have to work it out somehow
Idragmazda
09-03-2008, 05:27 AM
Looks good man, I think i saw your build on dropndrag I think.
good luck with the rest of it!
GMracer
09-03-2008, 07:09 PM
yea it's on dropndrag, thanks guys!
I'm in need of a ls t56 asap to get the frame done
Motown 454
09-03-2008, 09:19 PM
looks good nice work
bonecrrusher
10-14-2008, 03:40 PM
Any update on this?
GMracer
10-16-2008, 05:42 AM
Should be working on it this weekend, I picked up a t56 finally, been working a lot to save for my wheels, and going to school so little time. I hope to get some updates this weekend though
GMracer
10-20-2008, 12:12 PM
Grabbed my 4.8 to use for mockup
https://static1.pt-content.com/images/pt/2008/10/HPIM1139-1.jpg
https://static1.pt-content.com/images/pt/2008/10/HPIM1143-1.jpg
Cut and drilled some plates to mount to the engine for the engine side of the mount
https://static1.pt-content.com/images/pt/2008/10/HPIM1153-1.jpg
https://static1.pt-content.com/images/pt/2008/10/HPIM1157-1.jpg
Started to cut the tubing for the frame side of the mounts, and notching it
https://static1.pt-content.com/images/pt/2008/10/HPIM1161-1.jpg
https://static1.pt-content.com/images/pt/2008/10/HPIM1165-1.jpg
Laid them out, trimmed where needed and tac'd them in place
https://static1.pt-content.com/images/pt/2008/10/HPIM1167-1.jpg
https://static1.pt-content.com/images/pt/2008/10/HPIM1168-1.jpg
All set and ready to go
https://static1.pt-content.com/images/pt/2008/10/HPIM1187-1.jpg
https://static1.pt-content.com/images/pt/2008/10/HPIM1188-1.jpg
Welded up the motor plates solid, ran the piece across to prevent movement in the spacing
https://static1.pt-content.com/images/pt/2008/10/HPIM1189-1.jpg
https://static1.pt-content.com/images/pt/2008/10/HPIM1193-1.jpg
GMracer
10-20-2008, 12:13 PM
https://static1.pt-content.com/images/pt/2008/10/HPIM1196-1.jpg
I plan to gusset between the two plates and on the sides before I powdercoat them
Since everything was tac'd I yanked the motor with my new motor hoist, bout time I bought one, I was sick of borrowing tools, "ask to borrow once, that's fine, twice, you should think about buying one, three times don't even ask"
https://static1.pt-content.com/images/pt/2008/10/HPIM1200-1.jpg
Welded the mounts up solid
https://static1.pt-content.com/images/pt/2008/10/HPIM1201-1.jpg
https://static1.pt-content.com/images/pt/2008/10/HPIM1203-1.jpg
https://static1.pt-content.com/images/pt/2008/10/HPIM1204-1.jpg
https://static1.pt-content.com/images/pt/2008/10/HPIM1205-1.jpg
https://static1.pt-content.com/images/pt/2008/10/HPIM1206-1.jpg
Put the motor plates back on
https://static1.pt-content.com/images/pt/2008/10/HPIM1213-1.jpg
Put the bushings back in
https://static1.pt-content.com/images/pt/2008/10/HPIM1216-1.jpg
This is my temporary trans x-member set at the right height an all, just ran out of material for my permanent one, the motor sits so the tailshaft is at a downward slope of 3*
https://static1.pt-content.com/images/pt/2008/10/HPIM1214-1.jpg
Bombed the 4.8 to look better in pics :crazy: and put it back in for the week
https://static1.pt-content.com/images/pt/2008/10/HPIM1218-1.jpg
https://static1.pt-content.com/images/pt/2008/10/HPIM1219-1.jpg
The motor was moved up slightly 1.5" and back about 1" I wanted to get it lower back couldn't do so without compromising too much. This should be fine though.
bonecrrusher
10-20-2008, 05:04 PM
Thats badass, is the T56 going to clear the Silverado cab? You going to have to bang up the tranny tunnel?
GMracer
10-20-2008, 05:50 PM
I'm not too worried about the trans tunnel, the whole motor was moved since I relocated all my suspension also I am body dropping the cab so I planned on cutting the tunnel out before I even put the cab over the trans, since I know it's going to need to be clearanced.
GMracer
11-13-2008, 06:40 AM
So I finally came up with a good setup I believe, and all I have to do is lower the top bar 1" and 100% AS with 2* Understeer for the strip.
hows it look to you guys?
https://static1.pt-content.com/images/pt/2008/11/FINALRrearsusp-1.jpg
if I make it 18 5/8" on the frame end it bring it to roll understeer and still 0* just figured I'd mention that, while putting the AS at 80%
Throttle
11-13-2008, 07:02 AM
Damn Man, you have some a long way from asking me what drop I have on my truck.. :D Looks Awsome..
This is SierraSport from GMFS by the way..
Idragmazda
11-13-2008, 08:31 AM
Chassis is looking great btw. But one question I have (because I am in the process of developing a new suspenion for a chassis for an s10), what did you use to determine the center of gravity height?
The truck I'm workin on is completely dis-assembled, I have no way of measuring the COG. Any input would be great. Thanks!
GMracer
11-13-2008, 08:43 AM
I used the the center point of the cam, pretty standard area, once it's together I will again run it through the program and re-tweak it.
GMracer
11-13-2008, 08:44 AM
no kidding :headbang:
RAMKAT2
11-14-2008, 08:53 PM
Maybe I missed it earlier in this thread, but what vehicle did the rack and pinion steering unit come from? Thanks, Randy
GMracer
11-15-2008, 04:12 AM
Stock silverado rack
xx_ED_xx
11-20-2008, 06:03 PM
Beautiful Work :)
bonecrrusher
12-04-2008, 08:05 PM
Any updates to this?
GMracer
12-05-2008, 03:45 PM
waiting on parts, and donations =P just playing, but just waiting to get my rear end parts in and my 14 bolt narrowed.
icebird84
12-05-2008, 05:11 PM
excellent build IŽam looking forward next post to see more photo form the build .
Keep up the excellent work your doing
1971CHEVELLE
12-14-2008, 08:05 AM
Any updates to this....
GMracer
12-15-2008, 04:28 AM
now many, got to drop off my rearend to get shortened, been busy with school finals this week though so Ill have a month of time to work on it, expect some good updates then.
GMracer
12-23-2008, 08:53 PM
UPDATES!!!!
Xmas break is hear and I want to get this frame done... so without further or do, tonights progress...
I wanted to tie in the two front crossmembers, so I began with some tubing
https://static1.pt-content.com/images/pt/2008/12/HPIM1581-1.jpg
https://static1.pt-content.com/images/pt/2008/12/HPIM1580-1.jpg
https://static1.pt-content.com/images/pt/2008/12/HPIM1582-1.jpg
https://static1.pt-content.com/images/pt/2008/12/HPIM1585-1.jpg
Checked all the clearances
https://static1.pt-content.com/images/pt/2008/12/HPIM1586-1.jpg
https://static1.pt-content.com/images/pt/2008/12/HPIM1591-1.jpg
Now those tie them in, lets add some strength to the front end, what's stronger than an X?
https://static1.pt-content.com/images/pt/2008/12/HPIM15903-1.jpg
https://static1.pt-content.com/images/pt/2008/12/HPIM15902-1.jpg
GMracer
12-23-2008, 08:57 PM
Trans crossmember, the start
Cutting away with a cutoff wheel, and my almost gone sheet of 3/16"
https://static1.pt-content.com/images/pt/2008/12/HPIM15904-1.jpg
The outcome, well I used a holesaw for the holes
https://static1.pt-content.com/images/pt/2008/12/HPIM15905-1.jpg
Nice and tight fit
https://static1.pt-content.com/images/pt/2008/12/HPIM15906-1.jpg
Cut the top piece
https://static1.pt-content.com/images/pt/2008/12/HPIM15908-1.jpg
All tac'd
https://static1.pt-content.com/images/pt/2008/12/HPIM15909-1.jpg
https://static1.pt-content.com/images/pt/2008/12/HPIM159011-1.jpg
https://static1.pt-content.com/images/pt/2008/12/HPIM159012-1.jpg
The welded it all together, the corner gussets are temp, going to make one piece for it tomorrow
https://static1.pt-content.com/images/pt/2008/12/HPIM159014-1.jpg
https://static1.pt-content.com/images/pt/2008/12/HPIM159016-1.jpg
https://static1.pt-content.com/images/pt/2008/12/HPIM159017-1.jpg
Nate K
12-24-2008, 01:03 PM
The frame looks awsome it is really coming together.
