    Results 1 to 3 of 3
    Thread: 700r question
      Dec 2007
      nanaimo bc canada
      700r question
      i helped a friend of mine replace a 700r4 in his 80 camaro the tranny is supposed to have a manual valvebody in it but not sure what one or anything he got the tranny used ...
      my question is what would cause a tranny to not bang a 2-3 upshift at wot in a car with a manual valve body it will just bounce off the rev limiter untill u get out of the throttle to about 3/4 . some people are saying too much line pressure any thoughts???
      It sounds like you could have 3-4 clutch issues. After you let off from the throttle to allow the 2-3 shift to occur, can you go back to wide open throttle? If so does it hold? What about a wot 3-4 up shift? Do you have a detent cable hooked up? Get me some more information and I will see if I can guide you.
      Mark
      Bowler Performance Transmissions
      www.bowlertransmissions.com
      Dec 2007
      nanaimo bc canada
      the tv cable is hooked up and seems to be adjusted properly ... it does not slip after it takes the shift as for hitting a 3-4 th wide open shift has not been attempted as this is a fairly violent car and not on a track
