    Results 1 to 6 of 6
      Dec 2007
      nanaimo bc canada
      another tall spindle question
      hey guys i got a set of spindles off a 1980 camaro with 11" rotors i want to run these on my 82 cutlass with wilwood #140-9053 to match my rear.
      Another reason i want to run this setup is because i'll be running 15 wheels when i hit the strip and 16 or 17 on the street.
      Do i need new upper control arms? or is there a better/ less expensive way to do this all i have is the spindles right now if i go ahead i'll have to buy the wilwood kit and upper control arms
      May 2002
      Northern California
      Im not fluent in the B-body world but I believe it is a straight over swap. You could go with the aftermarket replacement tubular arms if you wish but I don't believe it is a requirement. It might set you more caster.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Shorter uca's are a requirement with b/f body tall spindle swap. Aftermarket uca's price range is anywhere between $100 to $500 for a set. Or you could be really cheap and shorten the stockers like I have. Without the shorter arms the fronts will have way too much camber. With this swap bumpsteer can be a problem. The easiest way I found to reduce bumpsteer is fabrication to the draglink in which the inner tierod is lowered.
      Link, Pics?
      The Gutless Cutlass, is no more.
      '73 Chevy C10, Low with lots of GO!!!!
      Dec 2007
      nanaimo bc canada
      how much is the inner supposed to be lowered is there a certain angle they need to be? doesn't seem like that big of a deal
      The first time I dropped the inner I lowered it about 1". My car drove alot better with no hint of bumpsteer anymore but I never did measure if I had any toe change. I swapped to Astro van spindles (required a lower ball joint sleeve) and bumpsteer was very noticable again. This time I checked toe change on the alignment rack before I welded it all back together.
      http://www.maliburacing.com/forum/vi...ilit=bumpsteer
      http://i10.photobucket.com/albums/a1...t/100_1083.jpg
