View Full Version : 2005 GTO brakes on 67 camaro
saunacrank
04-07-2008, 09:09 PM
Well I have a wrecked GTO so the entire brake system is free. Any sponsors make kits to adapt these brakes to a 1st gen or am I S.O.L? I want to put on the SL6 Wilwood kit, but don't have the 3 grand to spend on them, I have more like 2, which isnt even close.
Skip Fix
04-08-2008, 12:16 PM
You can use the calipers and just get C4/C5 Vette brackets/abutements and use the kits everyone has. Pretty sure that is the main difference.
Rotors no one uses unless you make a custom set up. The offset is too much,but would give better clearance.
The 2005-6 calipers are slightly beefier.
cdoggy81
04-08-2008, 04:54 PM
yep, Skip is correct. The brackets should fit. Not sure about the rotor...
What are you doing with the rest of the GTO?
saunacrank
04-08-2008, 06:55 PM
Im just gonna buy some wilwoods, the rest of the GTO? Sell it. It wont have a motor, and it might not have the tranny, but im thinking I want a TKO so I dunno. Other than that its complete.... except for the parts that need replacing after hitting a tree, lol.
cdoggy81
04-08-2008, 07:00 PM
got ya :) I need a few parts so send me a few pics when you are done picking over it.
saunacrank
04-08-2008, 07:01 PM
what parts do u need? Im really not gonna take anything else out as of now, its listed on craigslist as a whole car
cdoggy81
04-09-2008, 03:56 PM
Just some misc stuff. email me some pics & a price. Thanks!
badd151
06-19-2013, 02:55 PM
I'm hopeing there are some updates on the gto breaks I would like to know if there is a way to use them on my 70 cutlass convertable. any help would be great.
Apogee
06-20-2013, 06:49 AM
As far as I know, no one is offering a kit for the GTO brakes as they were such a limited production run in 05-06. That said and as was mentioned before, the GTO front calipers is the same casting as the 2005+ C6 caliper, so you can use the caliper bodies with C5/C6 front pad abutment brackets along with the associated C5/C6 conversion components for your GM short-spindle application.
Tobin
KORE3
Skip Fix
06-27-2013, 12:15 PM
You might could mock them up on the C5 bracket Tobin sells and see if the GTO abutement holes can be drilled in the bracket and keep them. Although I think Vette abutments are only around $30 each.
