View Full Version : Dual Fan Temp Sensor Wiring Diagram Needed
bigboi
05-07-2008, 08:56 PM
I have a Ron Davis Radiator w/ Dual Electric Fans. The fans are currently wired to a toggle switch. When the toggle switch is ON the fans will run when the car is running.
With the fans running all the time my temp is at 160. I would like the car to run at 180 so I think I need to install a temp sensor to kick the fans on at 180.
Does anyone have a wiring diagram showing how to do this?
eville
05-07-2008, 09:15 PM
Try this.
http://etxiow.accpaconline.com/itemdrilldown.cfm?category=FACC&exp=FANS&stype=cat&CFID=1429540&CFTOKEN=54301358&item=185FH
eville
05-07-2008, 09:20 PM
oh yeah, you'll want this for the second fan....
http://etxiow.accpaconline.com/itemdrilldown.cfm?category=FACC&exp=FANS&stype=cat&CFID=1429540&CFTOKEN=54301358&item=FRH
and if you want to get all fancy you'll want a SPAL PWM Fan Controller
bigboi
05-08-2008, 06:59 AM
Thanks man!