GMracer
12-25-2008, 07:46 AM
Finished up the trans crossmember...
https://static1.pt-content.com/images/pt/2008/12/HPIM1602-1.jpg
Smoothed out the welds real nice
https://static1.pt-content.com/images/pt/2008/12/HPIM1606-1.jpg
https://static1.pt-content.com/images/pt/2008/12/HPIM1608-1.jpg
https://static1.pt-content.com/images/pt/2008/12/HPIM1610-1.jpg
https://static1.pt-content.com/images/pt/2008/12/HPIM1611-1.jpg
Mocked it up
https://static1.pt-content.com/images/pt/2008/12/HPIM1613-1.jpg
https://static1.pt-content.com/images/pt/2008/12/HPIM1617-1.jpg
https://static1.pt-content.com/images/pt/2008/12/HPIM1619-1.jpg
https://static1.pt-content.com/images/pt/2008/12/HPIM1623-1.jpg
Now this plate will be welded to the frame and the nuts will be on the inside, a hole will be drilled to clearance the nuts and the plate will sit flush on the frame and welded all around.
https://static1.pt-content.com/images/pt/2008/12/HPIM1625-1.jpg
Then the other plate will be welded to the crossmember and allow it to be bolted in
https://static1.pt-content.com/images/pt/2008/12/HPIM1626-1.jpg
https://static1.pt-content.com/images/pt/2008/12/HPIM1627-1.jpg
craigs73
12-25-2008, 08:23 AM
nice work :1st: wish i had the tools and talent to do this maybe someday with a lot of practice good work:1st:
Inverter
12-25-2008, 02:15 PM
Lookin good Nick.Love that X brace under the rack. Nice to see your back at it. btw,,how much are you narrowing that rear end?Are you going to run a super wide tire/wheel in the rear? Yea,Im too lazy to go back through the entire thread.
Great fabbing,as always.
T_Raven
12-25-2008, 11:10 PM
Awsome build. Can't wait to see more.
GMracer
12-26-2008, 05:05 AM
Thanks everyone
Narrowed I think rougly 6" inches each side from stock width, I can't remember exactly from a stock housing just that the new one was 54" end of tube to end of tube I believe. I'm running 20x15 Intros, with the wheel center just about centered in the hoop, I want a dish but not a rediculous dish set all the way back.
Inverter
12-26-2008, 12:29 PM
Thats about a 7" lip or so..and a whole lotta rubber . a one off truck 4 sure.
btw,you should do the throw back sig.on here. That shot of the rear looks hott man.... Later
ed1le
12-26-2008, 08:16 PM
That's some nice frame work...keep the updates coming!
GMracer
12-26-2008, 09:24 PM
ok heres another...
well finished the trans crossmember...
Drilled some holes to recess the nuts
https://static1.pt-content.com/images/pt/2008/12/HPIM1633-1.jpg
https://static1.pt-content.com/images/pt/2008/12/HPIM1635-1.jpg
https://static1.pt-content.com/images/pt/2008/12/HPIM1636-1.jpg
Cut the crossmember and tac'd it in place
https://static1.pt-content.com/images/pt/2008/12/HPIM1638-1.jpg
https://static1.pt-content.com/images/pt/2008/12/HPIM1641-1.jpg
All set
https://static1.pt-content.com/images/pt/2008/12/HPIM1643-1.jpg
https://static1.pt-content.com/images/pt/2008/12/HPIM1644-1.jpg
https://static1.pt-content.com/images/pt/2008/12/HPIM1645-1.jpg
https://static1.pt-content.com/images/pt/2008/12/HPIM1647-1.jpg
Then played with some ideas for the next crossmember, and since I wanted to have one at the sweep up, and one 6" back from the ujoints I needed to come up with a good looking way to do so, instead of three round bars in a row, so I added another X
https://static1.pt-content.com/images/pt/2008/12/HPIM1648-1.jpg
Cut some tubing, and notched the small pieces
https://static1.pt-content.com/images/pt/2008/12/HPIM1650-1.jpg
https://static1.pt-content.com/images/pt/2008/12/HPIM1652-1.jpg
GMracer
12-26-2008, 09:25 PM
https://static1.pt-content.com/images/pt/2008/12/HPIM1653-1.jpg
https://static1.pt-content.com/images/pt/2008/12/HPIM1654-1.jpg
All done by eye and a hole saw on a drillpress
https://static1.pt-content.com/images/pt/2008/12/HPIM1658-1.jpg
icebird84
12-26-2008, 09:40 PM
nice to see that the excellent work continues , IŽm looking forward to see a Rolling Chassis keep up the truly excellent work
GMracer
12-27-2008, 08:15 AM
me too, that's why I'm working my ass off on it, I want the body on, however the wheels and brakes will be a little while till I can fork the cash for them. Thanks for the kind words though.
Chad-1stGen
12-27-2008, 09:20 AM
Awesome fab work. Just read the whole thread for the first time.
I'm curious. What is the main purpose behind the custom frame? Sounds like front suspension will be pretty much stock geometry so is it to fit the 4 link in the rear with the fat tires? Do you think you will save weight versus factory frame?
GMracer
12-27-2008, 11:46 AM
nope, the whole front suspension was redesigned, moved everything upwards to accommodate the 5" lower ride height while keeping my RC at a better height to make it handle the power in the turns. Plus the rear half was yes, to fit the fat meats.
EDIT I'm not sure if I will save weight or not, I'm designing it on strength not weight, since this is only my first frame to build.
Dream68
12-27-2008, 11:58 AM
Looks great, cant wait to see the progress!:cool:
Chad-1stGen
12-28-2008, 10:51 AM
Cool. Well for your first effort the fab work sure looks great
GMracer
12-28-2008, 10:59 AM
thanks man, actually back here today working on it. Pictures later
GMracer
12-28-2008, 09:59 PM
Rear suspension mock up, I HATE waiting for laser cut brackets to come in, so I took my sheet of 3/16"s and some cut off wheels and flap disks and made my own brackets... yet again :crazy:
https://static1.pt-content.com/images/pt/2008/12/Dec273-1.jpg
https://static1.pt-content.com/images/pt/2008/12/Dec272-1.jpg
Mounted the bars
https://static1.pt-content.com/images/pt/2008/12/Dec2713-1.jpg
Took my mandrels I ordered and got those ready to cut
https://static1.pt-content.com/images/pt/2008/12/Dec2721-1.jpg
Cut and tac'd in place
https://static1.pt-content.com/images/pt/2008/12/Dec286-1.jpg
Now I want everything adjustable, that way I can play with my settings, but again I didn't want to wait for my brackets
so I made these too, then ran out for the other side
https://static1.pt-content.com/images/pt/2008/12/Dec289-1.jpg
https://static1.pt-content.com/images/pt/2008/12/Dec284-1.jpg
https://static1.pt-content.com/images/pt/2008/12/Dec2819-1.jpg
Needed to space it out to match the axle side
https://static1.pt-content.com/images/pt/2008/12/Dec287-1.jpg
The bolted extra bushing for spacer and ran out of material for the night
https://static1.pt-content.com/images/pt/2008/12/Dec288-1.jpg
https://static1.pt-content.com/images/pt/2008/12/Dec2821-1.jpg
https://static1.pt-content.com/images/pt/2008/12/Dec2815-1.jpg
GMracer
12-28-2008, 10:00 PM
https://static1.pt-content.com/images/pt/2008/12/Dec2817-1.jpg
https://static1.pt-content.com/images/pt/2008/12/Dec2818-1.jpg
The plate is for JUST the top link, and allows 0*-10* change, 5 positions, all I need to do exactly what I need.
