View Full Version : Exhaust Video Thread
Vegas69
02-23-2008, 03:58 PM
Let's start a thread on Exhaust.
Post your video
Post your engine specs
Post your exhaust diameter
Post which manufacturer and mufflers
It sure would be nice to hear some different options before buying.
no bags
02-24-2008, 12:20 PM
Ok , I guess I will go..........
Solid roller small block
Flowmaster 3" complete exhaust.
Enjoy!https://static1.pt-content.com/images/pt/2007/05/th_MOV01773-1.jpg (http://s84.photobucket.com/albums/k32/stepupkr8/?action=view&current=MOV01773.flv)
Yelcamino
02-24-2008, 01:02 PM
Ok, here's my '66 Chevelle:
https://static1.pt-content.com/images/noimg.gif (http://s263.photobucket.com/albums/ii131/hlumpp/Chevelle/454/?action=view&current=MOV09471.flv)
The exhaust consists of Stahl Headers (2"-2.25" stepped w/ 3.5" collectors), 3.5" Dr. Gas "X" crossover, Spin Tech Truck/RV mufflers (3.5" in, 3" out), 3" tail pipes and oval tips.
The engine is a 468 and details are in my PT Garage.
Taylor1969
02-24-2008, 03:17 PM
1969 Camaro
383 Stroker - World Iron Heads 2.02/1.50, Mid-Range Crane Cam, Edelbrock Performer EPS Manifold
Thorley Tri-Y 1 5/8 Headers
Pypes 2 1/2" 409 stainless x-pipe system
Magnaflow Stainless mufflers
Everything went together really well and installed like a dream. The headers and exhaust tuck up under the subframe and have pretty good clearance everywhere.
https://static1.pt-content.com/images/pt/2008/02/th_First_Drive-1.jpg (http://s205.photobucket.com/albums/bb172/taylor1969/?action=view&current=First_Drive.flv)
https://static1.pt-content.com/images/pt/2008/01/IMG_2716-1.jpg
https://static1.pt-content.com/images/pt/2008/01/IMG_2709-1.jpg
maldo
02-24-2008, 05:58 PM
nice set up can you give me some specs on cam etc?
fishtail8
02-24-2008, 11:47 PM
I'll play too... 406... 400hp... 1 3/4- 1 7/8 homemade stepped headers with merge collectors and a diffuser, 3" sidepipes with 3" Dynomax Race Magnums. Yes it's really loud when you get on it... Video of that come spring...
http://www.youtube.com/watch?v=gtlCAU1hUT4
http://www.youtube.com/watch?v=XbLiPYPWZO4
kmcanally
02-25-2008, 04:32 AM
solid roller 302, JBA shorties, Dr.Gas X-pipe, Flowmaster Delta 40's, full tail pipes and all 2.5"
http://s24.photobucket.com/albums/c49/kmcanally/?action=view&current=e4a036ed.pbr
Zedzag
02-25-2008, 05:43 PM
2001 LQ4, milled 317 heads, crane 228/232 .600/.600, full length 1 5/8 headers,3" dynomax ultraflows including tails.
http://www.youtube.com/watch?v=wdgaJU1ly2I
and
http://www.youtube.com/watch?v=ntV_QEPPM4k&feature=related
Vegas69
02-25-2008, 06:22 PM
:twothumbs
Zedzag I saw your burnout sounds great!
GBodyGMachine
02-26-2008, 03:24 PM
I wanna turn
383 Stroker
Big valve Canfield Heads
$90 Junk headers.
First video with open headers
Second with Junk Headers, x-pipe, 40 Series Dumped, Snow Tires
http://s28.photobucket.com/albums/c219/Camaro88z28/?action=view&current=c085cb9f.flv
http://s28.photobucket.com/albums/c219/Camaro88z28/?action=view&current=jeffburnout.flv
GBodyGMachine
02-26-2008, 03:26 PM
One More, Open Headers
https://static1.pt-content.com/images/pt/2008/02/th_JeffBuick01-1.jpg (http://s28.photobucket.com/albums/c219/Camaro88z28/?action=view&current=Jeff-Buick01.flv)
Zedzag
02-26-2008, 08:33 PM
:twothumbs
Zedzag I saw your burnout sounds great!Thanks! I'd post that vid but 'm sure it would get pulled.
01somta
02-27-2008, 07:04 PM
x2!
maldo
02-28-2008, 08:15 AM
x2!
???? not sure which set up that is?
01somta
03-02-2008, 08:56 AM
I was saying that I agree I would like to know more about the setup he is running.
no bags
03-02-2008, 12:55 PM
Hey Maldo and 01somta,
first gen chev small block
10.25 c.r.
Ultradyde solid roller
.556 lift (intake and exhaust)
Duration of 278 deg int/ 290 deg exh
112 deg lobe sep.
1.6 roller rockers
Super Victor Intake
Pump gas
426 h.p @6100
Iamtheonlyreal1
03-02-2008, 01:40 PM
Maybe the wrong side of the car, but you can hear the exhaust...
302 cu, Standard Bore, 485 Rear wheel horse, equal length headers, 2.5 inch x-pipe exhaust, flow masters, Paxton supercharger, Cobra Motor Sports intake and Performance Cam, Program ECM, Ect...The car and the engine was built ten years ago, and all the driving the car does is like that...I has only about 500 hard miles since the build.
