    Results 1 to 5 of 5
      05 GTO master cylinder and Brake Booster?
      67 Camaro, Got a Wilwood SL6 kit, I have a wreck 05 GTO parts car. Could I take the MC and booster off the GTO and put them on my camaro? Have heard problems with certain MC's with LS2 equiped F bodies
      St. Pete FL
      Bump for ya as I too would like to know
      HELP!!!
      I did an 05 gto/t56 swap into my 69 and went with the ATS modified
      master /slave but it wouldn't work with GTO hyd clutch bearing-
      different fittings. Used a 2002 f body hyd clutch bearing and everything went fine. I upgraded to a LS7 clutch/disc since I had to pull the
      trans off also.
      that really wasn't an answer to my question... but okay?
      St. Pete FL
      ok... good to know...
      HELP!!!