(shown in the 10* spot)
https://static1.pt-content.com/images/pt/2008/12/Dec281-1.jpg
so what degree are you going to school for? Where did you get your frame building skills? This sure doesn't look like your first frame that's for sure
Inverter
12-29-2008, 07:01 PM
He's a flippin Carpenter! Can you believe it? Sorry Nick,,I had to say it.
All this fancy talk about Satchell n stuff got me lost,now I just look at the pictures...:injured:
GMracer
12-29-2008, 08:40 PM
yea I'm in school for carpentry, and yes it's my first frame.... a lot of work and snags along the way and design efforts. I already know what I'd do different next time. Thanks though, it means a lot!
mr.regal
12-29-2008, 08:45 PM
you are making it really hard for me not to sell my car and get a truck like yours as a DD, and just lower it and rims. keep up the good work, cannot wait to see the end result
T_Raven
12-30-2008, 04:37 AM
You're gonna be a carpenter eh? Maybe you mentioned it but whos shop are you working in? Do you work there?
GMracer
12-30-2008, 05:18 AM
My dads business, yes I've been there for about 10 years working there
jackfrost
12-30-2008, 12:05 PM
what kind of welder are you using? you're a great fabricator... keep it up.
GMracer
12-30-2008, 12:12 PM
thanks man, I'm still learning and can definitely improve upon some things... Lincoln 235 Powermig, I need my won though this is the businesses unfortunately.
796spdbu
12-30-2008, 03:42 PM
BAD ASS man!! Im digging it!
GMracer
12-30-2008, 08:49 PM
Grabbed another sheet of 3/16"
https://static1.pt-content.com/images/pt/2008/12/Dec302-1.jpg
Built my upper link mounts, going to gusset behind them otherwise they are basically done
https://static1.pt-content.com/images/pt/2008/12/Dec3011-1.jpg
https://static1.pt-content.com/images/pt/2008/12/Dec3018-1.jpg
https://static1.pt-content.com/images/pt/2008/12/Dec3019-1.jpg
https://static1.pt-content.com/images/pt/2008/12/Dec3021-1.jpg
https://static1.pt-content.com/images/pt/2008/12/Dec3023-1.jpg
https://static1.pt-content.com/images/pt/2008/12/Dec3024-1.jpg
https://static1.pt-content.com/images/pt/2008/12/Dec3027-1.jpg
As you can see here the holes I drilled on a 25" radius (same as bar length) no need to re thread as I adjust my bar angles
https://static1.pt-content.com/images/pt/2008/12/Dec3032-1.jpg
formula98
12-31-2008, 11:26 PM
Really nice work. It is great to see this post. keep up the great work!
GMracer
01-05-2009, 07:50 PM
Quick update
Started my lower link brackets, 3 position adjustable
https://static1.pt-content.com/images/pt/2009/01/HPIM1769-1.jpg
https://static1.pt-content.com/images/pt/2009/01/HPIM1763-1.jpg
https://static1.pt-content.com/images/pt/2009/01/HPIM1760-1.jpg
https://static1.pt-content.com/images/pt/2009/01/HPIM1762-1.jpg
https://static1.pt-content.com/images/pt/2009/01/HPIM1759-1.jpg
https://static1.pt-content.com/images/pt/2009/01/HPIM1765-1.jpg
Both bars at 0*
https://static1.pt-content.com/images/pt/2009/01/HPIM1767-1.jpg
And roughly where the bags will sit
https://static1.pt-content.com/images/pt/2009/01/HPIM1771-1.jpg
These are NOT the bags I'm using, I'm going to run the new f9200s instead, and the upper link bracket will probably be part of the bag bracket.
mr.regal
01-05-2009, 08:02 PM
that is some fine work you have done. keep it up
wickedspirits
01-10-2009, 08:06 PM
Any updates on this thing? Bada$$ build man.
GMracer
01-14-2009, 01:40 PM
Wanted to add a gusset for the upper link mounts
https://static1.pt-content.com/images/pt/2009/01/Jan730-1.jpg
https://static1.pt-content.com/images/pt/2009/01/Jan731-1.jpg
https://static1.pt-content.com/images/pt/2009/01/Jan728-1.jpg
Finished up the lower link mounts
Had to bend and weld them together
https://static1.pt-content.com/images/pt/2009/01/Jan72-1.jpg
Welded them up and added a gusset
https://static1.pt-content.com/images/pt/2009/01/Jan723-1.jpg
https://static1.pt-content.com/images/pt/2009/01/Jan726-1.jpg
https://static1.pt-content.com/images/pt/2009/01/Jan712-1.jpg
https://static1.pt-content.com/images/pt/2009/01/Jan713-1.jpg
Finally designed and made my under engine bolt in crossmember
https://static1.pt-content.com/images/pt/2009/01/Jan719-1.jpg
https://static1.pt-content.com/images/pt/2009/01/Jan718-1.jpg
https://static1.pt-content.com/images/pt/2009/01/Jan720-1.jpg
https://static1.pt-content.com/images/pt/2009/01/Jan721-1.jpg
1971CHEVELLE
01-14-2009, 02:46 PM
Wow...awesome metal work:1st:
796spdbu
01-14-2009, 08:27 PM
Nice!!!!!!
trackrat79
01-15-2009, 08:38 AM
Your making awesome progress, Wish i could say the same.
Anyway, keep up the good work. Eagerly awaiting the final product.
GMracer
01-15-2009, 10:17 AM
thanks guys!
brrymnvette
01-15-2009, 02:38 PM
This is f'kin awesome. I think this is tied with the Syborg build for coolest on here. Both trucks. But that's my $0.02
I wish I could fab like this.
GMracer
02-09-2009, 12:39 PM
CAB IS ON!!!!
