    Results 1 to 14 of 14
      Nov 2004
      In the black hole,Midwest US
      What's so great about Optima batteries?
      I don't get it, why is everybody running optima batts.? I know they resist shock and vibration better than old lead plate batts. but a conventional batt. will last 6 or 7 years at least, and I can buy 3 conventional batteries for the price of an optima. Is it just because they are prettier? Please somebody let me in the loop.
      1968 Chevy II Nova
      no go, no show
      Jan 2000
      Thousand Oaks California
      I have 2 in my trunk. I discharge them and charge them all the time. I've not driven my car in years except for one weekend. One battery lasted over 6 years and the other is still holding a charge. Another nice thing is there is no acid or the normal corrosion to deal with. I've even pulled them out and used them temorarally in other cars and they work great for me.
      I'm hooked.
      Just my two cents.
      Larry Callahan
      SoCal
      Although I haven't tried it, you're supposed to be able to mount them in any orientation.
      Jan 2002
      Crockett, Texas
      I've been using them for many years. They were actually developed across the street from our old shop.
      Here's some good info:
      http://www.optimabatteries.com/publi...ology/faq.html
      Don 67 Camaro RS/SS Texas
      Nov 2004
      Roanoke, VA
      Optimas are one of the best deals going IMO. I have 5 of them between my vehicles and they have yet to let me down. The batt in my syclone is 5+yrs old and sits for months on end and Ive only managed to run it down one time by leaving the dome light on for several weeks. After a quick charge it fired the truck right off and accepted a full charge in no time and hasnt given me a minutes trouble since. The one thats mounted in my car trailer for the winch and hydraulic tilt function gets used even less not to mention it takes quite a beating when the trailer is empty while being dragged down the freeway at ~75mph and it has never failed.
      Not only can you mount them in any position you want (I ran one in an old car mounted on its side) you dont have to worry about the corrosive gasses affecting surrounding components or that nasty white trash that builds up on the terminals of lead acid batteries thats a real pleasure to clean.
      I dont see the cost effectiveness of lead acids myself since advanced auto sells red top optimas for 109.00 compared to the price of a decent quality lead acid battery. Sure you can buy several cheapy lead acids or a couple quality lead acids in the time it would take to wear out an optima but whats the point if you still have to put up with the corrosive gasses and corroded components that surround it? No thanks, Ill buy an optima and forget it for 6 or 7 years.
      GMC Syclone (currently wrecked thanks to the typical rubber headed VA driver not paying attention to his red stop light...oh and he didnt have insurance either)
      #614 11.9 @ 113
      New stuff finished 08/06:
      4L80E trans w/TCI PCM
      Front: J&S UCA/LCA, QA1 coil overs
      Rear: Caltracks/Belltech drop leaves
      Empire drive line alum drive shaft
      Polished 17x9 F/17x11 R ZR1s with 275s/315s
      Syclone
      Tow rig
      Nov 2004
      Wow $109, that's a lot cheaper than $160 at Autozone. Unfortunately I don't know of any Advance Auto stores in my area. After a little looking I did find a red top in Summit for $119. I originally found the group 31 yellow top for $189 in summit and thats what scared me. Thanks for the info guys.
      1968 Chevy II Nova
      no go, no show
      May 2002
      Northern California
      Also try your local Honda dealer, or stereo supply house. Usually pretty cheap there too...I get em for $96. They are nice for the reasons above,no corrosion is my plus. They do go bad and when they do you will know it. The one I had fail on me did not wat to charge at all.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Fond Du Lac,Wisconsin
      Nothing worse than a lead acid battery leaking acid on your new paint job no fumes also.The only way to go. I had it Happen in the trunk what a mess. They also they last a lot longer. Will never go back to old batteries
      Nov 2003
      Maine
      napa
      i got my napa style dry cell battery for my 68 for 96 bucks too, forget who makes the napa batteries but is works awesome and has both style posts on it
      jake
      Jan 2004
      Iowa
      Optima red top battery story
      I had a boat that I used an optima in. I took it to the lake cranked on the boat for 15 min to get it started for the first time of the season(very cold blooded). It started and we warmed up the boat and took off and after joy riding for another 15 min I noticed that I only had 9 volts. I headed for the ramp(which took another 15 min). and loaded the boat up. I checked the alternator and the brushes had poped out of their holders and was charging little to none.
      So I cranked the boat started it and drove it for 30 minutes with little to no charging.
      I'm sold on it being a very good battery. I'll use it in any vehicle that needs a battery replaced from now on.
      Even better is the battery was used by the Arizona police for 1 year before I bought it for 60 bucks. They use batteries for a year and get new ones due to the electrical demands of the cars.
      Kevin
      Ontario, Canada
      Optima Q
      This question has been burning a hole in my head for some time. In regards to an NHRA Tech inspection; does a trunk mounted optima batt need to be boxed and vented if you do not have a firewall for your trunk?
      I've read that they are fume-less, but was wondering if NHRA tach inspectors accept this.
      Ken
      My other car is a Vega.
      Costco has them for $96 also.
      Stuart Seitz
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by JoeleanLS1
      keep in mind these are slightly different than the nomal ones.
      Although im running a different type of gel-cell battery in my 69 I must say that optima (and batts like them) are great.
      They are safer in a collision (no acid). they can be mounted in any position, they hold charge longer and respond to re-charging better and they have zero chance of screwing up your paint.
      Cheap insurance for $100 IMO..
      1968 Track Rat Camaro:
      Niceville, Florida 32578
      Optimas
      My wife's old SSEi had a short to ground in the primary positive battery cable and literally melted the positive side post off the battery. I pulled the battery and put it in another car that used the top posts and it worked for several more years. The Optimas are plenty tough.
      All that is necessary for evil to succeed is that good men do nothing.
      Edmund Burke
