View Full Version : Need brake booster. DSE good ?
John510
05-03-2008, 01:07 PM
Im looking for a good modern looking brake booster for my car. It will have an LS1 swap and for now I have factory disc in the front and eventually will have disc in the rear.
Anyone running the DSE booster? Or should I try and find a stock corvette one and modify it?
My other dumb question is once I find a brake booster (say I use DSE) which proportion valve do I buy?
eville
05-03-2008, 02:35 PM
If you're sure you want power brakes consider the hydraboost.
You'll need a distribution block (stock is fine) or similar and you'll likely want a proportioning valve (wilwood, summit, etc) in the line going to the rear brakes.