So I finally got my new rear bags, f9100s and at $200 a pc I was skeptical, till they showed up and I love them. On the right is a f9000, (blue tape protecting the billet)
https://static1.pt-content.com/images/pt/2009/02/HPIM1846-1.jpg
https://static1.pt-content.com/images/pt/2009/02/HPIM1847-1.jpg
https://static1.pt-content.com/images/pt/2009/02/HPIM1848-1.jpg
They get 9.75" of travel, compared to 6.5" ( I think on the f9000)
More hand made brackets
https://static1.pt-content.com/images/pt/2009/02/HPIM1834-1.jpg
https://static1.pt-content.com/images/pt/2009/02/HPIM1835-1.jpg
https://static1.pt-content.com/images/pt/2009/02/HPIM1837-1.jpg
Rear bag brackets complete
https://static1.pt-content.com/images/pt/2009/02/HPIM1844-1.jpg
Bag in
https://static1.pt-content.com/images/pt/2009/02/HPIM1849-1.jpg
Rear end being welded up
https://static1.pt-content.com/images/pt/2009/02/HPIM1853-1.jpg
GMracer
02-09-2009, 12:50 PM
The edges arent smooth because there will be a shock mount in front of that shortly
https://static1.pt-content.com/images/pt/2009/02/HPIM1855-1.jpg
https://static1.pt-content.com/images/pt/2009/02/HPIM1857-1.jpg
https://static1.pt-content.com/images/pt/2009/02/HPIM1888-1.jpg
Stock way bar (shape) can be used, plan to run a muscle bar from ART
https://static1.pt-content.com/images/pt/2009/02/HPIM1863-1.jpg
Now before I flipped the frame I thought about any weak point and this one stood out to me, where I pie cut it, so I added a gusset, couldn't hurt
https://static1.pt-content.com/images/pt/2009/02/HPIM1870-1.jpg
https://static1.pt-content.com/images/pt/2009/02/HPIM1875-1.jpg
Stripped
https://static1.pt-content.com/images/pt/2009/02/HPIM1878-1.jpg
Flipped
https://static1.pt-content.com/images/pt/2009/02/HPIM1889-1.jpg
GMracer
02-09-2009, 12:51 PM
Boxed in the LCA mounts
https://static1.pt-content.com/images/pt/2009/02/HPIM1890-1.jpg
https://static1.pt-content.com/images/pt/2009/02/HPIM1891-1.jpg
https://static1.pt-content.com/images/pt/2009/02/HPIM1892-1.jpg
Welded up and smoothed the bottom side, Plan to DA it before Powder coat
https://static1.pt-content.com/images/pt/2009/02/HPIM1898-1.jpg
and the frame heads home...
Back in the garage, (before I organized my tools and such for more room)
https://static1.pt-content.com/images/pt/2009/02/HPIM1902-1.jpg
Money shot 3/4" from rocker, right where I want it
https://static1.pt-content.com/images/pt/2009/02/HPIM1904-1.jpg
https://static1.pt-content.com/images/pt/2009/02/HPIM1908-1.jpg
https://static1.pt-content.com/images/pt/2009/02/HPIM1909-1.jpg
https://static1.pt-content.com/images/pt/2009/02/HPIM1910-1.jpg
https://static1.pt-content.com/images/pt/2009/02/HPIM1911-1.jpg
https://static1.pt-content.com/images/pt/2009/02/HPIM1912-1.jpg
brrymnvette
02-09-2009, 12:56 PM
wow
T_Raven
02-09-2009, 01:25 PM
Did you mention where you got the ends for your 4 link? I plan to build one for my 67 Firebird and I've been trying to find some good ends to use
GMracer
02-09-2009, 01:52 PM
SuicideDoors.com
GBodyGMachine
02-09-2009, 02:00 PM
Thats sick man, you are doing an amazing job.
GMracer
02-09-2009, 04:10 PM
thanks man:smoke:
badbu68
02-16-2009, 10:30 PM
Caught your sig in another post, man, I really want a blacked out silverado now. Nice metal work, that truck is insane.
GMracer
02-23-2009, 01:16 PM
Well I found a slight flex out back wanted to add another triangulated brace
https://static1.pt-content.com/images/pt/2009/02/Sch02224-1.jpg
https://static1.pt-content.com/images/pt/2009/02/Sch02225-1.jpg
Brand new, perfect condition bed...
https://static1.pt-content.com/images/pt/2009/02/Sch02227-1.jpg
Now all cut and section bed floor raised 5.5"
https://static1.pt-content.com/images/pt/2009/02/Sch022210-1.jpg
https://static1.pt-content.com/images/pt/2009/02/Sch022211-1.jpg
I didn't want to go more then 5.5" So to get the last >1" I'll section the bed crossmembers over the frame.
https://static1.pt-content.com/images/pt/2009/02/Sch022212-1.jpg
Cut the firewall and trans tunnel out to accommodate the motor, (body dropped 2", motor raised 1" and moved back 1.5"
https://static1.pt-content.com/images/pt/2009/02/Sch022215-1.jpg
Motor view, looks pretty far back without any accessories on it
https://static1.pt-content.com/images/pt/2009/02/Sch022217-1.jpg
https://static1.pt-content.com/images/pt/2009/02/Sch022218-1.jpg
Got my hubs from Moser Friday, should have my axles this coming Friday
5x5 lug pattern, 1/2"x120 screw in studs
https://static1.pt-content.com/images/pt/2009/02/Sch022225-1.jpg
brrymnvette
02-23-2009, 02:17 PM
Still WOW. Are those the MT's you plan on running? What size are they?
GMracer
02-23-2009, 03:53 PM
yes, and 29x18xR20
Throttle
02-23-2009, 08:16 PM
Jesus!!! I still cant believe that is the same truck that I was talking to you about awhile back..
GMracer
02-23-2009, 08:31 PM
haha thanks man, always had a sweet spot for you sierra
lower90xcab
02-23-2009, 08:54 PM
sick is all i can say!!!!!!!
GMracer
03-02-2009, 06:33 AM
First of all big thanks to Marty, owner of the incredible http://www.syborgtwinturbo.com/ Big help in letting me use his wheel tool. Made it so easy to measure and check clearances.
https://static1.pt-content.com/images/pt/2009/03/030109005-1.jpg
I did however notice my wheel wasnt perfectly centered in the wheel well, and that pisses me off, however I'll be able to adjust it once I get the bed permanently mounted I'll figure out just how much I'm off.
https://static1.pt-content.com/images/pt/2009/03/030109004-1.jpg
Cut out for the tubs, still looking for a spare set of factory tubs if anyone has any laying around. Basically I want to mimic the factory just 6" wider.
https://static1.pt-content.com/images/pt/2009/03/030109006-1.jpg
One thing I hate is when people run big wheels, or such and the tires and wheel are soo tucked in leaving a huge gap between the bedside and tire, even though sometimes it requires that to fit way up top. I kept it tight, here you can kind of see the tire just touches that lip, well I plan to roll that edge so the wheel will be pretty close to the actual bedside. Laid out I still have a fingers gap up top against the bedside
https://static1.pt-content.com/images/pt/2009/03/030109007-1.jpg
Just a quick undershot
https://static1.pt-content.com/images/pt/2009/03/030109010-1.jpg
https://static1.pt-content.com/images/pt/2009/03/030109011-1.jpg
Measuring for backspacing
https://static1.pt-content.com/images/pt/2009/03/030109017-1.jpg
Moving up front
https://static1.pt-content.com/images/pt/2009/03/030109013-1.jpg
https://static1.pt-content.com/images/pt/2009/03/030109014-1.jpg
Mounted the tire
https://static1.pt-content.com/images/pt/2009/03/030109018-1.jpg
This is set at ride height
https://static1.pt-content.com/images/pt/2009/03/030109019-1.jpg
https://static1.pt-content.com/images/pt/2009/03/030109020-1.jpg
GMracer
Lock to lock
https://static1.pt-content.com/images/pt/2009/03/030109021-1.jpg
https://static1.pt-content.com/images/pt/2009/03/030109024-1.jpg
https://static1.pt-content.com/images/pt/2009/03/030109025-1.jpg
https://static1.pt-content.com/images/pt/2009/03/030109026-1.jpg
https://static1.pt-content.com/images/pt/2009/03/030109028-1.jpg
Almost laid out, need to trim some more.
https://static1.pt-content.com/images/pt/2009/03/030109031-1.jpg
https://static1.pt-content.com/images/pt/2009/03/030109033-1.jpg
Brandon Miller
03-02-2009, 06:38 AM
That is pure sex right there. Those two shots are awesome.
