    View Poll Results: Should I grind the welds down?
    Voters
    46. You may not vote on this poll
    • Yes, Grind them!
      5 10.87%
    • No, Don't grind them down!
      18 39.13%
    • Bacon
      23 50.00%
    Results 1 to 20 of 20
      Missouri
      Should I grind the welds down on the inside of the wheels I had widened?
      Sean James
      69 Firebird - Build Thread
      72 Firebird
      Nov 2001
      Sacramento Ca
      who widened them? weldcraft?
      I'd take them to a machine shop and have the welds taken down on a lathe.
      Tony Langlois
      1966 Corvair Monza
      Missouri
      Quote Originally Posted by TonyL
      Yes.
      Sean James
      72 Firebird
      Jun 2001
      Orlando, FL
      I would leave them. Grinding the welds flat assumes the weld has perfect penetration... not such a good idea with moving parts.
      Sheet metal: grind 'em smooth. Wheels: leave 'em be.
      Actually, the better people to ask would be the guys who did the welding.
      jp
      ​John Parsons
      Missouri
      Quote Originally Posted by parsonsj
      jp
      I did here is their response.
      You can sand the welds down smooth with the wheel surface without compromising the strength. We use die cutters and flap disks here.........and we finish them with a Dynabrade tool.
      I'm just curious as to what others would do.
      Sean James
      72 Firebird
      Clinton, MS
      You can see the HOT ROD in that BOY'S EYE'S!!
      Nov 2001
      Sacramento Ca
      It was hard not to select bacon.
      you can't go wrong with bacon.
      I'd grind them though. The exposed welds would bug me.
      Tony Langlois
      1966 Corvair Monza
      Jun 2006
      Indianapolis,IN
      Put a tire on it and forget about it.
      Tim
      Oct 2006
      Phoenix, AZ
      Ah, I see, you're talking about the welds on the inside of the hoop. I think I'd be trying to grind them smooth too. Grab a 12-pack and a stool, could take a while...
      Jeff K.
      69 Camaro SS, 406 SBC, TKO600, 9" w/3.73 tru-trac, Speedtech Arms, AFX Spindles, Lee 670 Box, Baer GT front, C5Z rear. Hyperco Leafs w/ Fays2 Watts Link + Varishocks.
      Eastern Virginia
      I would leave it.
      More about the wheel though:
      What did you widen it from & to & if you don't mind, what did it run?
      THanks
      Scot
      86 Monte SS
      Missouri
      Quote Originally Posted by Samckitt
      I would leave it.
      THanks
      9.5 to 12 and cost $225 each wheel plus shipping.
      Sean James
      72 Firebird
      Feb 2007
      Tinley Park, IL
      Once you get them installed, in the wheel well, with brakes in there... will be much harder to notice. Especially when the inner wheel gets dirty and everything has a dull finish to it. I'd install them as is, and if it bugs you... make it a future project.
      Nick ~
      1969 Cutlass
      May 2002
      Northern California
      nope, leave them there....paint the inside high temp flat black enamel if they bug ya. Looks nice.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Huntington Beach, CA
      I would leave them as is.
      Mr Nick and MrQuick both have some good suggestions.
      (Sorry, could not help myself and picked Bacon)
      Rick
      " Better to Be Lucky than Good "
      Mar 2002
      Redwood City, CA
      Mmmm..... Bacon.....
      Allen Ortega
      Oct 2007
      Well, you had yours added on the backside, mine was added to front side so I didn't have much of a choice. When I received mine back James had already smoothed down the welds, I just had to prepare myself for alot of sanding/buffing/polishing...
      The first picture was after I started with an 80 grit, this shot was taken probably around the 600 grit stage.
      After initial buff, then not happy with it and redoing it for how it looks now.
      70 RS Camaro, 447ci w/Weiand 8-71, Holley HP 750's, a whole lot of billet alumninum, blood, sweat & tears. Orange/Purple with silver thrown into the mix. Tubbed with MT SR Radial's 31x18.5x18's, Spintech oval exhaust, and a whole lot more.
      My Baby
      My Baby's Bottles
      My Baby's Arse
      Dec 2007
      Gilroy, CA
      Thats a lot of rim! Nice!
      1969 Chevelle
      www.creationsultd.com
      Jul 2007
      Northern Virginia
      Ditto
      Ray
      1996 Impala SS aka MistreSS (7800 original miles)
      LPE LT4 Heads/Intake
      Powerdyne Supercharger\T-56 Conversion
      MistreSS Updates: https://www.pro-touring.com/showthre...light=mistress
      Cant go wrong with bacon.... Also the brakes will hide it. If you are having an "I will know its there" moment then do it
      East Washington state
      I had James widen my wheels also. I'm going to grind down smooth the one small weld that connected the end of the hoop together and just slightly smooth the rest and do a quick polish job. So I voted bacon, not one or the other.
      LaMont Mulligan aka munster, leroy, mull, just don't call me late for dinner..
      My car is Therapy. 69 - Firebird into Camaro wana be. Sheep in Wolves Clothing. DSE tubs, Air Rides Airbar Rear susp., CPP Tubular CA's w/Shockwaves, Unisteer Rack&Pinion, RS Hideaways, Polished calipers, drop spindles, 4wheel disc, Be Cool rad, 18" Coddingtons Junkyard Dogs w/12"wide mod on rears, BFG KDW's 335/30/18 & 245/40/18 fronts. 383 Stroker, Edelbrock Vic Jr Heads and Manifold, lunati cam solid Roller, Pro-Magnum Roller Rockers, Demon, MSD Dist, 6AL, Thorely Tri Y ceramic coated headers. Converted to 68 dash. Moser narrowed 12 bolt and fitted for Airbar.
