    Results 1 to 11 of 11
      North Carolina
      69 Camaro M/C choices
      Any suggestions for a newer GM M/C for my 69? Currently I have disks on the front and drums on the rear. Thanks.
      Oregon
      Stock discs and drums? Are you looking for manual or vacuum assist MC options? By "newer" do you mean that you would like to go with an aluminum MC to save weight and clean up the appearance, or do you just want something newer than 1969? We're pushing 40 years of options...so some additional details as to what you're searching for would be most helpful.
      Tobin
      KORE3
      It's what I does.
      North Carolina
      Sorry! Not enough info. Yes stock brakes disc/drums at the moment. I am looking to clean up a bit with something newer preferably aluminum. I'm piecing together the parts to convert over to a larger disc/disc set-up but I dont see that happening soon at the moment. I was hoping there was some newer factory GM M/C that I could go get from the local Napa.
      Oregon
      That answers the first question, how about the second one? Manual or power brake car?
      Tobin
      KORE3
      It's what I does.
      North Carolina
      OK, I'm striking out here. Power is the weapon of choice.
      Oregon
      No worries, we all have our off days.
      I like the 98-02 LS1 F-body MC for vacuum boosted C5/C6 setups. It's light weight, relatively low cost compared to the C5/C6 units, and has a 1" bore which works well with vac assist IMO, so long as you've got at least 14+ inches Hg vacuum to work with. I also like the screw-on cap and the fact that the reservoir is designed to be mounted on an incline as well.
      The cons are that the ports are on the passenger side, however potential interferences can usually be avoided with a few snug bends of the hard line. The ports are metric bubble flares...that bothers some people.
      Hopefully others will chime in with their favs.
      Tobin
      KORE3
      It's what I does.
      Apr 2008
      Im building a 67 front disc drum rear and motor doesnt have much vacum, I want to clean up the firewall and use a aluminum mc with no booster.
      thanks
      Walton, NY
      How about a 1981 Dodge D150 master? 1-1/8 bore aluminum master with plastic reservoir. You'll just have to widen the mounting ear holes to 3-3/8 on center from 3.2.
      Aug 2001
      Connecticut
      1-1/8 bore is way too big if you are running c4/c5/c6 calipers.
      1968 Camaro RS/SS, LS7 with Katech mods, T56 Magnum, C6Z06 Brakes
      1968 Camaro RS Convertible LS3/480hp/4L70E
      1962 Corvette 327-340hp stock
      1963 Corvette Split Window Coupe
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      Phoenix, AZ
      Hydroboost is the way to go for what you want
      Chris Fesler
      Walton, NY
      Quote Originally Posted by 68sixspeed
      True, but he has stock brakes.
