Results 1 to 20 of 20
Thread: C5 Brakes, Manual M/C, Pads?
02-01-2005 #1
- Join Date
- Aug 2004
- Posts
- 957
I've had it with my hydroboost system. The thing works amazingly well on the street, I can't believe how well my car stops, but it is not what I want in terms of pedal feel for the track. I really love the thing, but I don't like the modulation, and am going back to a manual setup.
I want to hear specific, objective feedback regarding folks that use the C5 (not C4, that's what I have currently) in a manual configuration. What bore size M/C, and what types of pads are you using, what is the pedal effort? I am less concerned with performance on the track, in that there are tons of pad compounds out there that will work just fine, but lower temp street pads have eluded me so far for a manual setup.
The C5 calipers use a slightly larger piston size front, and "much" larger rear piston, which would better lend itself to a "larger" bore M/C. I have a manual 1", and a manual 15/16" that I can try, curious to hear others setups. When using the C4 in a manual config, I had dreadful stopping power, which it turns out may have been largely due to the Perf. Friction Z rated pads, they apparently have a very low coefficient.
Any and all comments/help would be appreciated. Oh, and by the way, in case why folks might be wondering why I would swap out a perfectly good C4 setup for a C5? Rotor thickness in the front is the main reason, the added heat capacity is going to be very important here very soon.
Mark
02-01-2005 #2Different MC sizes
Mark - have you tried some alternate master cylinder bore sizes? You might be very suprised how very differently the systems modulate when run on different master cylinders, as it really can be night and day.
If I recall, you are running that system on a somewhat smallish mc. I really think you should try a 1 1/8" bore mc on the hydraulic assist before yanking it out - you just might change your mind.
You will also find that the C5 brakes at the wheels will modulate quite better in and of themselves too
There IS a difference - Thank you for choosing Hydratech!
Paul M. Clark
Founder / Master Engineer
Hydratech Braking Systems ®
www.hydratechbraking.com
02-02-2005 #3
