    Results 1 to 6 of 6
      Jan 2000
      Thousand Oaks California
      Help remind me what these clips are on my '68 Camaro
      For the life of me I can't remember what these clips and parts are for on my '68 Camaro. I think #4 might go on the parking brake pedal for the parking brake light?
      Help!
      Larry Callahan
      Jun 2001
      Newbury Park, CA
      I think you're right on #4.
      #3 looks like the clips used to hold the top of the door windlace in place.
      I don't remember about the others, but #1 looks kinda odd.
      Jan 2000
      I wonder how it goes? I played with it for a while and can't figure out how it fits.
      Larry Callahan
      Huntington Beach, CA
      2 - Holds lower windshield trim (covers cowl/windshield)
      3 - Carl is right. Connects the upper windlace and slides into the felt on the rear quarter window
      #1 covers the wiring harness as it runs down the steering column. It goes on the underneith side of the column under the adaptor that bolts the column to the studs under the dash. If you have the column out of the car you will easily see what I am saying, if you have put the column back in the car and it is bolted up....then in order to install it you must unbolt the three nuts from the (3) 3/8" studs and remove the (4) 5/16" bolts from the column adaptor so it can be removed. There will be for slots to put each corner tab into to hold it in.
      Jan 2000
      Thanks guys. I will try to re-install these today.
      Larry Callahan
