    Results 1 to 15 of 15
      Jan 2000
      Thousand Oaks California
      Covan center gauge console. Anyone install one in a '68 Camaro?
      I have one of these for my '68 and I'm not sure what is the best way to mount it. There are no screw holes and I'm afraid to screw it up. Do none of them have mouting holes or is it just mine?
      Larry Callahan
      Jul 2001
      Detroit, Michigan
      Larry I'm glad you posted this as I was going to when I got to this stage. I have one of those two, just like in the picture and was wondering the same thing.
      Did you get the inch and 5/8's or inch and 7/8's gauges? I got the big ones.
      1968 Pro-Touring Camaro LS1
      Project: Next Year
      - Start date; June '01
      Jan 2000
      I do everything big! LOL!
      Larry Callahan
      Jan 2000
      And I still have to find space for 3 more.
      Larry Callahan
      Tucson Arizona
      Got a gas cap for that 68.....LOL!! I would love to see a panel like these that allows you to use the factory heater controls!
      Joe
      "If you can leave black marks on a straight from the time you exit a corner till the time you brake for the next turn.......
      Then, you have enough horsepower."
      -Mark Donahue
      TuoCo, CA
      Quote Originally Posted by Larry Callahan
      Coming soon.... maybe
      http://www.camaros.net/forums/showth...ghlight=pillar
      Maybe sooner than a billet filler....
      Steve
      '68 Camaro - SBC, TKO600, 3.73 Moser 12-bolt, Speedtech, ATS-AFX, Hotchkis, Forgeline, Ron Davis and C5 brakes (Kore3), Holley Terminator TBI.
      Check it Out Here
      May 2002
      Southeastern WI
      If I remember correctly on the center dash cluster I took a little piece of sheet metal or aluminum and cut tabs on it that would slide into the plastic piece that screws on near the top of the dash. Then I epoxied it to the back of the gauge cluster. I drilled two holes in the bottom of the center cluster under the bottom radius and lined them up with the stock holes in the bottom of the dash, or I might have drilled new ones in the bottom of the dash.
      Of course I never thought to take any pictures of this.
      Jeff
      Jan 2000
      Still a long way to go but they are in. I just installed a screw from the back side and aligned the Covan unit where I wanted it. Then I just pushed hard on it to dimple the back side. I then removed it, drilled through and countersunk the front side for flat head screws. I need to countersink it more but here is the basic idea.
      Larry Callahan
      Jan 2000
      I wish the gauges were not so high. This is my view when sitting in a normal seating position. Maybe I need one of those small diameter chrome steering wheels? LOL!
      Larry Callahan
      Jan 2000
      This is just a stupid shot I thought looked cool.
      Larry Callahan
      Fort Myers, FL
      Thats looking real nice Larry.
      Chris Smock aka Blazed67
      Dec 2002
      Lost Wages, Nevada
      You can put the other three on a three panel (available thru Autometer) under the center dash. Then you can also use the offset bezel rings to create the angled view like the center dash panel. Plus, the fastner spacing is perfect for it...
      Jul 2001
      Detroit, Michigan
      That looks great, Larry. That helps me out.
      Project: Next Year
      Melbourne, FL
      I made mine to use the stock mount. I'll try and find some pics. I may have posted some on here previously. What I basically did was take an old beatup stock panel. Cut off the top chrome piece. Then epoxied it to the back of the Covan panel. You can then mount it like a stock panel. Hope this helps. But I'll look for some pics.
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      Melbourne, FL
      Found a pic on another site that someone else posted using my idea. This should help a little. Not the best pic. I may try and pull mine out of storage and take a better pic.