GMracer
03-02-2009, 06:49 AM
thanks man, I thought the same
brrymnvette
03-02-2009, 07:02 AM
I'm gonna have to remember who has the tool, hopefully I can rent it when I get to the point of my build. I'm sticking the exact same rear tires under my 89 Mustang Notch. Getting ready to start on my frame rails soon.
Radlark
03-02-2009, 08:25 AM
GMRacer man all I can say is your very talented! Great work man keep the pics rolling, great inspiration!
GMracer
03-02-2009, 09:06 AM
thanks man! and Brrymnvette, I believe he does rent it, but you need to ask him first.
Memphis
03-02-2009, 10:14 PM
Man you are really cooking on this, great job!
jackfrost
03-03-2009, 10:14 AM
it must feel good to see some sheetmetal on there. this thing is going to be badazz.
1971CHEVELLE
03-03-2009, 01:12 PM
Wow coming along nicely awesome project
Throttle
03-03-2009, 05:31 PM
I feel like such a little bitch now with my little 295's on the Sierra.. :D
GMracer
03-03-2009, 06:04 PM
haha I still love em lol
Throttle
03-03-2009, 07:43 PM
Wanna trade..
:D
WhiteS-10
04-01-2009, 06:36 PM
Any more updates?
I check almost everyday hoping for one.
logikal6785
04-01-2009, 07:15 PM
Damn. I feel like I should be paying for a ticket to watch =)
GMracer
04-02-2009, 04:32 AM
waiting on the wheels, should be next week. sorry guys!
Motown 454
04-02-2009, 04:23 PM
I'll be watching to see your wheels. Very nice work.
Otto-813
04-03-2009, 05:12 AM
Looking good as always!
GMracer
04-10-2009, 02:04 PM
https://static1.pt-content.com/images/pt/2009/04/Wheels002-1.jpg
https://static1.pt-content.com/images/pt/2009/04/Wheels005-1.jpg
https://static1.pt-content.com/images/pt/2009/04/Wheels006-1.jpg
https://static1.pt-content.com/images/pt/2009/04/Wheels008-1.jpg
Didn't want a HUGE lip, I like a big subtle lip, mainly because when you have a HUGE lip you tend to lose the design of the wheel.
https://static1.pt-content.com/images/pt/2009/04/Wheels012-1.jpg
Front wheels have like 1/2" lip, but for my low ride height and altered suspension the camber isn't going to help me like normal to clear my fenders. I kind of wish I narrowed the track width but all is well
https://static1.pt-content.com/images/pt/2009/04/Wheels0141-1.jpg
20x15 rear
20x8.5" Front
Motown 454
04-10-2009, 02:35 PM
Very nice wheels!! their going to look sweet on your ride..
Wow! Those looks great. I agree about the huge lip on the rear. To me, it's like looking at a drag car with huge rear tires and ultra deep rims, you don't even notice the rim design on those cars.
1971CHEVELLE
04-10-2009, 10:41 PM
Wow.....very nice wheels
brrymnvette
04-11-2009, 09:48 AM
Looks awesome. Those look like CCW SP5's
But what are they?
GMracer
04-11-2009, 12:44 PM
Intro GT Sports modified without rivets
Paul_J
04-11-2009, 01:55 PM
I prefer the 'Sans Rivet' look as well. The project is looking really good. Keep it up!
WTRacing
04-12-2009, 01:17 PM
awesome, cant wait to see more
GMracer
04-13-2009, 06:22 AM
Specs before anyone askes
20x8.5
20x15
Intro GT Sports (modified)
Mickey Thompson 29x18x20 Rear
Toyo Proxy STII 275/40/20
https://static1.pt-content.com/images/pt/2009/04/DSC04159-1.jpg
https://static1.pt-content.com/images/pt/2009/04/DSC04160-1.jpg
https://static1.pt-content.com/images/pt/2009/04/DSC04161-1.jpg
https://static1.pt-content.com/images/pt/2009/04/DSC04164-1.jpg
https://static1.pt-content.com/images/pt/2009/04/DSC04167-1.jpg
5" Ride Height
https://static1.pt-content.com/images/pt/2009/04/DSC04171-1.jpg
https://static1.pt-content.com/images/pt/2009/04/DSC04172-1.jpg
Reason behind the new suspension design, nice parallel LCA to the ground
https://static1.pt-content.com/images/pt/2009/04/DSC04174-1.jpg
My Favorite pic right now
https://static1.pt-content.com/images/pt/2009/04/DSC04178-1.jpg
https://static1.pt-content.com/images/pt/2009/04/DSC04179-1.jpg
brrymnvette
04-13-2009, 06:29 AM
love the steamrollers. Looks awesome. Give me more motivation to get mine done now.
GMracer
04-13-2009, 06:34 AM
thanks, they were EXACTLY what I hoped for
jackfrost
04-13-2009, 10:48 AM
damn this build is amazing.
i hate to say it, but you could almost have gone w/ a bigger wheel or taller tire in the rear. those wheel wells are huge!
nice work, dude.
GMracer
04-13-2009, 11:43 AM
I wish I could have ran 22x15 but they dont make a tire, however in person they seem to fit a lot better
Maybe I'll alter the wheel wheels if I have to. Thanks for the compliments though! I super stoked about the wheels.
68byrd
04-13-2009, 06:48 PM
I like the wheels. Nothing beats a simple 5 spoke. That truck looks great. I love that body style. You are doing some amazing work. And thanks for all the pics. Keep it up!
GMracer
04-13-2009, 07:03 PM
I love sharing pics, and here comments, suggestions and criticism.
GMracer
05-30-2009, 01:51 PM
First off I finally got my own welder, Miller 180 with some extras, used 5 times. $900
https://static1.pt-content.com/images/pt/2009/05/053009021-1.jpg
Little update... been working on it here and there, but trying to save my money so I can order the rest of my ART stuff.
Well you all know I've been waiting for a set of stock tubs, and well I got some and used about 4.5" of them haha, just so I could mimic the dimple the same. Then I added a filler and side piece and what I have is a "stock looking" tub widened 6"
https://static1.pt-content.com/images/pt/2009/05/053009016-1.jpg
https://static1.pt-content.com/images/pt/2009/05/053009018-1.jpg
https://static1.pt-content.com/images/pt/2009/05/053009019-1.jpg
https://static1.pt-content.com/images/pt/2009/05/053009020-1.jpg
I was asked for pictures of the filled and redrilled axle ends, and resplines, so here you go
https://static1.pt-content.com/images/pt/2009/05/053009023-1.jpg
https://static1.pt-content.com/images/pt/2009/05/053009029-1.jpg
Another thing I noticed, going to have change out the studs Moser used, or find a 3/16" nylock nut since on the McGaughys spindles, the upper bolt is now a stud, it's going to hit the wheel stud otherwise. You can see how close they are on the bottom
https://static1.pt-content.com/images/pt/2009/05/053009024-1.jpg
Picked up a 03 Console, $100
https://static1.pt-content.com/images/pt/2009/05/053009025-1.jpg
Finally, my corners. I felt they matched my Xenarcs pretty well, I plan to order a set of clear corners and take the lense with a clear reflector and install that lens
on this housing. Depo makes these corners, if anyone is wondering.
https://static1.pt-content.com/images/pt/2009/05/053009030-1.jpg
I love how you did the tubs. Very factory looking instead of simple sheet metal tubs
brrymnvette
05-31-2009, 03:59 PM
Can I ask why you filled and redrilled the wheel studs?
