    Results 1 to 7 of 7
      Dec 2007
      nanaimo bc canada
      wilwood 12.19 rotor 15 wheel?
      Got my moser rear and wilwood dynalite kit# 140-7140 with a 12.19 rotor any chance it will fit inside a 15" wheel so i can throw the slicks on if i want to. The kit i was supposed to end up with had a 10.75 rotor
      Aug 2003
      Orlando, FL
      Depending on the backspace of the wheels, you should clear OK as the rotor and caliper package has a lot of offset.
      Apr 2008
      i have the same brakes on my 66 msutang and i have 15x10 inch ccw wheels for my slicks and they fit fine .. ofset will be the issue not diameter.
      Dec 2007
      nanaimo bc canada
      thanks guys i'll let u know how it goes
      Dec 2007
      nanaimo bc canada
      wheels fit no problem at all ... but on my first run the drivers side was quite a bit warmer than the other side any suggestions?
      Auburn, WA
      How much warmer?
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      Dec 2007
      nanaimo bc canada
      the wheel was warm when i checked the other side was cool but it didn't smell like cooked brakes.... i havent changed the master or anything
      yet does anyone know if there is a residual valve built in to the stock master of an 1982 cutlass...
      truth be told i have had absolutly zero time to pull the wheel off and look for the obvious things yet...
      i have a master from and 1982 disk brake camaro i was gonna throw on should i lose the stock prop valve all together in favor of an adjustable one like the ssbc/wilwood/russel style any info would be helpful thanks
