    Results 1 to 6 of 6
      Sep 2004
      Near Dayton, OH
      Couple of dash pics
      Finished painting/dying my dash last night from the stock dark blue to black. Seems to have turned out pretty decent. I mocked it up into place in the car along with my gauge mockup just to see how things were going to look.
      I had thoughts about doing a bunch of custom woodwork and fiberglassing with the dash but after messing around with it, I just really like the lines of the stock dash too much to change it.
      1987 Olds Cutlass Supreme FE3X Clone
      EFI455/T56/9" w/ 4.30 gears
      __________________________________________________ __
      Fort Myers, FL
      That looks real good.
      Chris Smock aka Blazed67
      Sep 2004
      Near Dayton, OH
      Thanks!
      charleston, SC
      Like the factory look. Good job.
      Robert's 1969 Camaro - 2002 LS1/T56, 10pt cage, Global West Stage III front suspension, HTH truck arm rear suspension, Sprint Cup 9" full-floating rear end, Fikse Mach V 17" up front 18" in the back and still working on it...
      Feb 2008
      Sesser, Il
      Andrew that does look good. What did you use to dye it with? I'm getting ready to start putting my interior in but I wanted to freshen up my dash first. I still can't decide if I want to go black like you did or just re-dye it the original Dark Claret. Black is easier to find, I can't locate any of the code 79 (?) Dark Claret. I might just have to get a paint shop to mix up some and spray it for me.
      Doug
      Doug Gulley
      66 C10 383, AFR 190, Accel SuperRam, Hyd Roller 230*/236* 280XFI, aftermarket T56, *under construction*
      May 2006
      looking good