Code Red
05-31-2009, 04:44 PM
looking good man
GMracer
05-31-2009, 07:07 PM
Because it was 6 lug and I needed 5 lug. Out back the axles, no one will make stock style shortened 14bsf axles. So for now these will work, however I plan to get a set of Superior stock replacement for 454ss rearend already 5 lug and have the resplined.
carguy502
05-31-2009, 09:00 PM
Great work on the wheel well housings. :1st:
I hate when guys in the truck scene use generic tubs or no tube at all. Factory is tight.
GMracer
06-16-2009, 04:30 PM
Well figured I'd share a couple pics...
Got the driver side done, it's "pretty" smooth, enough for a skim coat of rage and then line-x
https://static1.pt-content.com/images/pt/2009/06/061609002-1.jpg
https://static1.pt-content.com/images/pt/2009/06/061609003-1.jpg
https://static1.pt-content.com/images/pt/2009/06/061609004-1.jpg
Then the passenger side
https://static1.pt-content.com/images/pt/2009/06/061609001-1.jpg
https://static1.pt-content.com/images/pt/2009/06/061609006-1.jpg
https://static1.pt-content.com/images/pt/2009/06/061609008-1.jpg
GMracer
06-16-2009, 04:31 PM
I ended up finishing it, then started on the stake pockets, shaved.
https://static1.pt-content.com/images/pt/2009/06/061609021-1.jpg
https://static1.pt-content.com/images/pt/2009/06/061609022-1.jpg
https://static1.pt-content.com/images/pt/2009/06/061609023-1.jpg
https://static1.pt-content.com/images/pt/2009/06/061609015-1.jpg
https://static1.pt-content.com/images/pt/2009/06/061609018-1.jpg
https://static1.pt-content.com/images/pt/2009/06/061609020-1.jpg
https://static1.pt-content.com/images/pt/2009/06/061609024-1.jpg
Oh and I picked up a HD front end for under $300, hood, grill and cap. Pretty sweet deal, so I snagged it.
https://static1.pt-content.com/images/pt/2009/06/061609014-1.jpg
GMracer
06-16-2009, 04:43 PM
Got the stake pockets nice and smooth and pretty close to flat, just a little filler, but on the sides I'm on paint and this shows the height from the paint to bare metal. Less than 1/16"
https://static1.pt-content.com/images/pt/2009/06/061609026-1.jpg
Another pocket
https://static1.pt-content.com/images/pt/2009/06/061609027-1.jpg
Motown 454
06-16-2009, 06:27 PM
Looks Good Nick. As always
bonecrrusher
06-16-2009, 07:27 PM
I was looking for an update on this project, great progress!
Ratty 46
06-17-2009, 06:03 AM
I went through this thread this morning top to bottom .... I can only say impressive!
Keep the pix coming.
Ratty 46
jackfrost
06-17-2009, 09:17 AM
damn this is a great project. keep it going.
AUSCAMARO
06-17-2009, 10:02 AM
This thing is totally off chops.. I like it!!!
Great workmanship..
Mitch
GMracer
06-17-2009, 06:45 PM
thanks guys, I appreciate all the kind words
GMracer
07-01-2009, 05:42 PM
Oh?
https://static1.pt-content.com/images/pt/2009/07/rollpan_mockup2007-1.jpg
brrymnvette
07-01-2009, 08:10 PM
Love the roll pan. I wish there was a production one like that for the Colorado's.
GMracer
08-02-2009, 02:24 PM
two pics, I didn't want to traditionally tub it. So I'm going a different way about it... raising the stock tub upwards
https://static1.pt-content.com/images/pt/2009/08/080209_firewall001-1.jpg
https://static1.pt-content.com/images/pt/2009/08/080209_firewall002-1.jpg
GMracer
08-03-2009, 01:50 PM
Parts are in...
Muscle Bar with Posi End Links
Titanium Shockwaves, dual adjustability, with internal ride height infrared sensors, remote resi.
Titanium rear shocks, custom made for my truck, I'm actually the first to even have them. Same as the shockwaves minus the sensors.
Big Red Valves
RidePro e2
Big thanks to Tony B. at ART
https://static1.pt-content.com/images/pt/2009/08/080309_ridetechparts001-1.jpg
https://static1.pt-content.com/images/pt/2009/08/080309_ridetechparts002-1.jpg
https://static1.pt-content.com/images/pt/2009/08/080309_ridetechparts003-1.jpg
https://static1.pt-content.com/images/pt/2009/08/080309_ridetechparts004-1.jpg
https://static1.pt-content.com/images/pt/2009/08/080309_ridetechparts007-1.jpg
https://static1.pt-content.com/images/pt/2009/08/080309_ridetechparts012-1.jpg
https://static1.pt-content.com/images/pt/2009/08/080309_ridetechparts014-1.jpg
https://static1.pt-content.com/images/pt/2009/08/080309_ridetechparts008-1.jpg
https://static1.pt-content.com/images/pt/2009/08/080309_ridetechparts015-1.jpg
Looking to send back my f9100s and have them anodized to match the black chrome look the titanium series stuff has.
https://static1.pt-content.com/images/pt/2009/08/080309_ridetechparts013-1.jpg
thetoystore
08-03-2009, 03:02 PM
sick buil man. love the chasis and that model truck with the hd front end. i grafted a hd frontend to a 97 a while back and that thing was sick.
GMracer
08-13-2009, 06:07 PM
Raised it up a little bit more, and got rid of the grommet holes, I forgot that I didn't need them any more.
https://static1.pt-content.com/images/pt/2009/08/Firewall_081309001-1.jpg
https://static1.pt-content.com/images/pt/2009/08/Firewall_081309002-1.jpg
https://static1.pt-content.com/images/pt/2009/08/Firewall_081309003-1.jpg
tones2SS
08-14-2009, 12:25 PM
Looking good Nick! Keep up the great work.
dude this thing is unreal. i opened it expecting nothing what you have shown.
i'm in the build atm aswell, doing a truck you guys don't get over there (i'm from downunder) and am changing the theme from mini truck to a race truck look.
it's still in the build but getting there.
https://static1.pt-content.com/images/noimg.gif[/IMG]
and this is my rear set up with shock waves also but with a parralel 4 link and watts linkage.
look forward to the updates man, it's killer
GMracer
08-15-2009, 12:02 PM
looks killer, post up a thread of your own with more pictures
mines not really at the pro touring satge atm so not sure if i should be a build up on this site.
It's still a mini truck at this stage...
whats next for yours? get the frame power coated?
GMracer
08-15-2009, 07:27 PM
plenty of sheet metal work, exhaust, motor work, fiberglass work, brakes, plumb, wire, body work, paint and powder coat, assemble, then interior
awesome dude
have you ever had a rendering done so you can see the final product?
i did mine all backwards, i spent big bucks on paint, then decieded to do a full bag job and a 3' bd.
i'll see how i go wth pics, might do a full biuld up.
anyways dude love it and wil deffinatly follow the build
GMracer
08-16-2009, 06:33 AM
I do have a rendering but holding off on it right now, just something I put together on photoshop. Thanks for the good words!
GMracer
08-25-2009, 06:47 PM
Driverside almost done
https://static1.pt-content.com/images/pt/2009/08/FirewallGasDoor_082509004-1.jpg
Gas Door Close to finished, need to add a little more metal here and there
https://static1.pt-content.com/images/pt/2009/08/FirewallGasDoor_082509013-1.jpg
https://static1.pt-content.com/images/pt/2009/08/FirewallGasDoor_082509019-1.jpg
https://static1.pt-content.com/images/pt/2009/08/FirewallGasDoor_082509020-1.jpg
796spdbu
08-25-2009, 08:54 PM
Nice! that metal finishing is top notch.
Throttle
08-26-2009, 04:54 AM
Looking Good..
