    Results 1 to 9 of 9
      Jul 2007
      G-Body Brake Upgrade 13" Z06 F and 12" LS1 R
      I have a set of C5 Z06 front calipers / rotors and a set of LS1 Camaro rear disc brakes for my 87 MCSS. I have a new Disc/disc proportioning/combination valve. Do I need to upgrade the master cylinder
      87 Monte Carlo SS 408 LSX S482 Holley EFI 4L80e
      92 GMC Typhoon Built 4.3l Vortec Heads Baby Billet 25G Turbo
      09 G8 GT Built LS2 CNC'd LS3 Heads
      Farmington Hills, MI
      Quote Originally Posted by awdvette
      About the same setup I have. I also added hydroboost and a 1" wilwood master cylinder. Hydraboost is nice, but not required. The 1" master cylinder I would recomend.
      Jeff
      JEFF SHORTT
      -IDEAL STEEL
      Jul 2007
      I have been looking up factory master cylinders. I have access to a 1996 Impala SS master cylinder and a 86-87 Caprice master cylinder. Looks like they are 1 1/8" bore mc. Are these compatable?
      Eastern Virginia
      A long time ago I switched to the B body master cylinder & while you are at it, might as well change to the B car booster too. That is if you are not going with hydraboost.
      Scot
      86 Monte SS
      North Jersey
      The '86-'87 Caprice master will work with no mods; the fittings are the same as the Monte. I have one in my car with the 12" B-body brakes up front and S10 7/8" wheel cylinders out back, and the car stops pretty darn good!
      Steve Ragusa - North Jersey
      2006 Infiniti G35x
      Not to steal this post but since were on the topic. I'm looking to convert drum to disc an 13" rotors all the way around could someone post some links or a list of what I need to do it correct. Thanks.
      guess not
      Jul 2007