The only problem is the ford AOD trans, they like to fall into third gear and Overdrive too fast You can hear the Slide into overdrive in the video...LOL..I Broke the shifter in the second run trying to shift back to LOW fast enough to hold second gear for a bit..I dont understand there Reasoning, NO Second Gear selection at the shifter for the Fords..... Plus no scotch blocks or Line locks, and 3.08 Posi Rear end, so my rear brakes are grabbing a bit...
http://www.youtube.com/watch?v=O4mGGFFuuO4
Ranaexcavating
03-23-2009, 04:23 PM
3" flowmasters through tails with x -pipe
https://static1.pt-content.com/images/pt/2009/01/th_MVI_7773-1.jpg (http://s254.photobucket.com/albums/hh119/jmartorana/?action=view&current=MVI_7773.flv)
TA219
03-23-2009, 05:42 PM
-Stock Internal 5.3 LSx with a LS1 intake
- S&P headers
- Magnaflow 2.5" exhaust w/ x-pipe
dont make fun of the car, it is an old video and I had broken the gas cap :machine:
http://s204.photobucket.com/albums/bb45/ta219/?action=view&current=IMGP2050.flv
SHANE 73Z
03-24-2009, 03:20 AM
Here is one with the old 355 but the current exhaust.
Thorley 1 5/8" Tri-Ys (2 1/2" collectors) 2.5" pypes X-pipe, 2.5" Edelbrock SDT mufflers, homemade 2.5" tails to dump out the sides.
Pic of exhaust on left
Click here to watch MOV01192 (http://media.putfile.com/MOV01192)
And since we love videos, the new 406 on the dyno, no media since the install though.
Click here to watch dyno-42 (http://media.putfile.com/dyno-42)
Shane
crustyz11
03-25-2009, 06:28 PM
Okay, i'm new but here goes, this is my setup so far;
-mild 355 with World heads, Comp Cams 274 cam, Edelbrock intake, Demon carb.
-cheap-o coated flowtech headers w/flowmaster american thunder exhaust.
-stock th400
-original stock 3.08 posi 12 bolt
http://www.youtube.com/watch?v=WqnUWGFvP38
Vegas69
03-25-2009, 08:26 PM
Since I started the thread it's time to post mine up.
489 Big Block Chevy Roller 593 HP/ 491 HP on the ground.
2 1/8 lemons headers into 3.5 collector
3 inch magnaflow stainless with x pipe and dumps
https://static1.pt-content.com/images/pt/2009/03/th_Dynoday309007-1.jpg (http://s200.photobucket.com/albums/aa251/Payback1969/?action=view&current=Dynoday3-09007.flv)
https://static1.pt-content.com/images/pt/2008/11/th_MVI_1254-1.jpg (http://s200.photobucket.com/albums/aa251/Payback1969/?action=view&current=MVI_1254.flv)
Procharmo
03-27-2009, 02:49 PM
I'm sure you've seen the vid before but here goes again.
Procharger F1C
Comp Cams #249-12-564-4
Grind: 274
Lift: .488''/.501''
RPM Range: 2400-6500
AFR 195 2.080,1.6 competition heads,
SBC 355, Air Gap rpm, Pro EV hat, 1.6 rockers,
1 7/8" 3.5 collectors Hooker super Comp headers,
QTP 3" electric cut outs, Jegs 3" X Pipe, Jegs 3" over the axle,
Flowmaster 3" muffler, Pypes 3" tail pipes.
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/SsBy_-Wqvb0&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/SsBy_-Wqvb0&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
TPI Monte SS
03-30-2009, 10:39 AM
Here's a vid of my Monte. It has a 355 V8, 9.8:1 compression, and ZZ4 cam. Exhaust is Edelbrock TES 1 5/8" headers into a single 3" test pipe, then split out into 2 2.5" pipes with Hooker Aerochamber mufflers. You can hear the idle and rev at the end of the video.
GbwqUmw59TI
Curley
04-07-2009, 08:30 PM
What the hell, here is mine. 383 with Thorley tri-y headers 1 5/8 primary to 2 1/2 collector, h-pipe, flo-pro mufflers to full 2 1/2 over and out the rear.
https://static1.pt-content.com/images/pt/2009/04/th_MVI_0291-1.jpg (http://s54.photobucket.com/albums/g91/curley150/?action=view&current=MVI_0291.flv)
67speedfreak
04-29-2009, 05:28 PM
Here is a vid of Agent Orange.
650 HP 502 with 2 1/8 dougs headers and custom 3in w/flow masters.
http://www.youtube.com/watch?v=rJdLIS2JF_0
ponchopwr70
04-30-2009, 04:41 AM
Heres my car with 3" oval x-pipe with small spintechs and 3" tails, with a 388 chevy, engine specs are in my pt garage http://www.youtube.com/watch?v=SER1gBLn2N0 (http://www.youtube.com/watch?v=SER1gBLn2N0)
7DRRunner
05-03-2009, 05:48 PM
70 Road Runner
440 4bbl
don't know the specs on the bumpstick
headers
Dynomax Ultra Flows 2.5"
just blowing out some condensation after a long winter's nap
http://www.youtube.com/watch?v=HwqUe2HDXhE