GMracer
08-26-2009, 06:24 AM
I'm sure the metal finishing just looks better in the pics, because it still needs some metal in places and I'm still getting the hang of it.
But thanks! :)
John Wright
08-26-2009, 07:45 AM
Great job Nick!
I just finished up reading this whole thread. How do you find the discipline it takes to stop everyso often to take pics?... I get my mind set on what I want to do and then get everything in gear, but I forget to take pics as I go.
GMracer
08-26-2009, 09:35 AM
recently I just take pics of final product of the night. not so much step by step anymore
Motown 454
08-26-2009, 12:14 PM
That looks good Nick
modular93fox
08-26-2009, 01:19 PM
man that filler flap is a nice touch. your doing some real nice factory lookin work - not tacky or trashy. good tastes my friend good tastes..
GMracer
08-26-2009, 04:55 PM
thanks guys!
GMracer
08-27-2009, 06:57 PM
I need to learn SolidWorks
https://static1.pt-content.com/images/pt/2009/08/Tips_082709004-1.jpg
https://static1.pt-content.com/images/pt/2009/08/Tips_082709014-1.jpg
https://static1.pt-content.com/images/pt/2009/08/Tips_082709017-1.jpg
GMracer
08-27-2009, 06:58 PM
By the way, the left top isn't welded yet cause I want the get a flange tool and lap the top seem
tones2SS
08-28-2009, 08:56 AM
Looking good Nick.
Man you got some skills. Keep up the good work bud!
What is that, exhaust cut out? Nice work regardless. I love this build up especially because it is a truck
formula98
08-28-2009, 06:23 PM
Not that difficult to learn. They have good tutorials. I've used it for the last 5 - 6 years, one of the easier 3D cad packages I've used. It's also a very powerful design package. If you start using it and have questions would be happy to answer or help you get the answers. I can also design or help you design in solidworks. I taught myself, but I've also been using Cad packages since 1985.
Great project! I love the work you have done on your project. Keep up the great posts!
GMracer
08-28-2009, 07:03 PM
Thanks for the help! and yes these are tips to come through the pan
Gearhead Dude
08-29-2009, 03:06 AM
This project continues to amaze me: Great work!
GMracer
08-29-2009, 07:12 PM
Tip done, I'm contemplating painting silver or chrome powder coat.
https://static1.pt-content.com/images/pt/2009/08/Tips_082809009-1.jpg
https://static1.pt-content.com/images/pt/2009/08/Tips_082809012-1.jpg
https://static1.pt-content.com/images/pt/2009/08/Tips_082809013-1.jpg
https://static1.pt-content.com/images/pt/2009/08/Tips_082809014-1.jpg
https://static1.pt-content.com/images/pt/2009/08/Tips_082809015-1.jpg
John Wright
08-31-2009, 10:00 AM
So that tip is made out of ga. metal to look like it is probably a half inch thick?....cool, looks like a lot of work went into that.
GMracer
08-31-2009, 11:09 AM
yes sir, 18ga. to be specific, too match the exact dimensions of the front SS duct
Oh hell that makes it even cooler. So when's this thing going to be done? :)
GMracer
09-01-2009, 05:50 PM
Couldn't tell you I hope another year
formula98
09-05-2009, 06:24 PM
The Tips look great! really nice work. I look forward to new posts.....
GMracer
10-19-2009, 08:05 AM
Thanks man, i just need to figure out how to get my exhaust all the way back there
holy crap an update!
well after a little over a month I took Sunday off to relax and work on my truck, didn't get TOO much done, but back on track.
Tubbed the otherside of the firewall, raised the factory tub of course
https://static1.pt-content.com/images/pt/2009/10/firewall_tubs101809011-1.jpg
https://static1.pt-content.com/images/pt/2009/10/firewall_tubs101809013-1.jpg
Clearance
https://static1.pt-content.com/images/pt/2009/10/firewall_tubs101809009-1.jpg
Full lock at 2" ride height, not that it matters since I wouldn't be able to turn that much with fenders, but just goes to show I made them wide enough to allow adequate turning
https://static1.pt-content.com/images/pt/2009/10/firewall_tubs101809006-1.jpg
Started on the fenders, bought two brand new OEM fenders, and proceeded to drill the spot welds out and start cutting.
https://static1.pt-content.com/images/pt/2009/10/firewall_tubs101809014-1.jpg
https://static1.pt-content.com/images/pt/2009/10/firewall_tubs101809015-1.jpg
Test fit and marked for height
https://static1.pt-content.com/images/pt/2009/10/firewall_tubs101809017-1.jpg
Cut and now to the special part, ordered two pre-99 inner fenders, going to try to make them work. They taper to quickly so they sit pretty high here, but I'm going to try to modify them. I actually have them installed opposite also, drivers on passenger. Worked better that way.
https://static1.pt-content.com/images/pt/2009/10/firewall_tubs101809018-1.jpg
https://static1.pt-content.com/images/pt/2009/10/firewall_tubs101809019-1.jpg
Motown 454
10-19-2009, 01:28 PM
Nice work Nick. I would have trouble thinking how to do this nevermind being able to. very nice.
Black-Jacket
10-22-2009, 06:39 AM
looking good nick
WTRacing
10-25-2009, 06:34 PM
incredible man, just incredible
T00LMAN
10-26-2009, 08:06 AM
Always a thread I enjoy to read on FSC.com. I look forward to seeing the truck completed.
GMracer
10-27-2009, 01:16 AM
motivators video updates gave me the idea to try these out
https://static1.pt-content.com/images/pt/2009/10/102509004-1.jpg
here is a above picture
http://www.youtube.com/watch?v=0cZJXAgbISE
http://www.youtube.com/watch?v=0EyTyml-6pk
Let me know what you guys think, I agree to what people keep saying they look big, but I think it's mainly because the motor is so bare. Once the engine bay is filled out it should look a little better
T00LMAN
10-27-2009, 07:08 AM
Looks much better with the filler panels. As for the size I do not think that you can get around that being that you need that being on airbags.
formula98
10-27-2009, 05:06 PM
Nice work! I like the video. Keep em coming
fire51
10-27-2009, 07:39 PM
awsome truck, cant wait to see it done.
FirstGenZq8
10-27-2009, 07:50 PM
love the vids! great work!
John Wright
10-28-2009, 03:35 AM
Love the progress vids...an excellent way to put thousands of words into a post without having to type them all...LOL
(pic worth a 1000 words, vid worth thousands of words)
montessaj
10-28-2009, 03:47 AM
I wish I had the guts to buy a brand new set of fenders and cut them up. :poke: You seriously have some skills.
GMracer
10-28-2009, 05:47 AM
Thanks man, luckily silverado fenders aren't nearly as expensive as some of these resto fenders for the older cars.
GMracer
11-09-2009, 08:12 AM
So after some pondering, I think I'm going to nix the OBS inner fenders... not completely sure yet. So I decided I'd go back and finish my exhaust tips. Come to find out I forgot to take into account the taper of the roll pan when I jigged up the tips and made them square to the pan not level with the ground. However it's not terrible, and too drastic so I should be able to live with it. However I need to re cut the openings in the roll pan, for now here are a few pics of them mocked up.
https://static1.pt-content.com/images/pt/2009/11/110709003-1.jpg
https://static1.pt-content.com/images/pt/2009/11/110709004-1.jpg
https://static1.pt-content.com/images/pt/2009/11/110709005-1.jpg
Here you can see the rear tip compared to the front bumper duct
https://static1.pt-content.com/images/pt/2009/11/110709006-1.jpg
brrymnvette
11-09-2009, 08:39 AM
I've been dreaming of tips and roll pan like that for years. I wish someone would just mass produce them already. For the full size and for the colorado.
