View Full Version : 315/40/19 F1's
cudacam
04-04-2008, 06:09 PM
I bought some well used 315/40/19's off the net to see what they would look like on the cuda. What do you guys think? I was planning on going no bigger than a 18" wheel in the back, but now I can't decide.
go-fish
04-05-2008, 02:22 AM
What type of rear susp are you using? I have a 70 with Air Rides Triangulated Four Link and was planning on mini-tubbing. I need to move the lower bars in too.
Do those tires get into the frame area any? Are you already mini-tubbed.
BTW, I plan on going 18 X as wide as I can, but it's your ride. I imagine replacing a smaller than 19? tire would be alot cheaper and then you got the jump in price on the wheels. But, again that is my opinion. You might not be concerned about those issues. They do, however, still look good.
go-fish
Are you on the Cuda-Challenger.com site?
rjsjea
04-05-2008, 08:11 AM
I put that same size on my Demon to see how they would look. I thought when compared to the fronts, they were too tall. I didnt like the 3" difference in tire diameter from front to rear.
Cuda is a bigger car though.........
ProdigyCustoms
04-05-2008, 08:35 AM
I like tall tires, but I think those are too tall.
JMO!
GinoRin
04-05-2008, 08:42 AM
I agree. Think theyre a little bit on the tall side... Otherwise great lookin car!
cudacam
04-05-2008, 09:53 AM
go-fish, The rear set-up is the air bar with Dr. Diffs 1" relocate kit. It's a B-body Strage 60 rear-end. No mini-tub. The 315's max out the wheel well for sure. I've been on the Cuda-Challenger site from time to time.
These tires measured 28.5" tall when I put a tape on them. It looks just a tad tall to me too. I wish there was a 315/40/18 out there, I think that would be perfect. I may look for a used 305/35/18 and see what it looks like. Thanks for the input.
-Cam
rjsjea
04-05-2008, 10:15 AM
Cudacam, where are you located?? I bought a few tires to mock up in the size range you are looking.....they been sitting on the side of my shop for a year now.
cudacam
04-05-2008, 10:41 AM
rjsjea, I'm in Nebraska just north of Omaha. If you have a 305/35/18 sitting around, I'd sure be interested. Just let me know what you need for it. Thanks!
-Cam
rjsjea
04-05-2008, 10:53 AM
I just checked and I have a 295/30/19, 285/35/19, and 315/40/19 sitting out there
cudacam
04-05-2008, 12:25 PM
What sizes (front/ back) did you end up going with on your Demon?
rjsjea
04-05-2008, 01:44 PM
335/30/18's and probably 255/35/18's............havent got them yet though.
DRJDVM's '69
04-05-2008, 05:15 PM
This is a mock up of my 70 Cuda with a 20 inch rear rim..... the tire I think was a "20" side wall....not enough sidewall for my tastes
https://static1.pt-content.com/images/pt/2008/04/IMG_0449-1.jpg
This is the car with a 275-40-18 tire, but no rim...too small
https://static1.pt-content.com/images/pt/2008/04/IMG_0440-1.jpg
Then the car with my actual 335-30-20 rear and 245-30-19 front....fully dropped... I'm using Air Ride front and back... the 335 is 28 inches tall. If you're gonna have a tall tire, it has to sit pretty low to look right. My car is minitubbed with a small notch in the frame and custom made tubs.
https://static1.pt-content.com/images/pt/2008/04/IMG_0634-1.jpg
I think with a tall tire you have to balance the sidewall...too much and it looks like a 4x4...too little and it looks like a rubber band. IMO the overall height of your tire is fine, but the sidewall is a bit big for that size rim etc.
BrianP
04-05-2008, 06:31 PM
I like the look of those 19s. I'd lower it so the top of the rim is the same height as the fender lip. It looks like the axle isn't centered in the wheelwell: can the suspension links be adjusted aft?
cudacam
04-05-2008, 06:52 PM
DRJDVM, Thanks for the pics. Your Cuda is going to be killer! I think your right on the hight and sidewall thing.
KQM052, I believe I would need a longer lower controll arm. The uppers are adjustible but not the lowers.
-Cam
J2speedandcustom
04-06-2008, 07:02 AM
I vote for the 315/40/19's, they fill out the wheel well perfectly. And the ride quality is going to be alot better with the 40 series sidewall. :twothumbs
The WidowMaker
04-06-2008, 03:17 PM
i love the big ones, but ill echo what has been said before; the rear must sit over them to make them look good. i cant tell you how many cars i saw at the goodguys show yesterday that either had way too much backspacing or sat waaayyy too high. this kills the look of big wheels and tires.
drop that rear end and run a tire that fills the well. im shooting for a 295 or 305/35/20 for the rear of my 70 velle. that 315/40/19 wouldnt be a bad option though.
tim
rocketman
04-06-2008, 07:20 PM
I love it bring the car down over them they will look good
Young Gun
04-06-2008, 08:07 PM
too much tire for my taste but still looks good!
sweet67
04-07-2008, 02:54 PM
"These tires measured 28.5" tall when I put a tape on them. It looks just a tad tall to me too. I wish there was a 315/40/18 out there, I think that would be perfect. I may look for a used 305/35/18 and see what it looks like. Thanks for the input.
-Cam[/quote]
I think they look good. I love a little bigger side wall, but its six one way half a dozen the other right. I have the same problem I wish someone would make a 315/40/17.
70camaro406
04-08-2008, 09:25 AM
+1 That's the truth. 25.7" is a little short. 26.5-27" would be perfect. But I want to stick with 17" wheels, too. As of now, my plans are 315/35-17 (maybe 285/40-17) rear and 275/40-17 front.
