    Results 1 to 12 of 12
    Thread: Seam Sealer ?'s
      Houston,TX
      Seam Sealer ?'s
      Redoing the seam sealer on my firewall and am curious when the preferred time to apply it is? 3M recommends applying it over primer, but I would think it would adhere better to bare metal and resist peeling better that way? What is the general concencus on this? Over bare metal or primer?
      71' Nova - LY6, T56
      Sep 2007
      Two Rivers, Wi.
      If you could put epoxy primer down first, then seam sealer, then epoxy over the seam sealer is the prefered way, but I would put whatever primer you are using down first, then the seam sealer, and get a good two part sealer.
      Rob
      "There are questions to be answered, and answers to be questioned"
      Jigs, sandblasting, shop, paintroom, rotisserie, pictures, little bit of everything.
      http://www.1969supersport.com
      Sep 2007
      Two Rivers, Wi.
      Heres a little bit about rolling on epoxy, and they also mention the two part seam sealer. Its a pretty short thread, but the guys doing the talking know the program.
      http://www.hotrodders.com/forum/epox...on-133942.html
      Rob
      Midwest
      Here's a list of some stories where we've applied different seam sealers on several cars. The SS496 and Royal Sport Camaro features are the ones to check out. Hope this helps.
      http://v8tvshow.com/index.php?option...rdering=newest
      Kevin Oeste
      V8 Speed and Resto Shop
      V8TV
      Muscle Car Of The Week
      V8 Radio Podcast
      All about us:
      https://www.v8speedshop.com
      Houston,TX
      Appreciate the links guys. Next set of questions, which epoxy primer would be best on a budget, as well as what seam sealer? Is a two part urethane sealer worth the extra exspense?
      71' Nova - LY6, T56
      Houston,TX
      bump...
      71' Nova - LY6, T56
      Sep 2007
      Two Rivers, Wi.
      Spi costs less then ppg, and I hear a lot of good things about it.
      Heres therw web site http://www.southernpolyurethanes.com/SPI%20News.htm
      And as far as a two part seam sealer, yes absolutely worth it.
      Rob
      Houston,TX
      Quote Originally Posted by rubadub
      Rob
      Thanks for the info and link to SPI. Any links to the two part seam sealer or preferred brand?
      71' Nova - LY6, T56
      Oct 2005
      Odessa mo.
      I use Kent stuff exclusively. I'm not sure of a link I just buy mine from the rep when he comes by work. It is not available in any stores you can only buy direct or from a rep. It is either a lawson or premier company I will look and get a web site tomorrow. Never really had good luck with fusor. Whenever we had a problem with it the reps always said lets see what you did wrong. Not lets see what went wrong. Kinda leaves a bad taste in my mouth when it's always the techs fault never a bad product. I've also used SEM never liked it. same for duramix seam sealer. Also PRIME FIRST you will be cussing later when it falls off. Sand and wipe down primer before applying sealer.
      Houston,TX
      Quote Originally Posted by mikey
      Thanks for the info and tips, any chance you could get ahold of some of the Kent sealer for me? Or happen to know any retailors?
      71' Nova - LY6, T56
      Houston,TX
      Anybody have any connections on the Kent sealer?
      71' Nova - LY6, T56
      Oct 2005
      Odessa mo.
      http://www.kent-automotive.com I have a email address i will try to find it later today. Also check with your local body shops see if they use it they may be able to get you a local reps #.
