View Full Version : Trunk mount battery progress
jlmccuan
04-29-2008, 06:03 PM
I made progress on my trunk mount battery with the mount, disconnect and solenoid bracket. All stainless, so it still has to be polished.
https://static1.pt-content.com/images/pt/2008/04/DSCF3267-1.jpg
https://static1.pt-content.com/images/pt/2008/04/DSCF3269-1.jpg
Samckitt
04-30-2008, 03:16 AM
Looks good!
Patrick
04-30-2008, 03:39 AM
I like how you have incorporated the disconnect and solenoid.
Samsdad2
05-08-2008, 02:26 PM
Your battery mount looks great. What amperage battery are you using? What gauge wire are you using for your positive lead to the starter?
Regards
Mark
jlmccuan
05-08-2008, 04:14 PM
The battery is 900 amp. The starter cable is 1 gauge. I used 3, 8 gauge power distribution cables. One to the trunk, one to the dash and a third to the engine bay. I got the linkage for the external shut-off done today. I'll put up pics of it this evening.
jlmccuan
05-08-2008, 07:00 PM
I started with a gun cleaning rod and handle and dipped the T handle in red Plastidip
https://static1.pt-content.com/images/pt/2008/05/DSCF3296-1.jpg
https://static1.pt-content.com/images/pt/2008/05/DSCF3297-1.jpg
I used an 8-32 stud, 2 3/16" brass compression ferrules, and an acorn nut.
https://static1.pt-content.com/images/pt/2008/05/DSCF3299-1.jpg
I drilled and slotted the disconnect switch handle
https://static1.pt-content.com/images/pt/2008/05/DSCF3307-1.jpg
Here is the assembly. Imagine the black project box is the trunk.
https://static1.pt-content.com/images/pt/2008/05/DSCF3310-1.jpg
https://static1.pt-content.com/images/pt/2008/05/DSCF3316-1.jpg
Samckitt
05-09-2008, 04:16 AM
Are you interested in making another to sell? If so how much would you sell one of the complete brackets, minus battery, solenoid & swi8tch for?
Samsdad2
05-10-2008, 05:39 AM
This may be a dumb question but why the extra solenoid? And is the disconnect on the positive side or negative side?
regards
Mark
CarlC
05-10-2008, 08:20 AM
Nice work. I really like the formed box.
I've wanted to do something similar, but running the rod through an unused bumper bolt and using a quick-connect for parking lot safety.
Something like this....
Well, I can't make the link work.
Try a Mcmaster Carr search for quick disconnect ball joint linkage.
jlmccuan
05-10-2008, 06:53 PM
The solenoid on the starter isn't used. Similar to the Ford with the solenoid moved to the trunk. The disconnect is on the positive side.
Karch
05-10-2008, 07:15 PM
Looks great.
Motown 454
05-14-2008, 02:40 PM
Nice set up looks good