OBS inner fenders?
I like the roll pan and tips. Having the tips not flush witht he roll pan could work in your favor by helping it stand out a little and not blend away. Or is it a different issue?
John Wright
11-10-2009, 06:16 AM
Scrap the tips and start over....LOL
I see what you mean about the tips not rolling around towards the outside of the truck like the roll pan does....to be honest, I bet nobody would ever know if you hadn't pointed it out. Maybe the roll pan will stretch out a bit on that side? I dunno metal work like you do so that might sound stupid and not even be feasible.
GMracer
11-10-2009, 06:21 AM
No they sit flush when they're mounted and the will fit the openings perfect, its just the flat part on the inside will be pitched down towards the back of the truck slightly. So you're right no one will notice, haha
John Wright
11-10-2009, 06:33 AM
Hurry up and get some exhaust tubing welded to those babies...LOL
Motown 454
11-10-2009, 11:18 AM
Your making some nice progress, I like the video updates.
GMracer
01-06-2010, 09:01 PM
Not much of an update, but figured I'd share. Found a water jet company 2 miles from my home so this is going to help this and future builds tremendously. I have about $170 worth of brackets being cut and will help get me to the next stage of my build... picking them up tomorrow stayed tuned for that.
As far as, have I been working on it? Well yes, but not much to take pictures, however I did finish up the exhaust tip openings, made them bigger and more symmetrical. All metal finished up. As far as the tips I decided on painting them, as well as the front bumper ducts with a chrome paint. This will allow me to do some needed bodywork, the back plate of the tip will be black to help hide the exhaust tubing opening. Stay tuned, I have one more week off from school and with work slow I may have a few "days off" so I can get some good progress.
As far as the rollpan, here are some pictures before I weld it in for good.
https://static1.pt-content.com/images/pt/2010/01/01052010003-1.jpg
https://static1.pt-content.com/images/pt/2010/01/01052010007-1.jpg
https://static1.pt-content.com/images/pt/2010/01/01052010010-1.jpg
CruizinKev
01-07-2010, 02:42 AM
looking good! nice work! :twothumbs
T00LMAN
01-08-2010, 07:33 PM
Looking good as ever Nick. :thumbup:
jevonniespapi
01-09-2010, 01:38 AM
This is very motivating. We need to talk!
GMracer
01-09-2010, 01:26 PM
Thanks, and about what?
GMracer
01-12-2010, 08:32 PM
I think it'd be way too expensive to try to make them, a LOT of work went into them,
Update time:
So this water jet thing freakin' rocks! So nice to design them in CAD and have them 1-2 days later.
Couple brackets I had cut, were the cage plates, explained in the video
https://static1.pt-content.com/images/pt/2010/01/011110001-1.jpg
Swaybar Plates to weld to the bottom side of the frame to hold the muscle bar
https://static1.pt-content.com/images/pt/2010/01/011110002-1.jpg
https://static1.pt-content.com/images/pt/2010/01/011110003-1.jpg
New rear lower bag plates
https://static1.pt-content.com/images/pt/2010/01/011110004-1.jpg
Lower Shockwave Mount
https://static1.pt-content.com/images/pt/2010/01/011110005-1.jpg
https://static1.pt-content.com/images/pt/2010/01/011110006-1.jpg
https://static1.pt-content.com/images/pt/2010/01/011110007-1.jpg
https://static1.pt-content.com/images/pt/2010/01/011110013-1.jpg
Upper Shockwave Mount
https://static1.pt-content.com/images/pt/2010/01/011110008-1.jpg
https://static1.pt-content.com/images/pt/2010/01/011110015-1.jpg
https://static1.pt-content.com/images/pt/2010/01/011110023-1.jpg
https://static1.pt-content.com/images/pt/2010/01/011110024-1.jpg
Waiting for my 3/8" Aluminum Spacers for the upper mount
https://static1.pt-content.com/images/pt/2010/01/011110025-1.jpg
Clearance? Good!
https://static1.pt-content.com/images/pt/2010/01/011110028-1.jpg
https://static1.pt-content.com/images/pt/2010/01/011110029-1.jpg
https://static1.pt-content.com/images/pt/2010/01/011110030-1.jpg
VIDEO UPDATE:
pfPCneg_EZw
CruizinKev
01-12-2010, 09:12 PM
sweet!! very nice fab work! :drool:
Motown 454
01-12-2010, 11:04 PM
Very nice, they help make some awesome fab work even better.
Eric Howell
01-13-2010, 07:41 PM
I hate you. I have to work on my truck now, and it's outside...and cold.
No, just playing. Your build is so motivating for me.
Awesome fab. So you're not a fabricator by trade?
GMracer
01-13-2010, 07:43 PM
Nope, I'm a carpenter
GMracer
03-29-2010, 06:03 AM
appears the house is for sale which means I need to find a place to put this thing, both parents will now NOT have a garage, and no room at the shop I built the chassis in. So until then I'm not sure what I'll be doing.
Sucks Nick. I hope you're able to put it somewhere safe and where you can work on it.
T00LMAN
04-12-2010, 10:23 PM
Sorry to hear of the troubles. I feel your pain. I had our Vette at my parents house since they had an extra space in their garage when we bought our current house that is short one garage. They just sold so I have the Vette in the garage at the house and the truck is without a garage. Not really a big deal since I will be selling the Vette shortly.
Tim
xx_ED_xx
07-10-2010, 04:04 PM
Now if someone just made custom chassis for our trucks. I would love my truck to look similar to the gale banks type R truck
Capown
07-10-2010, 04:59 PM
any updates???
ArtosDracon
07-10-2010, 10:35 PM
That truck is a full tube chassis with some stock bodywork wrapped around it.
GMracer
07-19-2010, 06:34 PM
So it's been quite a while since I last posted, never mind updated this thread. February 21, 2010 the day I turned 22, my whole life has changed drastically, in many ways. Rather than bore you with my life story, the house I grew up in was sold I was left without much of a choice where to live, thankfully my brother is letting me stay with him, since I just graduated also, and gives me some time to save some money up for my own place, which will be in about 2 months time. I quit my fathers business of 11yrs, and started working in construction in the city for Avalon Bay Communities, technically in an assistant supers position. Loosing the house lead me to need to find a place to store the truck, which leads to my update I now rent a garage, with storage second floor which will be a hangout, crash pad, and storage area. The garage had a 2 post, 9000lb lift in it, certified and USA made, instead of the last guy (a friend of mine) having to dismantle it I gave him the money for it, to leave it. Even the small amount of work it'll see, it's worth it. If you've worked on a lift you know what I'm talking about. Amongst plenty of other things in my life taking a complete 180 on me, I'm getting ready to get back into the swing of things. After feeling like I finally hit rock bottom with some family issues, my life is headed in what I feel the right direction finally...
So for a quick update a few pictures of the garage, and yes cooks truck is on the lift, first things first is to finish his up.
https://static1.pt-content.com/images/pt/2010/07/IMG_1343-1.jpg
https://static1.pt-content.com/images/pt/2010/07/IMG_1347-1.jpg
https://static1.pt-content.com/images/pt/2010/07/IMG_1346-1.jpg
https://static1.pt-content.com/images/pt/2010/07/IMG_1345-1.jpg
https://static1.pt-content.com/images/pt/2010/07/IMG_1344-1.jpg
https://static1.pt-content.com/images/pt/2010/07/IMG_1348-1.jpg
xx_ED_xx
07-19-2010, 07:16 PM
Thanks for the update. Good thing you are a shorter guy that lift would be hell on my back if i had to do a trans swap.
GMracer
07-19-2010, 07:25 PM
I'm just shy of 6' and can fit under standing up.
