View Full Version : G-Body Guys - In here for 12" LS1 Brakes!
Tony_SS
02-11-2008, 02:18 PM
Got my brakes in today and are looking good. They are LS1 twin piston calipers made to fit a g-body spindle. Best part about this setup is that it was very affordable compared to the name brand kits - plus I get to keep the stock geometry with the g-body spindle. Now I just have to track down some nice slotted 12" rotors and I'll be set.
https://static1.pt-content.com/images/pt/2008/02/582-1.jpg
nowukno
02-11-2008, 03:01 PM
Looks cool,were did you get those? hey Tony,why would you want to keep the stock G body geometry?
Tony_SS
02-11-2008, 03:30 PM
A guy off the TurboBuick board did them for me. I'm going to see if he minds me passing out his contact info before I do. And I was mainly referring to keeping the g spindle vs. the b-body one. I guess I could always do a tall lower BJ to improve the stock geometery - but this solution is a no-brainer vs the big-time 'kits'.
nowukno
02-11-2008, 04:01 PM
ok i got ya, how much?? if I my ask
Tony_SS
02-11-2008, 04:51 PM
$500 plus shipping ($65 s/h)
nowukno
02-11-2008, 05:13 PM
wow!!! not bad at all
ebmiller88
02-13-2008, 08:06 AM
Do you want brackets and hubs or the whole setup ready to bolt on?
Ed
71FormulaRA3
02-17-2008, 10:48 PM
I'm interested too... How much for the whole setup ready to bolt on?
nowukno
02-21-2008, 01:59 PM
Hey Tony,I put the rear disc brakes on the El Camino
Tony_SS
02-21-2008, 03:22 PM
That is the speedway kit, right? Looks really good and works with lowering I see.
nowukno
02-21-2008, 04:14 PM
Yes thats it Tony Im lowered 2.5" in the back no problems at all
Tony_SS
02-22-2008, 05:58 AM
That rear bracket needs to be welded? Was there any other fab work needed to mount them?
nowukno
02-22-2008, 06:07 AM
No,this is the bolt on kit..you can weld if you want.the only fab work was welding the hardline tabs on the axles were they connect to the soft line
el-camino
02-22-2008, 06:21 AM
hi tony,
i bought my brackets from www.scarebird.com
great stuff and cool service :yeah:
ebmiller88
02-26-2008, 05:12 PM
I have brackets available for the LS1 setup as well, laser cut and zinc coated as seen below. Hubs are zinc coated and have longer studs installed for you. I can do C5 brackets too:
https://static1.pt-content.com/images/pt/2008/02/Spindlebkthub6-1.jpg
78_elky
02-27-2008, 10:56 AM
So do these kits work with say a drop spindle? cuz if I was gonna go and take my front end apart again I'd go with the drop spindles this time.
But this brake stuff is really overwhelming at times, so maybe I'll wait a bit longer to get money/information LOL
jackfrost
02-27-2008, 12:30 PM
is this for the rear? any more info?
jdsfastgn
02-27-2008, 01:29 PM
They look good man. I am good friends with Robert and his son. He made a set for me and they are awesome. Im really thinking about going with a slotted rotors as well. keep us posted on the progress. BTW Thanks for the nice shirt with the GN on it. I got it on ebay a few weeks ago. Almost looks like my GN:)
GBodyGMachine
02-27-2008, 01:54 PM
Did you get those from boostinbuick?
Jeff
ebmiller88
02-27-2008, 06:26 PM
Dropped spindles work fine with these type brackets as they mount to the dust shield bolt holes which will be in the same locations on stock or dropped spindles, IE a 2102 BT dropped spindle.
Ed
Tony_SS
02-28-2008, 08:29 AM
Robert is a great guy - these were packed and shipped better than I could have imaged. I'd like to go with a dimpled or drilled and slotted rotor for a little bling, but we'll see how the budget goes. And glad you like the GN shirt! A gave a couple to Robert for his hard work.
Jack: That is the speedway motors kit. Look on their site and you'll see it for about $299 made to fit the 7.5 and 8.5 rears.
78_elky
02-28-2008, 10:39 AM
Ed
thanks man, this looks like a lot better option than all that searching and buying for the b-body swap and no bump steer.
-Josh
t72ss402
03-04-2008, 06:46 PM
Hey Tony, who did you get this kit from? Did they come with the rotors or are they seperate?
Tony_SS
03-04-2008, 07:00 PM
Got them from Robert M. I could have got a set of factory rotors with them, but am looking for something a little nicer.
maldo
03-05-2008, 08:19 AM
Hi which rotors do you use (part numbers etc) also can i use this for my 80 camaro?
t72ss402
03-05-2008, 05:47 PM
Tony can you pm me with some info to get in touch with Robert?
