    Results 1 to 14 of 14
      Phoenix, AZ
      Seat Mounting Question
      OK, here's a rather dumb question. For my 70 Chevelle (originally bench seat), I bought some Recaros to replace. They were used, so what I've got at this point are the seats themselves, and sliders. Has anyone in this situation installed seats themselves? Do I need to find some stock bucket seat mounts and then attach to the floor? I'm a little flummoxed at this point because the Chevelle floor only has mounting points for the outboard locations of the original bench, so I have no clue what I need from here. Hope that helps, and many thanks for the feedback....
      ~ Jason
      Feb 2008
      yea, easiest thing would be to find tracks for buckets, and then mount the seats to the tracks
      drill holes and a support plate (think large washer) under the floor board is probably gonna be the easiest
      Orlando, Fl
      I have vintage E21 BMW Recaro's in my car. My seat brackets came from:
      http://www.wedgeengineering.net/
      My sliders are genuine Recaro. I can't remember who I bought the sliders from. Everything was a bolt in affair. Took half an afternoon. No drilling, cutting, anything...
      Feb 2008
      www.glideengineering.com
      try this site. they are specialized in buckets, frames, mounts etc...
      Seats look good homie...
      Good luck
      SSG D
      Feb 2006
      Somewhere in the Pacific Ocean
      Here is a link to the bucket seat conversion brackets
      http://www.opgi.com/product.asp?topc...118&yearrange=
      I believe this will allow you to use the Wedge engineering kit as I've been told they use the stock bucket seat holes. You can confirm it with Wedge to be sure.
      Feb 2008
      Quote Originally Posted by 7TSS
      can these be used with pro car seats as well?
      Feb 2006
      Quote Originally Posted by deeboe78
      Not sure on the Pro Car seats. The OPG brackets are made to work with stock buckets. Your best bet is to call Wedge Engineering and see if they have something that works. Their info is in post #3 above.
      Phoenix, AZ
      I have the brackets for the Recaro seats if you need them, I use them in Camaros, Chevelles, Novas and Mustangs and they slide if the seats you have are the same as Recaro they will bolt up.
      Chris Fesler
      Phoenix, AZ
      Thanks to all for the responses. Looks like I need to make a call to OPG and figure out where to go from here...
      Orlando, Fl
      Quote Originally Posted by Chevelle LT1
      I would call Wedge first. They were VERY knowledgeable when I called with several questions. I have a sneaky suspicion OPG will know very little about the Recaro issue.
      Also, it looks like Wedge has you covered:
      If you scroll down on their main page to the item list, you will find this:
      68 -
      72
      CHEVELLE 704
      705 T
      OEM BENCH TO BUCKET
      Phoenix, AZ
      Quote Originally Posted by dipren443
      Thanks for the feedback. I ended up getting the brackets from Wedge, and they worked fantastically. Would definitely recommend them.
      Feb 2008
      Will the wedge brackets work for rally procar seats? I have this same problem. with my 70 chevelle
      thx
      SSG D
      Feb 2008
      chris
      I have the rally seats from pro car. will they fit?
      thx for the replies
      Feb 2008
      I made my own L shape brackets they worked out great. No height issues or anything.
